Not able to send data from nrf52840 to BLE for more than 1 minute.
Hi Everyone
I am able to configure BLE on the template project and it is sending data from nrf52840 to BLE nrfconnect app using the function nrf_ble_data_send() .
However i am getting into one problem, probably a minor issue.
nrf52840 cannot send data after 1 minute or so and in the DEBUG section or nrf5connect app , i see 0 bytes received.
But if i disable and enable the notification, i can see the data but only for another 1 minute or so.
What could be the reason of such error and how can it be resolved.
Thanks
Rajat!
void ble_init()
     bool erase_bonds;
    timers_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    advertising_start();
void ble_send(char *data_pointer)
 uint16_t temp_len = 0;
 while(*(data_pointer+temp_len)!='\0')
       temp_len++;
uint16_t length = (uint16_t)temp_len;
   ble_nus_data_send(&m_nus, data_pointer, &length, m_conn_handle);
int main()
ble_init();
while(1)
ble_send("ABC");
nrf_delay_ms(1000);
  • Just a little update
    My code is sending the data even when i put a while(1); statement after sending the data once.
    IN DEBUG section of Android app , i see 0bytes received , continously after around 50 miliseconds
  • Okay!
    Good news , the issue is resolved. I think i was too anxious that i posted it here , but it has been bugging me since a week or so.
    What i did was. Instead of writing data onto UART(because i am using another module on UART) , Whatever data i was receiving through bluetooth from nrfconnect to my nrf52840. I was sending that data back to the nrfconnect app(just to make sure data was reached to microcontroller).
    In the nus event handler , i called the send_data function outside of the "if (event flag)" statement which made it to send the data again without any delay.
    It was a silly mistake ,but glad that its solved now.
    Here is the piece of code i was talking about.
    The error was on Line40. I moved the send function inside the "if(event flag)"
    char data_nus[10]="";
            uint32_t err_code;
            printf("Received data from BLE NUS. Writing data on UART.");
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
    data_nus[i]=p_evt->params.rx_data.p_data[i];
    ble_nus_data_send(&m_nus, data_nus, &(p_evt->params.rx_data.length), m_conn_handle);
    /*The BELOW STATEMENT WAS CAUSING THE BUG,BLOODY BUGGER*/
    /////ble_nus_data_send(&m_nus, data_nus, &(p_evt->params.rx_data.length), m_conn_handle);
