Serial DFU bootloader example - "No ping response after opening COM port"
We are trying to get the serial dfu example from sdk 14.2 working with an nrf52832. After flashing the device succesfully and starting up the bootloader we were unable to initiate a transfer via UART. nrfutil produces the following error message:
#  nrfutil dfu serial -pkg firmware.zip -p /dev/tty.usbmodemFA1321 -b 115200 -fc 1
[------------------------------------]    0%
  File "/usr/local/bin/nrfutil", line 11, in <module>
    sys.exit(cli())
  File "/usr/local/lib/python2.7/site-packages/click/core.py", line 722, in __call__
    return self.main(*args, **kwargs)
  File "/usr/local/lib/python2.7/site-packages/click/core.py", line 697, in main
    rv = self.invoke(ctx)
  File "/usr/local/lib/python2.7/site-packages/click/core.py", line 1066, in invoke
    return _process_result(sub_ctx.command.invoke(sub_ctx))
  File "/usr/local/lib/python2.7/site-packages/click/core.py", line 895, in invoke
    return ctx.invoke(self.callback, **ctx.params)
  File "/usr/local/lib/python2.7/site-packages/click/core.py", line 535, in invoke
    return callback(*args, **kwargs)
  File "/usr/local/lib/python2.7/site-packages/nordicsemi/__main__.py", line 741, in serial
    do_serial(package, port, connect_delay, flow_control, packet_receipt_notification, baud_rate, True)
  File "/usr/local/lib/python2.7/site-packages/nordicsemi/__main__.py", line 676, in do_serial
    dfu.dfu_send_images()
  File "/usr/local/lib/python2.7/site-packages/nordicsemi/dfu/dfu.py", line 129, in dfu_send_images
    self._dfu_send_image(self.manifest.application)
  File "/usr/local/lib/python2.7/site-packages/nordicsemi/dfu/dfu.py", line 90, in _dfu_send_image
    self.dfu_transport.open()
  File "/usr/local/lib/python2.7/site-packages/nordicsemi/dfu/dfu_transport_serial.py", line 211, in open
    raise NordicSemiException("No ping response after opening COM port")
pc_ble_driver_py.exceptions.NordicSemiException: No ping response after opening COM port
After adding NRF_LOG to the example the following debug messages showed up in the SES RTT-client:
<info> app: Inside main
<debug> app: In nrf_bootloader_init
<debug> app: in weak nrf_dfu_init_user
<debug> app: In real nrf_dfu_init
<debug> nrf_dfu_settings: Running nrf_dfu_settings_init(sd_irq_initialized=false).
<debug> nrf_dfu_flash: Calling nrf_dfu_flash_init(sd_irq_initialized=false)...
<debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
<debug> app: Initializing the clock.
<debug> app: Enter nrf_dfu_continue
<debug> app: Valid App
<debug> app: Enter nrf_dfu_app_is_valid
<debug> app: Return true. App was valid
<debug> app: In nrf_dfu_transports_init
<debug> app: num transports: 1
<info> uart: RX Id:2 len:1
<debug> app: UART initialized
<debug> app: After nrf_dfu_transports_init
<debug> app: Waiting for events
<debug> app: UART RX done
<debug> app: Received ping 1
<debug> app: Sending Response: [0x9, 0x1]
<info> uart: TX req id:2 length: 5.
We are on OS X using SES Version 3.34b and nrfutil 3.5.0 with python 2.7.14.
Even when using the precompiled example images located in /examples/dfu/secure_dfu_test_images/serial/nrf52832 we get the same error messages.
Any help is appreciated!
Regards, Julian
  • I managed to go a bit further by disabling HWFC in nrf_serial_dfu. However I am now stuck with the following error message (I already tried to use a low baudrate but with no success):
     # nrfutil dfu serial -pkg $PACKAGE -p $PORT -b 57600
        sys.exit(cli())
      File "/usr/local/lib/python2.7/site-packages/nordicsemi/__main__.py", line 745, in serial
      File "/usr/local/lib/python2.7/site-packages/nordicsemi/__main__.py", line 680, in do_serial
      File "/usr/local/lib/python2.7/site-packages/nordicsemi/dfu/dfu.py", line 97, in _dfu_send_image
        self.dfu_transport.send_init_packet(data)
      File "/usr/local/lib/python2.7/site-packages/nordicsemi/dfu/dfu_transport_serial.py", line 244, in send_init_packet
        response = self.__select_command()
      File "/usr/local/lib/python2.7/site-packages/nordicsemi/dfu/dfu_transport_serial.py", line 373, in __select_command
        return self.__select_object(0x01)
      File "/usr/local/lib/python2.7/site-packages/nordicsemi/dfu/dfu_transport_serial.py", line 383, in __select_object
        (max_size, offset, crc)= struct.unpack('<III', bytearray(response))
    struct.error: unpack requires a string argument of length 12
  • Did you try this with one of the DFU test packets from the SDK, or only with your own pack?
  • I was able to fix it and may have found a bug in nrf_serial_dfu.c (?):
    I had to increase MAX_RESPONSE_SIZE by one. Then it worked when using a low Baudrate of 14400.
    Julian
  • There seems to be some changes in the serial DFU bootloader from SDK 14.2.0 to SDK 15.0.0. Could you test if this issue is present in SDK 15.0.0 as well?
    I came here to ask the same question. I was checking this with latest sdk(sdk 15). I am going through same situation while trying to run mesh dfu example.
  • Do you get the same error? Are you using a custom board as well? Did you try the workaround by ?
  • I am going to mark this thread as answered now as my workaround fixed it for me. I did not test with SDK 15.0.0 but I suspect the problem would not persist as the code for dfu was refactored entirely.
