This is more of a bug report than a question, but not sure how to get in touch with engineers outside the forum.
In app_util.h (Using SDK 12.3.0) there are two functions for encoding a uint32_t to a byte array:
static __INLINE uint8_t uint32_encode(uint32_t value, uint8_t * p_encoded_data)
p_encoded_data[0] = (uint8_t) ((value & 0x000000FF) >> 0);
p_encoded_data[1] = (uint8_t) ((value & 0x0000FF00) >> 8);
p_encoded_data[2] = (uint8_t) ((value & 0x00FF0000) >> 16);
p_encoded_data[3] = (uint8_t) ((value & 0xFF000000) >> 24);
return sizeof(uint32_t);
static __INLINE uint8_t uint32_big_encode(uint32_t value, uint8_t * p_encoded_data)
*(uint32_t *)p_encoded_data = __REV(value);
The normal one works as expected, but the uint32_big_encode will only work with 4-byte aligned memory (on nRF51822) or it will generate a hard fault. The correct way to do it is the following code:
p_encoded_data[3] = (uint8_t) ((value & 0x000000FF) >> 0);
p_encoded_data[2] = (uint8_t) ((value & 0x0000FF00) >> 8);
p_encoded_data[1] = (uint8_t) ((value & 0x00FF0000) >> 16);
p_encoded_data[0] = (uint8_t) ((value & 0xFF000000) >> 24);
/Jimmie
