FreeRTOS app_timer.h bug?
I'm using FreeRTOS and trying to get push button events to fire. The events would fire if I held the button down long enough. I found out that the problem was that "FREERTOS" wasn't defined anywhere so the APP_TIMER_TICKS macro wasn't calculating the right value.
/**@brief Convert milliseconds to timer ticks.
 * This macro uses 64-bit integer arithmetic, but as long as the macro parameters are
 *       constants (i.e. defines), the computation will be done by the preprocessor.
 * @param[in]  MS          Milliseconds.
 * @return     Number of timer ticks.
#ifndef FREERTOS
#define APP_TIMER_TICKS(MS)                                \
            ((uint32_t)ROUNDED_DIV(                        \
            (MS) * (uint64_t)APP_TIMER_CLOCK_FREQ,         \
            1000 * (APP_TIMER_CONFIG_RTC_FREQUENCY + 1)))
#else
#include "FreeRTOSConfig.h"
#define APP_TIMER_TICKS(MS) (uint32_t)ROUNDED_DIV((MS)*configTICK_RATE_HZ,1000)
