problem using timer interrupts with softdevice S310 v1.0.0
Hello to all,
Since a couple of weeks I have a problem in a program which consist of three parts:
1.- a Timer to make a pulse train by interrupts 2.- a program to control a LCD display 3.- a program to set and clear a led and to read a button via bluetooth.
All works fine while the part of the timer to generate a pulse train is disabled, but when I enable it, all my signals in the output pins from the another parts of the program go to zero, and I have no idea what it's happening. The timer configuration I've used is the next:
    // Start 16 MHz crystal oscillator.
    NRF_CLOCK->EVENTS_HFCLKSTARTED  = 0;
    NRF_CLOCK->TASKS_HFCLKSTART     = 1;
    // Wait for the external oscillator to start.
    while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0)
        // Do nothing.
    // Clear TIMER2
    NRF_TIMER2->TASKS_CLEAR = 1;
    // Configure TIMER2 for compare[0] event every 200 ms.
    NRF_TIMER2->PRESCALER = 4;                // Prescaler 4 results in 1 tick equals 1 microsecond.
    NRF_TIMER2->CC[0]     = 1*1000UL;       // 1 tick equals 1µ , multiply by 1000 for ms value.
    NRF_TIMER2->MODE      = TIMER_MODE_MODE_Timer;
    NRF_TIMER2->BITMODE   = TIMER_BITMODE_BITMODE_24Bit;
    NRF_TIMER2->SHORTS    = (TIMER_SHORTS_COMPARE0_CLEAR_Enabled <INTENSET = (TIMER_INTENSET_COMPARE0_Enabled <'ve used is the next:
		uint32_t err_code;
		nrf_gpio_cfg_output(GPIO_OUTPUT_PIN_NUMBER);
    timer2_init();                  // Use TIMER2 to generate events every 200 ms.
		// Enable TIMER2 interrupt
    err_code = sd_nvic_ClearPendingIRQ(TIMER2_IRQn);
    err_code = sd_nvic_SetPriority(TIMER2_IRQn, NRF_APP_PRIORITY_HIGH);
    err_code = sd_nvic_EnableIRQ(TIMER2_IRQn);
    NRF_TIMER2->TASKS_START = 1;    // Start event generation.
Is the configuration of the  timer interrupts correct???
The libraries I'm using are the next:
    include stdint.h
    include string.h
    include "nordic_common.h"
    include "nrf.h"
    include "app_error.h"
    include "nrf_gpio.h"
    include "nrf51_bitfields.h"
    include "boards.h"
    include "app_timer.h"
    include "app_gpiote.h"
    include "app_button.h"
    include "spi_master.h"
    include "spi_master_config.h"
    include "nrf_delay.h"
    include "boards.h"
    include "nrf_gpiote.h"
