Is there any example for how to use app_pwm module?
I want to control the LED effect, Thanks!
I'm using the nrf_pwm driver if you want to use that. Code ripped out of its context and with very basic usage but you get the idea...
#include "nrfx_pwm.h"
static nrf_pwm_values_common_t seq_values[] = {0};
nrf_pwm_sequence_t const seq =
.values.p_common = seq_values,
.length = NRF_PWM_VALUES_LENGTH(seq_values),
.repeats = 0,
.end_delay = 0
static nrfx_pwm_config_t const config_pwm =
.output_pins = {LED_PIN, \
NRFX_PWM_PIN_NOT_USED, \
NRFX_PWM_PIN_NOT_USED }, \
.irq_priority = PWM_DEFAULT_CONFIG_IRQ_PRIORITY, \
.base_clock = (nrf_pwm_clk_t)PWM_DEFAULT_CONFIG_BASE_CLOCK, \
.count_mode = (nrf_pwm_mode_t)PWM_DEFAULT_CONFIG_COUNT_MODE, \
.top_value = PWM_DEFAULT_CONFIG_TOP_VALUE, \
.load_mode = (nrf_pwm_dec_load_t)PWM_DEFAULT_CONFIG_LOAD_MODE, \
.step_mode = (nrf_pwm_dec_step_t)PWM_DEFAULT_CONFIG_STEP_MODE, \
static nrfx_pwm_t m_pwm0 = NRFX_PWM_INSTANCE(0);
main{}
APP_ERROR_CHECK(nrfx_pwm_init(&m_pwm0, &config_pwm, NULL));
seq_values[0] = 10*(100-duty_cycle);
nrfx_pwm_simple_playback(&m_pwm0, &seq, 1, NRFX_PWM_FLAG_LOOP);
Regards
//Ola
If you prefer the app_pwm module over the driver, there are probably examples in SDK (I'm using SDK 15.0.0, don't know how it is in your case) which will be a good start.
..\examples\peripheral\pwm_library\...
Thanks!
Thanks!
