Issues while reading data from multiple sensors through TWI
I am using nrf52832 custom board with s132 to read data from 4 sensors using twi. i have 2 separate TWI with two different sensors on each bus. i am using nrf_drv_twi
driver for reading the data.
I am facing some issues while reading from both sensors on same bus. when i try to read from the second sensor, it stops working ie .. it is not able to read the data from sensors.
i am using two separate TWI instances for each twi buses.
The sampling rate of the sensors is
1st sensor = 50 sampleas/ second
2nd sensor = 1 sample in every 5 seconds.
I am also sending around 50 bytes of data per second  through a custom service, for that i kept the connection interval very hgh 40 mS.
All the 4 sensors are working individually if i disable the the sharing sensors.
What could be the issue? Using app_twi drivers will do any good?
