Program Keil generated hex file with nRFStudio
I need to program the hex application image into the PCA10001 board. However, if I program the hex file generated by the Keil compiler using nRFStudio, the application does not run correctly. The S110 is programmed correctly.
If I program using the Keil tool, the application runs fine. What am I missing?
  • I can't think of anything that should cause such behavior. Could you elaborate a bit on what in the application doesn't work (i.e. does it not run at all, does it not advertise, is it impossible to connect to or any other symptom you see.)? Also, if you could upload the hex file here, that would have been very interesting, so that I can take a look at it and test it.
  • It ended up that the PCA1001 required a power reset (i.e. unplug USB cable) for it to advertise correctly.
