Implementing a buttonless DFU for nRF51x22
We are using an nRF51x22 in one of our designs.
I am in the process of writing a bootloader that conforms to a packet format we use for loading code across our product line (this allows our suite of software tools to work across our product line, to load code into many different processors).
Anyway, we need a buttonless DFU to accomplish this.
I noticed that there is an example buttonless DFU that only supports the nRF52 products (contained in SDK version 15.0.0), but that buttonless DFU requires the loading of a special dedicated soft device to handle the buttonless toggling between the bootloader and the application.  A specialized soft device seems like an extremely complicated way to accomplish what should be a rather simple thing – the decision whether to stay in the bootloader, or jump to the application. Besides, we need a BLE stack loaded as our soft device.
I am drawn to this structure, and its use:
typedef struct
    uint32_t            crc;                /**< CRC for the stored DFU settings, not including the CRC itself. If 0xFFFFFFF, the CRC has never been calculated. */
    uint32_t            settings_version;   /**< Version of the currect dfu settings struct layout.*/
    uint32_t            app_version;        /**< Version of the last stored application. */
    uint32_t            bootloader_version; /**< Version of the last stored bootloader. */
    uint32_t            bank_layout;        /**< Bank layout: single bank or dual bank. This value can change. */
    uint32_t            bank_current;       /**< The bank that is currently used. */
    nrf_dfu_bank_t      bank_0;             /**< Bank 0. */
    nrf_dfu_bank_t      bank_1;             /**< Bank 1. */
    uint32_t            write_offset;       /**< Write offset for the current operation. */
    uint32_t            sd_size;            /**< SoftDevice size (if combined BL and SD). */
    dfu_progress_t      progress;           /**< Current DFU progress. */
    uint32_t            enter_buttonless_dfu;
    uint8_t             init_command[INIT_COMMAND_MAX_SIZE];  /**< Buffer for storing the init command. */
} nrf_dfu_settings_t;
Shouldn’t the decision to stay in the bootloader or run the application be a simple matter of triggering off the “enter_buttonless_dfu” element of the above structure?
 In order to set this value in the application, and then have the DFU evaluate it upon reset, this structure has to be stored non-volatially. Is it place in non-volatile memory at some point? If so, I’m not finding where (although I could be overlooking it).
 TIA
  • Hi
    I'm a little late to the party. But I'm having issues with this example.
    I have followed all the steps and I have managed to upload the example. However, I don't see the bluetooth device on NRFConnect, so I've connected to the device via RTT (note that the same messages keep repeting, so I think something is not working and it is falling back to the bootloader):
    00> :INFO:Running nrf_bootloader_app_start with address: 0x0001b000
    00> :INFO:Disabling interrupts
    00> :INFO:Setting SD vector table base: 0x0001b000
    00> :INFO:Inside main
    00> :INFO:In nrf_bootloader_init
    00> :INFO:In real nrf_dfu_init
    00> :INFO:running nrf_dfu_settings_init
    00> :INFO:Enter nrf_dfu_continue
    00> :INFO:Valid App
    00> :INFO:Enter nrf_dfu_app_is_valid
    00> :INFO:Return true. App was valid
    00> :INFO:Jumping to: 0x0001b000
    00> :INFO:Valid App
    00> :INFO:Valid App
    00> :INFO:Valid App
    00> :INFO:Valid App
    00> :INFO:Valid App
    00> :INFO:Valid App
    00> :INFO:Valid App
    00> :INFO:Valid App
    00> :INFO:Valid App
    00> :INFO:Valid App
    00> :INFO:Valid App
    00> :INFO:Valid App
    00> :INFO:Valid App
    00> :INFO:Valid App
    00> :INFO:Valid App
    00> :INFO:Valid App
    Additionally I have uploaded the blinky_ble example. This one works flawlessly, I can control the LED ffrom the NRFConnect app. So I think this discards any problem with the bootloader or the SD.
    I agree, and I think that the log from the bootloader supports this theory. I think you need to check the (RTT) log from the ble_app_uart application. I guess that it is crashing somewhere. If the log doesn't give anything useful, you can try to debug. I just described how to debug when a bootloader is present in another post:
    https://devzone.nordicsemi.com/f/nordic-q-a/85223/merging-examples-with-dfu-cause-nrf_error_no_mem
    BR,
    Edvin
