nRF52840 SPI EasyDMA Double Buffering
I am trying to determine whether or not the SPI EasyDMA functionality of the nrf52840 supports double buffering in the sense that the DMA controller will switch buffers without intervention from the processor. In other words, can you start one DMA transfer and then immediately queue the next DMA transfer so that the following scenario happens:
Example:
255 Byte DMA buffer x 2
1. Start DMA transfer from buffer1 and immediately queue DMA transfer from buffer2.
2. Receive DMA transfer complete interrupt from buffer1. The DMA controller has already automatically switched to buffer2. Load buffer1 with new data and queue this transfer.
3. Receive DMA transfer complete interrupt from buffer2. The DMA controller has already automatically switched to buffer1. Load buffer2 with new data and queue this transfer.
4. etc...
I ask because I am using the SoftDevice while receiving ADC data over SPI sampled at 250 Hz and I want to make sure that if the DMA interrupt is delayed by any BLE activity that I do not miss a sample from my ADC's. If my understanding of this is correct, is there an example I can reference?
SoftDevice: S140
SDK: 15.0.0
Derek
  • I have spent a bit of time playing around with these examples and have gotten DMA transmit working with SPIM3 and HW chip select. Thanks for pointing that out, I didn't realize SPIM3 had this feature. However, I have run into a small problem and hopefully I am missing something here.
    My DAC SPI writes need to occur at specific intervals without CPU involvement indefinitely. So what I have done is set up a periodic timer to trigger each SPI transfer using PPI. I have set up a second timer to count the number of transfers using the SPI end event. This works great in that my SPI transmit ArrayList is iterated through as expected solely using PPI and timers. The problem arises when you want to reset the SPI transfer pointer back to the top of the ArrayList. How can this be done without CPU involvement?
    Unless I am missing something, this was my idea as a possible solution. Since the SPIM buffer pointers are double buffered, I was going to set up a third timer to count the number of SPI transfers -1 and interrupt the CPU. So while the last transfer is ongoing, the 3rd timer callback will set the SPI pointer back to the top, ie Channel.PTR = &MyArrayList;. Once the next SPI transfer begins, it will start back at the top. My only concern with this is that the system could stall due to other interrupts and not reset the pointer soon enough and overflow the buffer.
    Does this approach makes sense and seem feasible? Is there an easier way that I am missing to reset the pointer back to the top of the buffer? Just to reiterate, it is imperative that there is no noticeable delay in DAC writes when looping over this buffer.
    Edit: Not sure why I wasn't able to find this article before, but it appears that the ArrayList pointer cannot be reset without CPU involvement after-all: https://devzone.nordicsemi.com/f/nordic-q-a/23349/ringbuffer-spi-twi-tx-with-fixed-sample-rate . Hopefully my idea of using a third timer will work unless you have any other tricks or ideas?
    Thanks!
  • I think you have grasped the functionality of the SPIM peripherals and linked list EasyDMA, and I'm afraid that you cannot be 100% sure that you can update the buffer pointer in time since we need the CPU to write to the register and you only have the time it takes to send the last two bytes to do it.
    There is one thing I am curious about and that is if the TXD.PTR itself is incremented by the EasyDMA or if it is copied at the start of the SPI transaction. If it's the latter then the TXD.PTR should contain the pointer to the beginning of you buffer and you can immidiately trigger another transfer to start the process again. To verify this I suggest you halt the CPU when you have finished transfering your buffer and read the content of SPIM3's TXD.PTR register. If it contains the address of your buffer, then you should have a 100% glitch free communication with your DAC.
  • Just wanted to follow up on how I solved this issue. TXD.PTR is indeed incremented by the DMA controller.
    What I did to get around the fact that you can't reset the pointer without the CPU is added a 10 msec buffer "overhead" to my DAC ArrayList buffer. In other words, I duplicate my DAC waveform for an additional 10 msec beyond where I expect the transmit buffer to end. Once my interrupt fires to tell me that I have transmitted the entire "expected" buffer, I then check TXD.PTR to see how far beyond the expected buffer it went into the extra 10 msec buffer. I then move the pointer back to the start of the buffer plus the offset of (TXD.PTR - end of expected buffer). Worst case scenario I duplicate a single data-point of the waveform on the DAC. Testing with BLE enabled yields excellent results and I haven't had any issues yet.
    Thanks again for all of your help. Without it I wouldn't have resolved this issue.
  • Hello, I have a follow up question to this: How do you make sure that between the moment you read TXD.PTR and the moment you overwrite it the DMA did not update it?
    I was thinking that one could do active wait inside the interrupt for an EVENTS_STARTED and then change it right after, but I wonder if there is a way to make sure that such active poll is not interrupted by a higher-priority interrupt.
    Thank you
    That's a good point that I actually ran into later and opened another ticket for that was private due to code sharing.
    Here is an excerpt from that ticket. Basically, you have to disconnect the PPI channel between the timer and SPI peripheral, wait for any pending SPI transaction to complete, read the TX pointer, update it, and reconnect the PPI channel. I did however see delays doing this causing a few missed samples, so this is not a complete solution but a step in the right direction. The delay issue was never resolved but our DAC waveforms were such a low frequency that it didn't matter for that project. Perhaps Nordic can chime in further here but my guess is they would want you to open another ticket. If you do get an answer on how to resolve the delay issue that I am sure you will observe during your tests, I would be grateful if you could let me know.
    Thanks!
    Update: Step 2 and 3 (below) requires that you use the SPIM3 peripheral on the nRF52840. It is the only peripheral with hardware chip select.
    Excerpt:
    From a high level, here is my implementation which is what I want to discuss:
    1. Disconnect the PPI 32 usec timer from the SPI Start Task
    2. Determine if there is a SPI transaction currently in progress by checking if the CS (Chip select) pin is low. This is a hardware driven chip select hence why this works.
    3. If the Chip select pin is low, I set EVENTS_ENDTX to 0
    4. Wait until the EVENTS_ENDTX register is set to 1 by the DMA hardware
    5. Update the TX.PTR
    6. Reconnect the 32 usec timer to the SPI Start Task using PPI
    Now my concern is with step 2. I wasn't sure how else to determine if there is a SPI transaction in progress before setting EVENTS_ENDTX to 0 and polling for it to return to 1. The purpose of verifying if there is a SPI transaction in progress is because simply setting  EVENTS_ENDTX to 0 and waiting for it to return to 1 will not work if there was not a SPI transaction already in progress. You will end up waiting forever for it to return to 1 and it never will. And since the DMA controller only writes "1"s to these registers, I wasn't sure how else to check this.
