nRF52840 SPI EasyDMA Double Buffering
I am trying to determine whether or not the SPI EasyDMA functionality of the nrf52840 supports double buffering in the sense that the DMA controller will switch buffers without intervention from the processor. In other words, can you start one DMA transfer and then immediately queue the next DMA transfer so that the following scenario happens:
Example:
255 Byte DMA buffer x 2
1. Start DMA transfer from buffer1 and immediately queue DMA transfer from buffer2.
2. Receive DMA transfer complete interrupt from buffer1. The DMA controller has already automatically switched to buffer2. Load buffer1 with new data and queue this transfer.
3. Receive DMA transfer complete interrupt from buffer2. The DMA controller has already automatically switched to buffer1. Load buffer2 with new data and queue this transfer.
4. etc...
I ask because I am using the SoftDevice while receiving ADC data over SPI sampled at 250 Hz and I want to make sure that if the DMA interrupt is delayed by any BLE activity that I do not miss a sample from my ADC's. If my understanding of this is correct, is there an example I can reference?
SoftDevice: S140
SDK: 15.0.0
Derek
  • Hello I found my workaround for a true endless loop playback without skipped samples, it is somehow limited to my specific application but I figured it could maybe work for you too. Sorry for the long post.
    Let me describe the limitations of such approach:
    1) I will assume you must transmit 12 bit samples to a DAC in the form of 16bit words. We will call this word_length = 2. If you would transmit 24bit words we would have word_length = 3 and so on.
    2) Only works with sample rates that are SPI_FREQUENCY / (8 * (word_length + 1)) like for instance 83.333kHz with SPI_FREQUANCY = 2MHz and word_length = 2.
    3) Only works with DACs that can "ignore" bits that are transmitted after the nominal word length, before the chip select goes high again.
    4) requires 2 timer-counters
    5) requires (in my specific case) 4 PPI channels
    6) only works if the data you want to transfer is coming straight from another peripheral via DMA, like from an SPI flash.
    7) The maximum number of buffered samples (from now on buffer_length) is (255 - CMD) / (word_len + 1) where CMD is the number of bytes that must be transmitted to the external flash to start a transfer (usually 1 byte command and 3 byte address). For example, we could have max 83 sample buffer with word_length = 2 and CMD = 4.
    8) It only allows to cyclically play signals the length of which is an integer multiple of the chosen buffer size.
    Here is how it works (the big picture):
    1) we represent each signal sample with an extra dummy byte after the nominal word length (24 bits if you want to transmit 16bit words).
    2) we will assume that we have a word_length = 2, so we will imagine that we have already a full buffer of 83 samples on 16 + 8 bits in RAM. We will se later how we bring new data in the buffer without skipping samples
    3) we configure the output SPI0 to perform a DMA transfer of (buffer_length * (word_length + 1) - 1) bytes at a certain frequency (say 2MHz), WITHOUT  POST-INCREMENT and we hold the transfer. Notice that the size of the transfer is the buffer size in bytes minus one, more on this at point 8). When started SPI0-DMA will transfer the whole buffer byte by byte without distinction and, at the end, it will reset the start address of the DMA to the beginning of the buffer without CPU intervention.
    4) we set up TIMER1 @ 16MHz with cyclic COMPARE0_CLEAR mode with the same exact period as the SPI word-transfer, in our case period = (16MHz / SPI0_FREQUENCY) * 8 * (word_length + 1) = 192. When the TIMER1 is started, its cycle will be synchronous with the SPI transfers. The phase alignment must be figured out empyrically (measure with a scope) but it is deterministic and repeatable.
    5) we set up two intermediate compares for TIMER1 and we connect them through PPI to a GPIOTE that will serve as chip-select. When the timer is running, a chip select pulse will be generated once every word_length + 1 bytes, so synchronous with the SPI word transfer. The correct phase and length of such pulse shall be found empyrically so that the chip-select pulse occurs while the "dummy" byte of each word is being transmitted, and the chip-select must fall right before the first bit of the new transfer. It is tricky to set up but it is deterministic and repeatable.
    6) we set up a TIMER2 as counter connected to TIMER1 COMPARE0 event through PPI. This counter will count the number of samples that were transmitted. We set up COMPARE0 of TIMER2 with counter value equal to 84 (buffer_length).
    7) We connect COMPARE0 of TIMER2 to SPI0 START_TASK and we also short it to the CLEAR task of TIMER2. A whole buffer transfer via SPI0-DMA will be triggered every period of TIMER2 (buffer_length) which is EXACTLY the time it takes for the SPI0 to transfer our data buffer.
    8) The last byte that we left off from the SPI0 transfer (point 3) acts as a clearance interval that allows the DMA to reach a full STOP before it is triggered again. Anyway the last byte was a dummy byte so it is ok not to transfer it. So now we see that this extra dummy byte serves a double purpose: it allows some "dead" time between consecutive output words so that we can pulse the chip-select and mark the end of a word and the beginning of the next one, and also allows the SPI0 DMA to stop before it is triggered again.
    At this point we have an endless playback of the 84 sample (buffer_length) buffer content without any CPU intervention. Now we will see how we can actually bring new data to such buffer without skipping a sample.
    9) we assume that most SPI flash memories can be read consecutively with a read-write operation. First, CMD bytes are transmitted to the flash, containing the command and the data address, the data will immediately start streaming out the flash at every following byte transfer. See for example W25Q16JV flash read protocol.
    10) when we allocate the buffer for our output data, we make sure to allocate CMD additional bytes on top of the necessary buffer size for the signal. We MUST allocate these extra bytes BEFORE the beginning of the actual data. This can be achieved by allocating the desired ((buffer_length * (word_length + 1) + CMD) bytes and then configuring the SPI0 DMA transfer to start CMD bytes after the beginning of the buffer.
    11) we set up SPI1 at the maximum frequency that our flash and our system will allow, say 8MHz. We set up a read-write SPI1-DMA transfer WITHOUT POST INCREMENT, starting at the beginning of the buffer and we hold it. The size of such transfer will be ((buffer_length * (word_length + 1) + CMD) bytes as opposed to the output SPI0 that only transfers the (buffer_length * (word_length + 1) - 1)  bytes after the first CMD bytes of the allocated buffer.
    12) we write the necessary read command and the desired  flash address into the first CMD bytes of the buffer (again, there extra bytes must be just before the "data space"
    13) we set up an additional CPMPARE1 for TIMER2 at a counter value that is very close to the end of the buffer, like buffer_length - 2 for instance. We connect COMPARE1 of TIMER2 to SPI1 START_TASK through PPI. Now every time the OUTPUT DMA has almost finished reading the buffer, a new chunk of data will be transferred from flash to the buffer via SPI1. By the time the OUTPUT DMA wraps around and reads the first buffer samples again, new samples will have been written already. By the time the INPUT DMA writes to the end of the buffer, the input DMA will have already wrapped around. So there are no read-write conflicts anywhere.
    The input SPI1 performs a read-write operation. Technically the entire OLD buffer content is transferred TO the flash while the NEW buffer content is being transferred FROM the flash. This is ok because the flash will ignore all bytes transferred TO it except for the first CMD bytes that contain read command and address. This strategy allows to transfer the read command and address TO the flash and read back the data FROM the flash with a single, continuous DMA transfer.
    Note that with such transfer, the first CMD bytes are also overwritten (with zeros most likely) and will have to be manually re-written and updated. This is the only point where the CPU comes in, the rest is all done in hardware. However this is not a problem because the CPU has a very long time (83 samples @ 83.333kHz ~ 1ms) to perform this task within an interrupt
    14) we enable TIMER2 COMPARE0 interrupts. The interrupt handler will add the buffersize in bytes = (buffer_length * (word_length + 1)) to the flash read address, or reset it if the end of the signal has been reached, and will write the flash read command and updated address to the first CMD bytes of the buffer, ready for the next transfer that will be triggered by hardware (TIMER2 COMPARE1).
    Note that this operation (overwriting the CMD bytes) can be done safely right after the input SPI1 transfer has started and has transferred the first CMD bytes. This allows the maximum time for the interrupt to be handled.
    I have tested this for hours with several buffer lengths. with anything above 50 samples I have continuous playback without skipping samples.
  • Thanks for the update! I am working on a new project using DMA so I may be able to leverage some of your technique.
    Derek
