Characteristic permissions are not being enforced correctly
I encountered a weird behavior. i defined characteristics with specific read/write permission however all the characteristics are writable for some reason altough the permissions are sent correctly.
I have noticed it on a BT dongle from Texas Instruments. in which i can see the right permissions but even if a characteristic is read only i can still write to it.
you can see the permissions in the following snippet:
permissions
the value is changed with a write process
the packets sent are:
in other devices i have worked on a characteristic would deny a write sequence if no write permissions are set.
please let me know what is required in order to solve this.
    Please make sure you configure your characteristic correctly. As you probably know this is done using sd_ble_gatts_characteristic_add. Make sure you do configure both char_md and attr_md, and that you memset these before you configure them.
    Example for Hear rate characteristic:
    /**@brief Function for adding the Heart Rate Measurement characteristic.
     * @param[in]   p_hrs        Heart Rate Service structure.
     * @param[in]   p_hrs_init   Information needed to initialize the service.
     * @return      NRF_SUCCESS on success, otherwise an error code.
    static uint32_t heart_rate_measurement_char_add(ble_hrs_t            * p_hrs,
                                                    const ble_hrs_init_t * p_hrs_init)
        ble_gatts_char_md_t char_md;
        ble_gatts_attr_md_t cccd_md;
        ble_gatts_attr_t    attr_char_value;
        ble_uuid_t          ble_uuid;
        ble_gatts_attr_md_t attr_md;
        uint8_t             encoded_initial_hrm[MAX_HRM_LEN];
        memset(&cccd_md, 0, sizeof(cccd_md));
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
        cccd_md.write_perm = p_hrs_init->hrs_hrm_attr_md.cccd_write_perm;
        cccd_md.vloc       = BLE_GATTS_VLOC_STACK;
        memset(&char_md, 0, sizeof(char_md));
        char_md.char_props.notify = 1;
        char_md.p_char_user_desc  = NULL;
        char_md.p_char_pf         = NULL;
        char_md.p_user_desc_md    = NULL;
        char_md.p_cccd_md         = &cccd_md;
        char_md.p_sccd_md         = NULL;
        BLE_UUID_BLE_ASSIGN(ble_uuid, BLE_UUID_HEART_RATE_MEASUREMENT_CHAR);
        memset(&attr_md, 0, sizeof(attr_md));
        attr_md.read_perm  = p_hrs_init->hrs_hrm_attr_md.read_perm;
        attr_md.write_perm = p_hrs_init->hrs_hrm_attr_md.write_perm;
        attr_md.vloc       = BLE_GATTS_VLOC_STACK;
        attr_md.rd_auth    = 0;
        attr_md.wr_auth    = 0;
        attr_md.vlen       = 1;
        memset(&attr_char_value, 0, sizeof(attr_char_value));
        attr_char_value.p_uuid    = &ble_uuid;
        attr_char_value.p_attr_md = &attr_md;
        attr_char_value.init_len  = hrm_encode(p_hrs, INITIAL_VALUE_HRM, encoded_initial_hrm);
        attr_char_value.init_offs = 0;
        attr_char_value.max_len   = MAX_HRM_LEN;
        attr_char_value.p_value   = encoded_initial_hrm;
        return sd_ble_gatts_characteristic_add(p_hrs->service_handle,
                                               &char_md,
                                               &attr_char_value,
                                               &p_hrs->hrm_handles);
