nRF52 receiving data from 24L01 incorrectly
I am using a 24L01+(as PTX) communicating with a nrf52832(as PRX).
I can have these two device communicating, where nrf52832 can receive data from 24L01+.
However, the data nrf52832 received is not the exactly same as the data 24L01+ has transmitted. For example, the 24L01+ is transmitting a 3-byte data(e.g. 0x123456) to nRF52832, while the data nRF52832 received is 0x2468AC. As you can see, 0x2468AC = 0x123456 <- 1. However, in another test, the 24L01+ transmitted 0x676767, while the nRF52832 received 0xCECECF.
Any suggestion would be appreciated.
Best regards!
    It sounds like you have configured the radio incorrectly, especially the endianess of the nrf52 radio (see PCNF1 register)
    Have you tried using nrf_esb library for nRF52 to see if that works better?
    Håkon
  • Thanks for your suggestion.
    The program running on the nRF52832 was modified from the nRF52 SDK 15.0.0 esb_prx example. It uses the nrf_esb library to recieve data.
    A part of my code which config the esb is as follows.
    uint32_t esb_init( void )
        uint32_t err_code;
        uint8_t base_addr_0[3] = {0xE7, 0xE7, 0xE7};
        uint8_t base_addr_1[3] = {0xC2, 0xC2, 0xC2};
        uint8_t addr_prefix[2] = {0xE7, 0xC2};
        nrf_esb_config_t nrf_esb_config         = NRF_ESB_LEGACY_CONFIG;
        nrf_esb_config.payload_length           = 3;
        nrf_esb_config.crc 	                	= NRF_ESB_CRC_8BIT;
        nrf_esb_config.protocol                 = NRF_ESB_PROTOCOL_ESB;
        nrf_esb_config.bitrate                  = NRF_ESB_BITRATE_2MBPS;
        nrf_esb_config.mode                     = NRF_ESB_MODE_PRX;
        nrf_esb_config.event_handler            = nrf_esb_event_handler;
        nrf_esb_config.selective_auto_ack       = false;
        err_code = nrf_esb_init(&nrf_esb_config);
        VERIFY_SUCCESS(err_code);
        err_code = nrf_esb_set_rf_channel(73);
        err_code = nrf_esb_set_address_length(4);
        err_code = nrf_esb_set_base_address_0(base_addr_0);
        err_code = nrf_esb_set_base_address_1(base_addr_1);
        err_code = nrf_esb_set_prefixes(addr_prefix, 2);
        return err_code;
    I don't know where I should modify my code.
    Thanks
  • That is strange. Looking at the bit stream, it seems that your data is shifted one bit (0x676767 << 1 becomes 0xCECECF).
    Do you have several nRF24L01+ modules, and they all behave like this? Do you have a link to where you obtained them?
    Håkon
  • I have several 24L01+ modules and they can work well with each other. Also I have several nRF52832 modules and they work well too.
    Since 24L01+ can receive data correctly from 24L01+, the 24L01+ may not have problem and so does nRF52832. It is so strange.
  • Are you sending ESB-packets from the nRF24L01+, or are you using the older "shockburst" packet format?
    Could you post the nRF24L01+ configuration that you are using? A register dump would suffice.
    Cheers,
    Håkon
