LSM6DSL problem to start via i2c
Hello!
I have a custom pcb with Lsm6dsl connect to nrf52832 via i2c.
I can write and read regs of Lsm6dsl well ( reg "who_am_I" return 0x6a as describe in datasheet ).
The problem appears when I try to write "ODR" (output data rate) bits in CTRL1_XL (10h) reg (for example 0x10). This bits must turn on an accelerometer. After the transaction, I can no longer access  Lsm6ds because it always return NRF_DRV_TWI_EVT_ADDRESS_NACK.. like there is no i2c slave on this address.
If I write other bits in CTRL1_XL (10h) reg that do not enable accelerometer (for example 0x0f) it work OK.
Can anybody help me, what it is the problem?
Here is programm code:
static const nrf_drv_twi_t m_twi_lsm6dsl = NRF_DRV_TWI_INSTANCE(0);
uint8_t address_acc = 0x6aU;
uint8_t reg_odr_sys_on[2] = {0x10U, 0x10U};
uint8_t who_am_i_buffer = 0;
uint8_t reg_who_am_i_buffer_read[1] = {0x0fU};
* @brief TWI events handler.
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
    ret_code_t err_code;
    switch(p_event->type)
         case NRF_DRV_TWI_EVT_DONE:
         case NRF_DRV_TWI_EVT_ADDRESS_NACK:
         case NRF_DRV_TWI_EVT_DATA_NACK:
* @brief twi initialization.
void twi_init (void)
    const nrf_drv_twi_config_t twi_lsm6dsl_config = {
    .scl = 06,
    .sda = 07,
    .frequency = NRF_TWI_FREQ_100K,
    .interrupt_priority = APP_IRQ_PRIORITY_LOW
    err_code = nrf_drv_twi_init(&m_twi_lsm6dsl, &twi_lsm6dsl_config, twi_handler, NULL);
    nrf_drv_twi_enable(&m_twi_lsm6dsl);
    twi_init();
    err_code = nrf_drv_twi_tx(&m_twi_lsm6dsl, address_acc, reg_who_am_i_buffer_read, sizeof(reg_who_am_i_buffer_read), false);
    nrf_delay_ms(100);
    err_code = nrf_drv_twi_rx(&m_twi_lsm6dsl, address_acc, &who_am_i_buffer, sizeof(who_am_i_buffer));
    nrf_delay_ms(100);
    err_code = nrf_drv_twi_tx(&m_twi_lsm6dsl, address_acc, reg_odr_sys_on, sizeof(reg_odr_sys_on), false);
    nrf_delay_ms(100);
    while(true)
  • Do you have a logic analyzer that you can use to capture what goes on on the bus?
    What happens if you remove the code reading from the who am I registers? The LSM6DSL's datasheet states that you need a repeated start condition between TX and RX operations and you don't have that. I'm not sure it if it is related though, and it is i odd that a read operation would work, but not subsequent write operations.
    To use repeated start, please use:
    nrf_drv_twi_tx(..., ..., ..., ..., true);
    before
    nrf_drv_twi_rx(..., ..., ..., ...);
  • Hi!
    Thanks for reply!
    Today I discovered a problem. I have two different power supply net on nrf52832 and LSM6DSL (with common ground) on my custom board. After connecting to one common power supply net,  programm  code work good.
