pc_ble_driver_py.exceptions.NordicSemiException: No ping response after opening COM port
I was trying to run dfu mesh example according to this. I attempted quite few times but every time having an error at step 11.
infocenter.nordicsemi.com/index.jsp
Here is my environment details:
OS: windows 10
nrfutil version: 3.5.1
mesh SDK: Mesh_v2.1.1_src
Board : nrf52832
SDK version: 15
SoftDeive s132_6.0.0
step 1: Creating my own private key
 nrfutil.exe keys generate private.pem
Step2: Generated respective public key in hex format
nrfutil.exe keys display --key pk format code .\private.pem --out_file dfu_public_key.c
step 3: Added this key in the end of  "bootloader_config_default.json" file.
Step 4: Creating own signed image  package for dfu
nrfutil.exe pkg generate --hw-version 52 --application-version 4 --sd-req 0x00A8 --application C:\nordic_semi\nrf5_SDK_for_Mesh_v2.
1.1\bin\blinky\blinky_nrf52832_xxAA_s132_6.0.0.hex --key-file .\private.pem secure_dfu_mesh.zip
Step 5:  Generating device page with provided script as follow
python .\device_page_generator.py  -d nrf52832_xxAA -sd "s132_6.0.0"
Step 6:  flashing soft device:
nrfjprog --program C:\nordic_semi\nrf5_SDK_for_Mesh_v2.1.1\bin\softdevice\s132_nrf52_6.0.0_softdevice.hex --chiperase
step 7: Flash the serial bootloader on all devices:
nrfjprog --program C:\nordic_semi\nrf5_SDK_for_Mesh_v2.1.1\bin\bootloader\gccarmemb\mesh_bootloader_serial_gccarmemb_nrf52832_xxAA.hex
step 8: flashing application:
nrfjprog --program C:\nordic_semi\nrf5_SDK_for_Mesh_v2.1.1\examples\dfu\build\dfu_nrf52832_xxAA_s132_6.0.0_Debug\dfu_nrf52832_xxAA_s13
2_6.0.0.hex
Step 9: Flashing device page:
nrfjprog --program C:\nordic_semi\nrf5_SDK_for_Mesh_v2.1.1\tools\dfu\bin\device_page_nrf52832_xxAA_s132_6.0.0.hex
Step 10: Resetting
nrfjprog --reset
Step 11: Problematic one(Transfer the DFU archive over serial with nrfutil)
 nrfutil.exe dfu serial -pkg .\secure_dfu_mesh.zip -p COM15 -b 1200
 I have problem only on step 11
  • Hi.
    Could you check our which version of nrfutil you are using?
    Just run "nrfutil.exe version" in cmd.
    The dfu quick start guide requires the version 0.3.0.0, which is found in this GitHub link.
    - Andreas
  • version is 3.5.1, so i am thinking that i used wrong version. Now my question is how can i use the version you mentioned.
    Thanks for your reply
  • 1) C:\Python27\;C:\Python27\Scripts;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;"C:\Python27 ; C:\Program Files (x86)\GnuWin32\bin\make";C:\Python27\Scripts;C:\ProgramData\Oracle\Java\javapath;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\nodejs\;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;"C:\Program Files (x86)\Skype\Phone\;C:\Python27;C:\Program Files\PuTTY\;C:\WINDOWS\System32\OpenSSH\;%PYTHON_HOME%";C:\Program Files (x86)\Nordic Semiconductor\nrf5x\bin\;C:\Program Files\CMake\bin;"C:\Users\Shohidur\AppData\Local\Microsoft\WindowsApps;C:\Users\Shohidur\AppData\Roaming\npm;C:\Users\Shohidur\AppData\Local\Microsoft\WindowsApps;C:\Program Files\CMake\bin;C:\Python27\
    2) where nrfutilmesh ( I guess your "which" was a typo for "where")
    C:\Python27\Scripts\nrfutilmesh.exe
  • I have attached here all the commands and their output as text file. Please have a look on that.
    Command to install nrfutil lastest version: PS C:\> pip install nrfutil
    ======out put =======
    Collecting nrfutil
      Using cached https://files.pythonhosted.org/packages/ed/b8/82cc0cbff17b7b3ce433afbe9319a5cf525645363cb3a426c31cf1fba2b9/nrfutil-3.5.1.tar.gz
    Collecting six>=1.9 (from nrfutil)
      Using cached https://files.pythonhosted.org/packages/67/4b/141a581104b1f6397bfa78ac9d43d8ad29a7ca43ea90a2d863fe3056e86a/six-1.11.0-py2.py3-none-any.whl
    Collecting pyserial>=2.7 (from nrfutil)
      Using cached https://files.pythonhosted.org/packages/0d/e4/2a744dd9e3be04a0c0907414e2a01a7c88bb3915cbe3c8cc06e209f59c30/pyserial-3.4-py2.py3-none-any.whl
    Collecting enum34>=1.0.4 (from nrfutil)
      Using cached https://files.pythonhosted.org/packages/c5/db/e56e6b4bbac7c4a06de1c50de6fe1ef3810018ae11732a50f15f62c7d050/enum34-1.1.6-py2-none-any.whl
    Collecting click>=6.0 (from nrfutil)
      Using cached https://files.pythonhosted.org/packages/34/c1/8806f99713ddb993c5366c362b2f908f18269f8d792aff1abfd700775a77/click-6.7-py2.py3-none-any.whl
    Collecting ecdsa>=0.13 (from nrfutil)
      Using cached https://files.pythonhosted.org/packages/63/f4/73669d51825516ce8c43b816c0a6b64cd6eb71d08b99820c00792cb42222/ecdsa-0.13-py2.py3-none-any.whl
    Collecting behave (from nrfutil)
      Using cached https://files.pythonhosted.org/packages/a8/6c/ec9169548b6c4cb877aaa6773408ca08ae2a282805b958dbc163cb19822d/behave-1.2.6-py2.py3-none-any.whl
    Collecting protobuf (from nrfutil)
      Using cached https://files.pythonhosted.org/packages/77/78/a7f1ce761e2c738e209857175cd4f90a8562d1bde32868a8cd5290d58926/protobuf-3.6.1-py2.py3-none-any.whl
    Collecting pc_ble_driver_py>=0.11.3 (from nrfutil)
      Using cached https://files.pythonhosted.org/packages/4b/96/58f61140b86ef288636ec93db234a37f1e9fe21e9ada2e38dc2914105458/pc_ble_driver_py-0.11.3.tar.gz
    Collecting tqdm (from nrfutil)
      Using cached https://files.pythonhosted.org/packages/c7/e0/52b2faaef4fd87f86eb8a8f1afa2cd6eb11146822033e29c04ac48ada32c/tqdm-4.25.0-py2.py3-none-any.whl
    Collecting piccata (from nrfutil)
      Using cached https://files.pythonhosted.org/packages/d0/29/d2a321338a04da7d371c79abe4dbb1b8b1ed381728227621a3a4a156439a/piccata-1.0.1.tar.gz
    Collecting pyspinel==1.0.0a1 (from nrfutil)
      Using cached https://files.pythonhosted.org/packages/71/1f/0c3d64ce4fe546173da2452e895671668d85cee83d01a025e07f5cd46a13/pyspinel-1.0.0a1.tar.gz
    Collecting parse>=1.8.2 (from behave->nrfutil)
      Using cached https://files.pythonhosted.org/packages/79/e1/522401e2cb06d09497f2f56baa3b902116c97dec6f448d02b730e63b44a8/parse-1.8.4.tar.gz
    Collecting parse-type>=0.4.2 (from behave->nrfutil)
      Using cached https://files.pythonhosted.org/packages/a2/c9/e6fd8092a5a06f2519ec434ca8e9e42238384f64c9b659456d98b0593b89/parse_type-0.4.2-py2.py3-none-any.whl
    Collecting traceback2; python_version < "3.0" (from behave->nrfutil)
      Using cached https://files.pythonhosted.org/packages/17/0a/6ac05a3723017a967193456a2efa0aa9ac4b51456891af1e2353bb9de21e/traceback2-1.4.0-py2.py3-none-any.whl
    Requirement already satisfied: setuptools in c:\python27\lib\site-packages (from protobuf->nrfutil)
    Collecting wrapt (from pc_ble_driver_py>=0.11.3->nrfutil)
      Using cached https://files.pythonhosted.org/packages/a0/47/66897906448185fcb77fc3c2b1bc20ed0ecca81a0f2f88eda3fc5a34fc3d/wrapt-1.10.11.tar.gz
    Collecting future (from pc_ble_driver_py>=0.11.3->nrfutil)
      Using cached https://files.pythonhosted.org/packages/00/2b/8d082ddfed935f3608cc61140df6dcbf0edea1bc3ab52fb6c29ae3e81e85/future-0.16.0.tar.gz
    Collecting ipaddress (from piccata->nrfutil)
      Using cached https://files.pythonhosted.org/packages/fc/d0/7fc3a811e011d4b388be48a0e381db8d990042df54aa4ef4599a31d39853/ipaddress-1.0.22-py2.py3-none-any.whl
    Collecting linecache2 (from traceback2; python_version < "3.0"->behave->nrfutil)
      Using cached https://files.pythonhosted.org/packages/c7/a3/c5da2a44c85bfbb6eebcfc1dde24933f8704441b98fdde6528f4831757a6/linecache2-1.0.0-py2.py3-none-any.whl
    Installing collected packages: six, pyserial, enum34, click, ecdsa, parse, parse-type, linecache2, traceback2, behave, protobuf, wrapt, future, pc-ble-driver-py, tqdm, ipaddress, piccata, pyspinel, nrfutil
      Running setup.py install for parse ... done
      Running setup.py install for wrapt ... done
      Running setup.py install for future ... done
      Running setup.py install for pc-ble-driver-py ... done
      Running setup.py install for piccata ... done
      Running setup.py install for pyspinel ... done
      Running setup.py install for nrfutil ... done
    Successfully installed behave-1.2.6 click-6.7 ecdsa-0.13 enum34-1.1.6 future-0.16.0 ipaddress-1.0.22 linecache2-1.0.0 nrfutil-3.5.1 parse-1.8.4 parse-type-0.4.2 pc-ble-driver-py-0.11.3 piccata-1.0.1 protobuf-3.6.1 pyserial-3.4 pyspinel-1.0.0a1 six-1.11.0 tqdm-4.25.0 traceback2-1.4.0 wrapt-1.10.11
    You are using pip version 9.0.1, however version 18.0 is available.
    You should consider upgrading via the 'python -m pip install --upgrade pip' command.
    Command to upgrade pip: PS C:\> python -m pip install --upgrade pip
    ======out put==================
    Collecting pip
      Using cached https://files.pythonhosted.org/packages/5f/25/e52d3f31441505a5f3af41213346e5b6c221c9e086a166f3703d2ddaf940/pip-18.0-py2.py3-none-any.whl
    Installing collected packages: pip
      Found existing installation: pip 9.0.1
        Uninstalling pip-9.0.1:
          Successfully uninstalled pip-9.0.1
    Successfully installed pip-18.0
    Command for pre-requisite: PS C:\> pip install -U setuptools
    Collecting setuptools
      Using cached https://files.pythonhosted.org/packages/66/e8/570bb5ca88a8bcd2a1db9c6246bb66615750663ffaaeada95b04ffe74e12/setuptools-40.2.0-py2.py3-none-any.whl
    Installing collected packages: setuptools
      Found existing installation: setuptools 28.8.0
        Uninstalling setuptools-28.8.0:
          Successfully uninstalled setuptools-28.8.0
    Successfully installed setuptools-40.2.0
    Command for prerequisite: PS C:\> pip install -r requirements.txt
    =====output====
    Requirement already satisfied: six>=1.9 in c:\python27\lib\site-packages (from -r requirements.txt (line 1)) (1.11.0)
    Requirement already satisfied: pyserial>=2.7 in c:\python27\lib\site-packages (from -r requirements.txt (line 2)) (3.4)
    Requirement already satisfied: enum34>=1.0.4 in c:\python27\lib\site-packages (from -r requirements.txt (line 3)) (1.1.6)
    Requirement already satisfied: click>=6.0 in c:\python27\lib\site-packages (from -r requirements.txt (line 4)) (6.7)
    Requirement already satisfied: ecdsa>=0.13 in c:\python27\lib\site-packages (from -r requirements.txt (line 5)) (0.13)
    Requirement already satisfied: behave in c:\python27\lib\site-packages (from -r requirements.txt (line 6)) (1.2.6)
    Requirement already satisfied: protobuf in c:\python27\lib\site-packages (from -r requirements.txt (line 7)) (3.6.1)
    Requirement already satisfied: pc_ble_driver_py>=0.11.3 in c:\python27\lib\site-packages (from -r requirements.txt (line 8)) (0.11.3)
    Requirement already satisfied: tqdm in c:\python27\lib\site-packages (from -r requirements.txt (line 9)) (4.25.0)
    Requirement already satisfied: piccata in c:\python27\lib\site-packages (from -r requirements.txt (line 10)) (1.0.1)
    Requirement already satisfied: pyspinel==1.0.0a1 in c:\python27\lib\site-packages (from -r requirements.txt (line 11)) (1.0.0a1)
    Requirement already satisfied: parse>=1.8.2 in c:\python27\lib\site-packages (from behave->-r requirements.txt (line 6)) (1.8.4)
    Requirement already satisfied: parse-type>=0.4.2 in c:\python27\lib\site-packages (from behave->-r requirements.txt (line 6)) (0.4.2)
    Requirement already satisfied: traceback2; python_version < "3.0" in c:\python27\lib\site-packages (from behave->-r requirements.txt (line 6)) (1.4.0)
    Requirement already satisfied: setuptools in c:\python27\lib\site-packages (from protobuf->-r requirements.txt (line 7)) (40.2.0)
    Requirement already satisfied: wrapt in c:\python27\lib\site-packages (from pc_ble_driver_py>=0.11.3->-r requirements.txt (line 8)) (1.10.11)
    Requirement already satisfied: future in c:\python27\lib\site-packages (from pc_ble_driver_py>=0.11.3->-r requirements.txt (line 8)) (0.16.0)
    Requirement already satisfied: ipaddress in c:\python27\lib\site-packages (from piccata->-r requirements.txt (line 10)) (1.0.22)
    Requirement already satisfied: linecache2 in c:\python27\lib\site-packages (from traceback2; python_version < "3.0"->behave->-r requirements.txt (line 6)) (1.0.0)
    Command for pre-requisite: PS C:\> pip install http://sourceforge.net/projects/py2exe/files/latest/download?source=files
    Collecting http://sourceforge.net/projects/py2exe/files/latest/download?source=files
      Using cached http://sourceforge.net/projects/py2exe/files/latest/download?source=files
    Installing collected packages: py2exe
      Running setup.py install for py2exe ... done
    Successfully installed py2exe-0.6.9
    Installing mesh nrfutil: PS C:\Python27\pc-nrfutil-0.3.0> python setup.py install
    ====================out put===============
    running install
    running bdist_egg
    running egg_info
    creating nrfutil.egg-info
    writing nrfutil.egg-info\PKG-INFO
    writing top-level names to nrfutil.egg-info\top_level.txt
    writing dependency_links to nrfutil.egg-info\dependency_links.txt
    writing entry points to nrfutil.egg-info\entry_points.txt
    writing manifest file 'nrfutil.egg-info\SOURCES.txt'
    reading manifest file 'nrfutil.egg-info\SOURCES.txt'
    installing library code to build\bdist.win32\egg
    running install_lib
    running build_py
    creating build
    creating build\lib
    creating build\lib\nordicsemi
    copying nordicsemi\exceptions.py -> build\lib\nordicsemi
    copying nordicsemi\version.py -> build\lib\nordicsemi
    copying nordicsemi\__init__.py -> build\lib\nordicsemi
    copying nordicsemi\__main__.py -> build\lib\nordicsemi
    creating build\lib\nordicsemi\bluetooth
    copying nordicsemi\bluetooth\__init__.py -> build\lib\nordicsemi\bluetooth
    creating build\lib\nordicsemi\dfu
    copying nordicsemi\dfu\crc16.py -> build\lib\nordicsemi\dfu
    copying nordicsemi\dfu\dfu.py -> build\lib\nordicsemi\dfu
    copying nordicsemi\dfu\dfu_transport.py -> build\lib\nordicsemi\dfu
    copying nordicsemi\dfu\dfu_transport_ble.py -> build\lib\nordicsemi\dfu
    copying nordicsemi\dfu\dfu_transport_serial.py -> build\lib\nordicsemi\dfu
    copying nordicsemi\dfu\init_packet.py -> build\lib\nordicsemi\dfu
    copying nordicsemi\dfu\manifest.py -> build\lib\nordicsemi\dfu
    copying nordicsemi\dfu\model.py -> build\lib\nordicsemi\dfu
    copying nordicsemi\dfu\nrfhex.py -> build\lib\nordicsemi\dfu
    copying nordicsemi\dfu\package.py -> build\lib\nordicsemi\dfu
    copying nordicsemi\dfu\signing.py -> build\lib\nordicsemi\dfu
    copying nordicsemi\dfu\util.py -> build\lib\nordicsemi\dfu
    copying nordicsemi\dfu\__init__.py -> build\lib\nordicsemi\dfu
    creating build\lib\nordicsemi\utility
    copying nordicsemi\utility\target_registry.py -> build\lib\nordicsemi\utility
    copying nordicsemi\utility\__init__.py -> build\lib\nordicsemi\utility
    creating build\lib\nordicsemi\bluetooth\hci
    copying nordicsemi\bluetooth\hci\codec.py -> build\lib\nordicsemi\bluetooth\hci
    copying nordicsemi\bluetooth\hci\slip.py -> build\lib\nordicsemi\bluetooth\hci
    copying nordicsemi\bluetooth\hci\__init__.py -> build\lib\nordicsemi\bluetooth\hci
    creating build\lib\nordicsemi\bluetooth\hci\tests
    copying nordicsemi\bluetooth\hci\tests\test_codec.py -> build\lib\nordicsemi\bluetooth\hci\tests
    copying nordicsemi\bluetooth\hci\tests\__init__.py -> build\lib\nordicsemi\bluetooth\hci\tests
    creating build\lib\nordicsemi\dfu\intelhex
    copying nordicsemi\dfu\intelhex\compat.py -> build\lib\nordicsemi\dfu\intelhex
    copying nordicsemi\dfu\intelhex\__init__.py -> build\lib\nordicsemi\dfu\intelhex
    creating build\lib\nordicsemi\dfu\tests
    copying nordicsemi\dfu\tests\test_dfu_transport_serial.py -> build\lib\nordicsemi\dfu\tests
    copying nordicsemi\dfu\tests\test_init_packet.py -> build\lib\nordicsemi\dfu\tests
    copying nordicsemi\dfu\tests\test_manifest.py -> build\lib\nordicsemi\dfu\tests
    copying nordicsemi\dfu\tests\test_nrfhex.py -> build\lib\nordicsemi\dfu\tests
    copying nordicsemi\dfu\tests\test_package.py -> build\lib\nordicsemi\dfu\tests
    copying nordicsemi\dfu\tests\test_signing.py -> build\lib\nordicsemi\dfu\tests
    copying nordicsemi\dfu\tests\__init__.py -> build\lib\nordicsemi\dfu\tests
    creating build\lib\nordicsemi\utility\tests
    copying nordicsemi\utility\tests\test_target_registry.py -> build\lib\nordicsemi\utility\tests
    copying nordicsemi\utility\tests\__init__.py -> build\lib\nordicsemi\utility\tests
    creating build\bdist.win32
    creating build\bdist.win32\egg
    creating build\bdist.win32\egg\nordicsemi
    creating build\bdist.win32\egg\nordicsemi\bluetooth
    creating build\bdist.win32\egg\nordicsemi\bluetooth\hci
    copying build\lib\nordicsemi\bluetooth\hci\codec.py -> build\bdist.win32\egg\nordicsemi\bluetooth\hci
    copying build\lib\nordicsemi\bluetooth\hci\slip.py -> build\bdist.win32\egg\nordicsemi\bluetooth\hci
    creating build\bdist.win32\egg\nordicsemi\bluetooth\hci\tests
    copying build\lib\nordicsemi\bluetooth\hci\tests\test_codec.py -> build\bdist.win32\egg\nordicsemi\bluetooth\hci\tests
    copying build\lib\nordicsemi\bluetooth\hci\tests\__init__.py -> build\bdist.win32\egg\nordicsemi\bluetooth\hci\tests
    copying build\lib\nordicsemi\bluetooth\hci\__init__.py -> build\bdist.win32\egg\nordicsemi\bluetooth\hci
    copying build\lib\nordicsemi\bluetooth\__init__.py -> build\bdist.win32\egg\nordicsemi\bluetooth
    creating build\bdist.win32\egg\nordicsemi\dfu
    copying build\lib\nordicsemi\dfu\crc16.py -> build\bdist.win32\egg\nordicsemi\dfu
    copying build\lib\nordicsemi\dfu\dfu.py -> build\bdist.win32\egg\nordicsemi\dfu
    copying build\lib\nordicsemi\dfu\dfu_transport.py -> build\bdist.win32\egg\nordicsemi\dfu
    copying build\lib\nordicsemi\dfu\dfu_transport_ble.py -> build\bdist.win32\egg\nordicsemi\dfu
    copying build\lib\nordicsemi\dfu\dfu_transport_serial.py -> build\bdist.win32\egg\nordicsemi\dfu
    copying build\lib\nordicsemi\dfu\init_packet.py -> build\bdist.win32\egg\nordicsemi\dfu
    creating build\bdist.win32\egg\nordicsemi\dfu\intelhex
    copying build\lib\nordicsemi\dfu\intelhex\compat.py -> build\bdist.win32\egg\nordicsemi\dfu\intelhex
    copying build\lib\nordicsemi\dfu\intelhex\__init__.py -> build\bdist.win32\egg\nordicsemi\dfu\intelhex
    copying build\lib\nordicsemi\dfu\manifest.py -> build\bdist.win32\egg\nordicsemi\dfu
    copying build\lib\nordicsemi\dfu\model.py -> build\bdist.win32\egg\nordicsemi\dfu
    copying build\lib\nordicsemi\dfu\nrfhex.py -> build\bdist.win32\egg\nordicsemi\dfu
    copying build\lib\nordicsemi\dfu\package.py -> build\bdist.win32\egg\nordicsemi\dfu
    copying build\lib\nordicsemi\dfu\signing.py -> build\bdist.win32\egg\nordicsemi\dfu
    creating build\bdist.win32\egg\nordicsemi\dfu\tests
    copying build\lib\nordicsemi\dfu\tests\test_dfu_transport_serial.py -> build\bdist.win32\egg\nordicsemi\dfu\tests
    copying build\lib\nordicsemi\dfu\tests\test_init_packet.py -> build\bdist.win32\egg\nordicsemi\dfu\tests
    copying build\lib\nordicsemi\dfu\tests\test_manifest.py -> build\bdist.win32\egg\nordicsemi\dfu\tests
    copying build\lib\nordicsemi\dfu\tests\test_nrfhex.py -> build\bdist.win32\egg\nordicsemi\dfu\tests
    copying build\lib\nordicsemi\dfu\tests\test_package.py -> build\bdist.win32\egg\nordicsemi\dfu\tests
    copying build\lib\nordicsemi\dfu\tests\test_signing.py -> build\bdist.win32\egg\nordicsemi\dfu\tests
    copying build\lib\nordicsemi\dfu\tests\__init__.py -> build\bdist.win32\egg\nordicsemi\dfu\tests
    copying build\lib\nordicsemi\dfu\util.py -> build\bdist.win32\egg\nordicsemi\dfu
    copying build\lib\nordicsemi\dfu\__init__.py -> build\bdist.win32\egg\nordicsemi\dfu
    copying build\lib\nordicsemi\exceptions.py -> build\bdist.win32\egg\nordicsemi
    creating build\bdist.win32\egg\nordicsemi\utility
    copying build\lib\nordicsemi\utility\target_registry.py -> build\bdist.win32\egg\nordicsemi\utility
    creating build\bdist.win32\egg\nordicsemi\utility\tests
    copying build\lib\nordicsemi\utility\tests\test_target_registry.py -> build\bdist.win32\egg\nordicsemi\utility\tests
    copying build\lib\nordicsemi\utility\tests\__init__.py -> build\bdist.win32\egg\nordicsemi\utility\tests
    copying build\lib\nordicsemi\utility\__init__.py -> build\bdist.win32\egg\nordicsemi\utility
    copying build\lib\nordicsemi\version.py -> build\bdist.win32\egg\nordicsemi
    copying build\lib\nordicsemi\__init__.py -> build\bdist.win32\egg\nordicsemi
    copying build\lib\nordicsemi\__main__.py -> build\bdist.win32\egg\nordicsemi
    byte-compiling build\bdist.win32\egg\nordicsemi\bluetooth\hci\codec.py to codec.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\bluetooth\hci\slip.py to slip.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\bluetooth\hci\tests\test_codec.py to test_codec.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\bluetooth\hci\tests\__init__.py to __init__.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\bluetooth\hci\__init__.py to __init__.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\bluetooth\__init__.py to __init__.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\dfu\crc16.py to crc16.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\dfu\dfu.py to dfu.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\dfu\dfu_transport.py to dfu_transport.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\dfu\dfu_transport_ble.py to dfu_transport_ble.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\dfu\dfu_transport_serial.py to dfu_transport_serial.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\dfu\init_packet.py to init_packet.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\dfu\intelhex\compat.py to compat.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\dfu\intelhex\__init__.py to __init__.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\dfu\manifest.py to manifest.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\dfu\model.py to model.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\dfu\nrfhex.py to nrfhex.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\dfu\package.py to package.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\dfu\signing.py to signing.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\dfu\tests\test_dfu_transport_serial.py to test_dfu_transport_serial.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\dfu\tests\test_init_packet.py to test_init_packet.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\dfu\tests\test_manifest.py to test_manifest.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\dfu\tests\test_nrfhex.py to test_nrfhex.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\dfu\tests\test_package.py to test_package.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\dfu\tests\test_signing.py to test_signing.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\dfu\tests\__init__.py to __init__.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\dfu\util.py to util.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\dfu\__init__.py to __init__.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\exceptions.py to exceptions.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\utility\target_registry.py to target_registry.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\utility\tests\test_target_registry.py to test_target_registry.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\utility\tests\__init__.py to __init__.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\utility\__init__.py to __init__.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\version.py to version.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\__init__.py to __init__.pyc
    byte-compiling build\bdist.win32\egg\nordicsemi\__main__.py to __main__.pyc
    creating build\bdist.win32\egg\EGG-INFO
    copying nrfutil.egg-info\PKG-INFO -> build\bdist.win32\egg\EGG-INFO
    copying nrfutil.egg-info\SOURCES.txt -> build\bdist.win32\egg\EGG-INFO
    copying nrfutil.egg-info\dependency_links.txt -> build\bdist.win32\egg\EGG-INFO
    copying nrfutil.egg-info\entry_points.txt -> build\bdist.win32\egg\EGG-INFO
    copying nrfutil.egg-info\not-zip-safe -> build\bdist.win32\egg\EGG-INFO
    copying nrfutil.egg-info\top_level.txt -> build\bdist.win32\egg\EGG-INFO
    creating dist
    creating 'dist\nrfutil-0.3.0-py2.7.egg' and adding 'build\bdist.win32\egg' to it
    removing 'build\bdist.win32\egg' (and everything under it)
    Processing nrfutil-0.3.0-py2.7.egg
    creating c:\python27\lib\site-packages\nrfutil-0.3.0-py2.7.egg
    Extracting nrfutil-0.3.0-py2.7.egg to c:\python27\lib\site-packages
    Adding nrfutil 0.3.0 to easy-install.pth file
    Installing nrfutil-script.py script to C:\Python27\Scripts
    Installing nrfutil.exe script to C:\Python27\Scripts
    Installing nrfutil.exe.manifest script to C:\Python27\Scripts
    Installed c:\python27\lib\site-packages\nrfutil-0.3.0-py2.7.egg
    Processing dependencies for nrfutil==0.3.0
    Finished processing dependencies for nrfutil==0.3.0
    Final SteP:  PS C:\Python27\pc-nrfutil-0.3.0> python setup.py py2exe
    =======out put==========================0
    running py2exe
    running build_py
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\bundle-2.7
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\temp
    creating C:\Python27\pc-nrfutil-0.3.0\0.3.0
    *** searching for required modules ***
    *** parsing results ***
    *** finding dlls needed ***
    *** create binaries ***
    *** byte compile python files ***
    byte-compiling C:\Python27\lib\StringIO.py to StringIO.pyc
    byte-compiling C:\Python27\lib\UserDict.py to UserDict.pyc
    byte-compiling C:\Python27\lib\_LWPCookieJar.py to _LWPCookieJar.pyc
    byte-compiling C:\Python27\lib\_MozillaCookieJar.py to _MozillaCookieJar.pyc
    byte-compiling C:\Python27\lib\__future__.py to __future__.pyc
    byte-compiling C:\Python27\lib\_abcoll.py to _abcoll.pyc
    byte-compiling C:\Python27\lib\_osx_support.py to _osx_support.pyc
    byte-compiling C:\Python27\lib\_strptime.py to _strptime.pyc
    byte-compiling C:\Python27\lib\_threading_local.py to _threading_local.pyc
    byte-compiling C:\Python27\lib\_weakrefset.py to _weakrefset.pyc
    byte-compiling C:\Python27\lib\abc.py to abc.pyc
    byte-compiling C:\Python27\lib\anydbm.py to anydbm.pyc
    byte-compiling C:\Python27\lib\ast.py to ast.pyc
    byte-compiling C:\Python27\lib\atexit.py to atexit.pyc
    byte-compiling C:\Python27\lib\base64.py to base64.pyc
    byte-compiling C:\Python27\lib\bdb.py to bdb.pyc
    byte-compiling C:\Python27\lib\bisect.py to bisect.pyc
    byte-compiling C:\Python27\lib\calendar.py to calendar.pyc
    byte-compiling C:\Python27\lib\cmd.py to cmd.pyc
    byte-compiling C:\Python27\lib\codecs.py to codecs.pyc
    byte-compiling C:\Python27\lib\collections.py to collections.pyc
    byte-compiling C:\Python27\lib\contextlib.py to contextlib.pyc
    byte-compiling C:\Python27\lib\cookielib.py to cookielib.pyc
    byte-compiling C:\Python27\lib\copy.py to copy.pyc
    byte-compiling C:\Python27\lib\copy_reg.py to copy_reg.pyc
    byte-compiling C:\Python27\lib\ctypes\__init__.py to ctypes\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\ctypes
    byte-compiling C:\Python27\lib\ctypes\_endian.py to ctypes\_endian.pyc
    byte-compiling C:\Python27\lib\ctypes\macholib\__init__.py to ctypes\macholib\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\ctypes\macholib
    byte-compiling C:\Python27\lib\ctypes\macholib\dyld.py to ctypes\macholib\dyld.pyc
    byte-compiling C:\Python27\lib\ctypes\macholib\dylib.py to ctypes\macholib\dylib.pyc
    byte-compiling C:\Python27\lib\ctypes\macholib\framework.py to ctypes\macholib\framework.pyc
    byte-compiling C:\Python27\lib\ctypes\util.py to ctypes\util.pyc
    byte-compiling C:\Python27\lib\ctypes\wintypes.py to ctypes\wintypes.pyc
    byte-compiling C:\Python27\lib\decimal.py to decimal.pyc
    byte-compiling C:\Python27\lib\difflib.py to difflib.pyc
    byte-compiling C:\Python27\lib\dis.py to dis.pyc
    byte-compiling C:\Python27\lib\distutils\__init__.py to distutils\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\distutils
    byte-compiling C:\Python27\lib\distutils\debug.py to distutils\debug.pyc
    byte-compiling C:\Python27\lib\distutils\errors.py to distutils\errors.pyc
    byte-compiling C:\Python27\lib\distutils\log.py to distutils\log.pyc
    byte-compiling C:\Python27\lib\distutils\spawn.py to distutils\spawn.pyc
    byte-compiling C:\Python27\lib\distutils\sysconfig.py to distutils\sysconfig.pyc
    byte-compiling C:\Python27\lib\distutils\text_file.py to distutils\text_file.pyc
    byte-compiling C:\Python27\lib\doctest.py to doctest.pyc
    byte-compiling C:\Python27\lib\dumbdbm.py to dumbdbm.pyc
    byte-compiling C:\Python27\lib\dummy_thread.py to dummy_thread.pyc
    byte-compiling C:\Python27\lib\dummy_threading.py to dummy_threading.pyc
    byte-compiling C:\Python27\lib\email\__init__.py to email\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\email
    byte-compiling C:\Python27\lib\email\_parseaddr.py to email\_parseaddr.pyc
    byte-compiling C:\Python27\lib\email\base64mime.py to email\base64mime.pyc
    byte-compiling C:\Python27\lib\email\charset.py to email\charset.pyc
    byte-compiling C:\Python27\lib\email\encoders.py to email\encoders.pyc
    byte-compiling C:\Python27\lib\email\errors.py to email\errors.pyc
    byte-compiling C:\Python27\lib\email\feedparser.py to email\feedparser.pyc
    byte-compiling C:\Python27\lib\email\generator.py to email\generator.pyc
    byte-compiling C:\Python27\lib\email\header.py to email\header.pyc
    byte-compiling C:\Python27\lib\email\iterators.py to email\iterators.pyc
    byte-compiling C:\Python27\lib\email\message.py to email\message.pyc
    byte-compiling C:\Python27\lib\email\mime\__init__.py to email\mime\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\email\mime
    byte-compiling C:\Python27\lib\email\parser.py to email\parser.pyc
    byte-compiling C:\Python27\lib\email\quoprimime.py to email\quoprimime.pyc
    byte-compiling C:\Python27\lib\email\utils.py to email\utils.pyc
    byte-compiling C:\Python27\lib\encodings\__init__.py to encodings\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\encodings
    byte-compiling C:\Python27\lib\encodings\aliases.py to encodings\aliases.pyc
    byte-compiling C:\Python27\lib\encodings\ascii.py to encodings\ascii.pyc
    byte-compiling C:\Python27\lib\encodings\base64_codec.py to encodings\base64_codec.pyc
    byte-compiling C:\Python27\lib\encodings\big5.py to encodings\big5.pyc
    byte-compiling C:\Python27\lib\encodings\big5hkscs.py to encodings\big5hkscs.pyc
    byte-compiling C:\Python27\lib\encodings\bz2_codec.py to encodings\bz2_codec.pyc
    byte-compiling C:\Python27\lib\encodings\charmap.py to encodings\charmap.pyc
    byte-compiling C:\Python27\lib\encodings\cp037.py to encodings\cp037.pyc
    byte-compiling C:\Python27\lib\encodings\cp1006.py to encodings\cp1006.pyc
    byte-compiling C:\Python27\lib\encodings\cp1026.py to encodings\cp1026.pyc
    byte-compiling C:\Python27\lib\encodings\cp1140.py to encodings\cp1140.pyc
    byte-compiling C:\Python27\lib\encodings\cp1250.py to encodings\cp1250.pyc
    byte-compiling C:\Python27\lib\encodings\cp1251.py to encodings\cp1251.pyc
    byte-compiling C:\Python27\lib\encodings\cp1252.py to encodings\cp1252.pyc
    byte-compiling C:\Python27\lib\encodings\cp1253.py to encodings\cp1253.pyc
    byte-compiling C:\Python27\lib\encodings\cp1254.py to encodings\cp1254.pyc
    byte-compiling C:\Python27\lib\encodings\cp1255.py to encodings\cp1255.pyc
    byte-compiling C:\Python27\lib\encodings\cp1256.py to encodings\cp1256.pyc
    byte-compiling C:\Python27\lib\encodings\cp1257.py to encodings\cp1257.pyc
    byte-compiling C:\Python27\lib\encodings\cp1258.py to encodings\cp1258.pyc
    byte-compiling C:\Python27\lib\encodings\cp424.py to encodings\cp424.pyc
    byte-compiling C:\Python27\lib\encodings\cp437.py to encodings\cp437.pyc
    byte-compiling C:\Python27\lib\encodings\cp500.py to encodings\cp500.pyc
    byte-compiling C:\Python27\lib\encodings\cp720.py to encodings\cp720.pyc
    byte-compiling C:\Python27\lib\encodings\cp737.py to encodings\cp737.pyc
    byte-compiling C:\Python27\lib\encodings\cp775.py to encodings\cp775.pyc
    byte-compiling C:\Python27\lib\encodings\cp850.py to encodings\cp850.pyc
    byte-compiling C:\Python27\lib\encodings\cp852.py to encodings\cp852.pyc
    byte-compiling C:\Python27\lib\encodings\cp855.py to encodings\cp855.pyc
    byte-compiling C:\Python27\lib\encodings\cp856.py to encodings\cp856.pyc
    byte-compiling C:\Python27\lib\encodings\cp857.py to encodings\cp857.pyc
    byte-compiling C:\Python27\lib\encodings\cp858.py to encodings\cp858.pyc
    byte-compiling C:\Python27\lib\encodings\cp860.py to encodings\cp860.pyc
    byte-compiling C:\Python27\lib\encodings\cp861.py to encodings\cp861.pyc
    byte-compiling C:\Python27\lib\encodings\cp862.py to encodings\cp862.pyc
    byte-compiling C:\Python27\lib\encodings\cp863.py to encodings\cp863.pyc
    byte-compiling C:\Python27\lib\encodings\cp864.py to encodings\cp864.pyc
    byte-compiling C:\Python27\lib\encodings\cp865.py to encodings\cp865.pyc
    byte-compiling C:\Python27\lib\encodings\cp866.py to encodings\cp866.pyc
    byte-compiling C:\Python27\lib\encodings\cp869.py to encodings\cp869.pyc
    byte-compiling C:\Python27\lib\encodings\cp874.py to encodings\cp874.pyc
    byte-compiling C:\Python27\lib\encodings\cp875.py to encodings\cp875.pyc
    byte-compiling C:\Python27\lib\encodings\cp932.py to encodings\cp932.pyc
    byte-compiling C:\Python27\lib\encodings\cp949.py to encodings\cp949.pyc
    byte-compiling C:\Python27\lib\encodings\cp950.py to encodings\cp950.pyc
    byte-compiling C:\Python27\lib\encodings\euc_jis_2004.py to encodings\euc_jis_2004.pyc
    byte-compiling C:\Python27\lib\encodings\euc_jisx0213.py to encodings\euc_jisx0213.pyc
    byte-compiling C:\Python27\lib\encodings\euc_jp.py to encodings\euc_jp.pyc
    byte-compiling C:\Python27\lib\encodings\euc_kr.py to encodings\euc_kr.pyc
    byte-compiling C:\Python27\lib\encodings\gb18030.py to encodings\gb18030.pyc
    byte-compiling C:\Python27\lib\encodings\gb2312.py to encodings\gb2312.pyc
    byte-compiling C:\Python27\lib\encodings\gbk.py to encodings\gbk.pyc
    byte-compiling C:\Python27\lib\encodings\hex_codec.py to encodings\hex_codec.pyc
    byte-compiling C:\Python27\lib\encodings\hp_roman8.py to encodings\hp_roman8.pyc
    byte-compiling C:\Python27\lib\encodings\hz.py to encodings\hz.pyc
    byte-compiling C:\Python27\lib\encodings\idna.py to encodings\idna.pyc
    byte-compiling C:\Python27\lib\encodings\iso2022_jp.py to encodings\iso2022_jp.pyc
    byte-compiling C:\Python27\lib\encodings\iso2022_jp_1.py to encodings\iso2022_jp_1.pyc
    byte-compiling C:\Python27\lib\encodings\iso2022_jp_2.py to encodings\iso2022_jp_2.pyc
    byte-compiling C:\Python27\lib\encodings\iso2022_jp_2004.py to encodings\iso2022_jp_2004.pyc
    byte-compiling C:\Python27\lib\encodings\iso2022_jp_3.py to encodings\iso2022_jp_3.pyc
    byte-compiling C:\Python27\lib\encodings\iso2022_jp_ext.py to encodings\iso2022_jp_ext.pyc
    byte-compiling C:\Python27\lib\encodings\iso2022_kr.py to encodings\iso2022_kr.pyc
    byte-compiling C:\Python27\lib\encodings\iso8859_1.py to encodings\iso8859_1.pyc
    byte-compiling C:\Python27\lib\encodings\iso8859_10.py to encodings\iso8859_10.pyc
    byte-compiling C:\Python27\lib\encodings\iso8859_11.py to encodings\iso8859_11.pyc
    byte-compiling C:\Python27\lib\encodings\iso8859_13.py to encodings\iso8859_13.pyc
    byte-compiling C:\Python27\lib\encodings\iso8859_14.py to encodings\iso8859_14.pyc
    byte-compiling C:\Python27\lib\encodings\iso8859_15.py to encodings\iso8859_15.pyc
    byte-compiling C:\Python27\lib\encodings\iso8859_16.py to encodings\iso8859_16.pyc
    byte-compiling C:\Python27\lib\encodings\iso8859_2.py to encodings\iso8859_2.pyc
    byte-compiling C:\Python27\lib\encodings\iso8859_3.py to encodings\iso8859_3.pyc
    byte-compiling C:\Python27\lib\encodings\iso8859_4.py to encodings\iso8859_4.pyc
    byte-compiling C:\Python27\lib\encodings\iso8859_5.py to encodings\iso8859_5.pyc
    byte-compiling C:\Python27\lib\encodings\iso8859_6.py to encodings\iso8859_6.pyc
    byte-compiling C:\Python27\lib\encodings\iso8859_7.py to encodings\iso8859_7.pyc
    byte-compiling C:\Python27\lib\encodings\iso8859_8.py to encodings\iso8859_8.pyc
    byte-compiling C:\Python27\lib\encodings\iso8859_9.py to encodings\iso8859_9.pyc
    byte-compiling C:\Python27\lib\encodings\johab.py to encodings\johab.pyc
    byte-compiling C:\Python27\lib\encodings\koi8_r.py to encodings\koi8_r.pyc
    byte-compiling C:\Python27\lib\encodings\koi8_u.py to encodings\koi8_u.pyc
    byte-compiling C:\Python27\lib\encodings\latin_1.py to encodings\latin_1.pyc
    byte-compiling C:\Python27\lib\encodings\mac_arabic.py to encodings\mac_arabic.pyc
    byte-compiling C:\Python27\lib\encodings\mac_centeuro.py to encodings\mac_centeuro.pyc
    byte-compiling C:\Python27\lib\encodings\mac_croatian.py to encodings\mac_croatian.pyc
    byte-compiling C:\Python27\lib\encodings\mac_cyrillic.py to encodings\mac_cyrillic.pyc
    byte-compiling C:\Python27\lib\encodings\mac_farsi.py to encodings\mac_farsi.pyc
    byte-compiling C:\Python27\lib\encodings\mac_greek.py to encodings\mac_greek.pyc
    byte-compiling C:\Python27\lib\encodings\mac_iceland.py to encodings\mac_iceland.pyc
    byte-compiling C:\Python27\lib\encodings\mac_latin2.py to encodings\mac_latin2.pyc
    byte-compiling C:\Python27\lib\encodings\mac_roman.py to encodings\mac_roman.pyc
    byte-compiling C:\Python27\lib\encodings\mac_romanian.py to encodings\mac_romanian.pyc
    byte-compiling C:\Python27\lib\encodings\mac_turkish.py to encodings\mac_turkish.pyc
    byte-compiling C:\Python27\lib\encodings\mbcs.py to encodings\mbcs.pyc
    byte-compiling C:\Python27\lib\encodings\palmos.py to encodings\palmos.pyc
    byte-compiling C:\Python27\lib\encodings\ptcp154.py to encodings\ptcp154.pyc
    byte-compiling C:\Python27\lib\encodings\punycode.py to encodings\punycode.pyc
    byte-compiling C:\Python27\lib\encodings\quopri_codec.py to encodings\quopri_codec.pyc
    byte-compiling C:\Python27\lib\encodings\raw_unicode_escape.py to encodings\raw_unicode_escape.pyc
    byte-compiling C:\Python27\lib\encodings\rot_13.py to encodings\rot_13.pyc
    byte-compiling C:\Python27\lib\encodings\shift_jis.py to encodings\shift_jis.pyc
    byte-compiling C:\Python27\lib\encodings\shift_jis_2004.py to encodings\shift_jis_2004.pyc
    byte-compiling C:\Python27\lib\encodings\shift_jisx0213.py to encodings\shift_jisx0213.pyc
    byte-compiling C:\Python27\lib\encodings\string_escape.py to encodings\string_escape.pyc
    byte-compiling C:\Python27\lib\encodings\tis_620.py to encodings\tis_620.pyc
    byte-compiling C:\Python27\lib\encodings\undefined.py to encodings\undefined.pyc
    byte-compiling C:\Python27\lib\encodings\unicode_escape.py to encodings\unicode_escape.pyc
    byte-compiling C:\Python27\lib\encodings\unicode_internal.py to encodings\unicode_internal.pyc
    byte-compiling C:\Python27\lib\encodings\utf_16.py to encodings\utf_16.pyc
    byte-compiling C:\Python27\lib\encodings\utf_16_be.py to encodings\utf_16_be.pyc
    byte-compiling C:\Python27\lib\encodings\utf_16_le.py to encodings\utf_16_le.pyc
    byte-compiling C:\Python27\lib\encodings\utf_32.py to encodings\utf_32.pyc
    byte-compiling C:\Python27\lib\encodings\utf_32_be.py to encodings\utf_32_be.pyc
    byte-compiling C:\Python27\lib\encodings\utf_32_le.py to encodings\utf_32_le.pyc
    byte-compiling C:\Python27\lib\encodings\utf_7.py to encodings\utf_7.pyc
    byte-compiling C:\Python27\lib\encodings\utf_8.py to encodings\utf_8.pyc
    byte-compiling C:\Python27\lib\encodings\utf_8_sig.py to encodings\utf_8_sig.pyc
    byte-compiling C:\Python27\lib\encodings\uu_codec.py to encodings\uu_codec.pyc
    byte-compiling C:\Python27\lib\encodings\zlib_codec.py to encodings\zlib_codec.pyc
    byte-compiling C:\Python27\lib\fnmatch.py to fnmatch.pyc
    byte-compiling C:\Python27\lib\ftplib.py to ftplib.pyc
    byte-compiling C:\Python27\lib\functools.py to functools.pyc
    byte-compiling C:\Python27\lib\genericpath.py to genericpath.pyc
    byte-compiling C:\Python27\lib\getopt.py to getopt.pyc
    byte-compiling C:\Python27\lib\getpass.py to getpass.pyc
    byte-compiling C:\Python27\lib\gettext.py to gettext.pyc
    byte-compiling C:\Python27\lib\glob.py to glob.pyc
    byte-compiling C:\Python27\lib\gzip.py to gzip.pyc
    byte-compiling C:\Python27\lib\hashlib.py to hashlib.pyc
    byte-compiling C:\Python27\lib\heapq.py to heapq.pyc
    byte-compiling C:\Python27\lib\hmac.py to hmac.pyc
    byte-compiling C:\Python27\lib\httplib.py to httplib.pyc
    byte-compiling C:\Python27\lib\importlib\__init__.py to importlib\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\importlib
    byte-compiling C:\Python27\lib\inspect.py to inspect.pyc
    byte-compiling C:\Python27\lib\io.py to io.pyc
    byte-compiling C:\Python27\lib\json\__init__.py to json\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\json
    byte-compiling C:\Python27\lib\json\decoder.py to json\decoder.pyc
    byte-compiling C:\Python27\lib\json\encoder.py to json\encoder.pyc
    byte-compiling C:\Python27\lib\json\scanner.py to json\scanner.pyc
    byte-compiling C:\Python27\lib\keyword.py to keyword.pyc
    byte-compiling C:\Python27\lib\linecache.py to linecache.pyc
    byte-compiling C:\Python27\lib\locale.py to locale.pyc
    byte-compiling C:\Python27\lib\logging\__init__.py to logging\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\logging
    byte-compiling C:\Python27\lib\mimetools.py to mimetools.pyc
    byte-compiling C:\Python27\lib\mimetypes.py to mimetypes.pyc
    byte-compiling C:\Python27\lib\ntpath.py to ntpath.pyc
    byte-compiling C:\Python27\lib\nturl2path.py to nturl2path.pyc
    byte-compiling C:\Python27\lib\numbers.py to numbers.pyc
    byte-compiling C:\Python27\lib\opcode.py to opcode.pyc
    byte-compiling C:\Python27\lib\optparse.py to optparse.pyc
    byte-compiling C:\Python27\lib\os.py to os.pyc
    byte-compiling C:\Python27\lib\os2emxpath.py to os2emxpath.pyc
    byte-compiling C:\Python27\lib\pdb.py to pdb.pyc
    byte-compiling C:\Python27\lib\pkgutil.py to pkgutil.pyc
    byte-compiling C:\Python27\lib\platform.py to platform.pyc
    byte-compiling C:\Python27\lib\plistlib.py to plistlib.pyc
    byte-compiling C:\Python27\lib\posixpath.py to posixpath.pyc
    byte-compiling C:\Python27\lib\pprint.py to pprint.pyc
    byte-compiling C:\Python27\lib\py_compile.py to py_compile.pyc
    byte-compiling C:\Python27\lib\quopri.py to quopri.pyc
    byte-compiling C:\Python27\lib\random.py to random.pyc
    byte-compiling C:\Python27\lib\re.py to re.pyc
    byte-compiling C:\Python27\lib\repr.py to repr.pyc
    byte-compiling C:\Python27\lib\rfc822.py to rfc822.pyc
    byte-compiling C:\Python27\lib\shlex.py to shlex.pyc
    byte-compiling C:\Python27\lib\shutil.py to shutil.pyc
    byte-compiling C:\Python27\lib\site-packages\_dummy_thread\__init__.py to _dummy_thread\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\_dummy_thread
    byte-compiling C:\Python27\lib\site-packages\_thread\__init__.py to _thread\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\_thread
    byte-compiling C:\Python27\lib\site-packages\builtins\__init__.py to builtins\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\builtins
    byte-compiling C:\Python27\lib\site-packages\click\__init__.py to click\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\click
    byte-compiling C:\Python27\lib\site-packages\click\_bashcomplete.py to click\_bashcomplete.pyc
    byte-compiling C:\Python27\lib\site-packages\click\_compat.py to click\_compat.pyc
    byte-compiling C:\Python27\lib\site-packages\click\_termui_impl.py to click\_termui_impl.pyc
    byte-compiling C:\Python27\lib\site-packages\click\_textwrap.py to click\_textwrap.pyc
    byte-compiling C:\Python27\lib\site-packages\click\_unicodefun.py to click\_unicodefun.pyc
    byte-compiling C:\Python27\lib\site-packages\click\_winconsole.py to click\_winconsole.pyc
    byte-compiling C:\Python27\lib\site-packages\click\core.py to click\core.pyc
    byte-compiling C:\Python27\lib\site-packages\click\decorators.py to click\decorators.pyc
    byte-compiling C:\Python27\lib\site-packages\click\exceptions.py to click\exceptions.pyc
    byte-compiling C:\Python27\lib\site-packages\click\formatting.py to click\formatting.pyc
    byte-compiling C:\Python27\lib\site-packages\click\globals.py to click\globals.pyc
    byte-compiling C:\Python27\lib\site-packages\click\parser.py to click\parser.pyc
    byte-compiling C:\Python27\lib\site-packages\click\termui.py to click\termui.pyc
    byte-compiling C:\Python27\lib\site-packages\click\types.py to click\types.pyc
    byte-compiling C:\Python27\lib\site-packages\click\utils.py to click\utils.pyc
    byte-compiling C:\Python27\lib\site-packages\ecdsa\__init__.py to ecdsa\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\ecdsa
    byte-compiling C:\Python27\lib\site-packages\ecdsa\_version.py to ecdsa\_version.pyc
    byte-compiling C:\Python27\lib\site-packages\ecdsa\curves.py to ecdsa\curves.pyc
    byte-compiling C:\Python27\lib\site-packages\ecdsa\der.py to ecdsa\der.pyc
    byte-compiling C:\Python27\lib\site-packages\ecdsa\ecdsa.py to ecdsa\ecdsa.pyc
    byte-compiling C:\Python27\lib\site-packages\ecdsa\ellipticcurve.py to ecdsa\ellipticcurve.pyc
    byte-compiling C:\Python27\lib\site-packages\ecdsa\keys.py to ecdsa\keys.pyc
    byte-compiling C:\Python27\lib\site-packages\ecdsa\numbertheory.py to ecdsa\numbertheory.pyc
    byte-compiling C:\Python27\lib\site-packages\ecdsa\rfc6979.py to ecdsa\rfc6979.pyc
    byte-compiling C:\Python27\lib\site-packages\ecdsa\six.py to ecdsa\six.pyc
    byte-compiling C:\Python27\lib\site-packages\ecdsa\util.py to ecdsa\util.pyc
    byte-compiling C:\Python27\lib\site-packages\enum\__init__.py to enum\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\enum
    byte-compiling C:\Python27\lib\site-packages\future\__init__.py to future\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\future
    byte-compiling C:\Python27\lib\site-packages\future\backports\__init__.py to future\backports\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\future\backports
    byte-compiling C:\Python27\lib\site-packages\future\backports\datetime.py to future\backports\datetime.pyc
    byte-compiling C:\Python27\lib\site-packages\future\backports\email\__init__.py to future\backports\email\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\future\backports\email
    byte-compiling C:\Python27\lib\site-packages\future\backports\email\_encoded_words.py to future\backports\email\_encoded_words.pyc
    byte-compiling C:\Python27\lib\site-packages\future\backports\email\_parseaddr.py to future\backports\email\_parseaddr.pyc
    byte-compiling C:\Python27\lib\site-packages\future\backports\email\_policybase.py to future\backports\email\_policybase.pyc
    byte-compiling C:\Python27\lib\site-packages\future\backports\email\base64mime.py to future\backports\email\base64mime.pyc
    byte-compiling C:\Python27\lib\site-packages\future\backports\email\charset.py to future\backports\email\charset.pyc
    byte-compiling C:\Python27\lib\site-packages\future\backports\email\encoders.py to future\backports\email\encoders.pyc
    byte-compiling C:\Python27\lib\site-packages\future\backports\email\errors.py to future\backports\email\errors.pyc
    byte-compiling C:\Python27\lib\site-packages\future\backports\email\feedparser.py to future\backports\email\feedparser.pyc
    byte-compiling C:\Python27\lib\site-packages\future\backports\email\generator.py to future\backports\email\generator.pyc
    byte-compiling C:\Python27\lib\site-packages\future\backports\email\header.py to future\backports\email\header.pyc
    byte-compiling C:\Python27\lib\site-packages\future\backports\email\iterators.py to future\backports\email\iterators.pyc
    byte-compiling C:\Python27\lib\site-packages\future\backports\email\message.py to future\backports\email\message.pyc
    byte-compiling C:\Python27\lib\site-packages\future\backports\email\parser.py to future\backports\email\parser.pyc
    byte-compiling C:\Python27\lib\site-packages\future\backports\email\quoprimime.py to future\backports\email\quoprimime.pyc
    byte-compiling C:\Python27\lib\site-packages\future\backports\email\utils.py to future\backports\email\utils.pyc
    byte-compiling C:\Python27\lib\site-packages\future\backports\http\__init__.py to future\backports\http\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\future\backports\http
    byte-compiling C:\Python27\lib\site-packages\future\backports\http\client.py to future\backports\http\client.pyc
    byte-compiling C:\Python27\lib\site-packages\future\backports\http\cookiejar.py to future\backports\http\cookiejar.pyc
    byte-compiling C:\Python27\lib\site-packages\future\backports\misc.py to future\backports\misc.pyc
    byte-compiling C:\Python27\lib\site-packages\future\backports\urllib\__init__.py to future\backports\urllib\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\future\backports\urllib
    byte-compiling C:\Python27\lib\site-packages\future\backports\urllib\error.py to future\backports\urllib\error.pyc
    byte-compiling C:\Python27\lib\site-packages\future\backports\urllib\parse.py to future\backports\urllib\parse.pyc
    byte-compiling C:\Python27\lib\site-packages\future\backports\urllib\request.py to future\backports\urllib\request.pyc
    byte-compiling C:\Python27\lib\site-packages\future\backports\urllib\response.py to future\backports\urllib\response.pyc
    byte-compiling C:\Python27\lib\site-packages\future\backports\urllib\robotparser.py to future\backports\urllib\robotparser.pyc
    byte-compiling C:\Python27\lib\site-packages\future\builtins\__init__.py to future\builtins\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\future\builtins
    byte-compiling C:\Python27\lib\site-packages\future\builtins\iterators.py to future\builtins\iterators.pyc
    byte-compiling C:\Python27\lib\site-packages\future\builtins\misc.py to future\builtins\misc.pyc
    byte-compiling C:\Python27\lib\site-packages\future\builtins\newnext.py to future\builtins\newnext.pyc
    byte-compiling C:\Python27\lib\site-packages\future\builtins\newround.py to future\builtins\newround.pyc
    byte-compiling C:\Python27\lib\site-packages\future\builtins\newsuper.py to future\builtins\newsuper.pyc
    byte-compiling C:\Python27\lib\site-packages\future\moves\__init__.py to future\moves\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\future\moves
    byte-compiling C:\Python27\lib\site-packages\future\moves\dbm\__init__.py to future\moves\dbm\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\future\moves\dbm
    byte-compiling C:\Python27\lib\site-packages\future\moves\dbm\dumb.py to future\moves\dbm\dumb.pyc
    byte-compiling C:\Python27\lib\site-packages\future\moves\dbm\gnu.py to future\moves\dbm\gnu.pyc
    byte-compiling C:\Python27\lib\site-packages\future\moves\dbm\ndbm.py to future\moves\dbm\ndbm.pyc
    byte-compiling C:\Python27\lib\site-packages\future\moves\test\__init__.py to future\moves\test\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\future\moves\test
    byte-compiling C:\Python27\lib\site-packages\future\moves\test\support.py to future\moves\test\support.pyc
    byte-compiling C:\Python27\lib\site-packages\future\standard_library\__init__.py to future\standard_library\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\future\standard_library
    byte-compiling C:\Python27\lib\site-packages\future\types\__init__.py to future\types\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\future\types
    byte-compiling C:\Python27\lib\site-packages\future\types\newbytes.py to future\types\newbytes.pyc
    byte-compiling C:\Python27\lib\site-packages\future\types\newdict.py to future\types\newdict.pyc
    byte-compiling C:\Python27\lib\site-packages\future\types\newint.py to future\types\newint.pyc
    byte-compiling C:\Python27\lib\site-packages\future\types\newlist.py to future\types\newlist.pyc
    byte-compiling C:\Python27\lib\site-packages\future\types\newobject.py to future\types\newobject.pyc
    byte-compiling C:\Python27\lib\site-packages\future\types\newrange.py to future\types\newrange.pyc
    byte-compiling C:\Python27\lib\site-packages\future\types\newstr.py to future\types\newstr.pyc
    byte-compiling C:\Python27\lib\site-packages\future\utils\__init__.py to future\utils\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\future\utils
    byte-compiling C:\Python27\lib\site-packages\future\utils\surrogateescape.py to future\utils\surrogateescape.pyc
    byte-compiling C:\Python27\lib\site-packages\pkg_resources\__init__.py to pkg_resources\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\pkg_resources
    byte-compiling C:\Python27\lib\site-packages\pkg_resources\extern\__init__.py to pkg_resources\extern\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\pkg_resources\extern
    byte-compiling C:\Python27\lib\site-packages\pkg_resources\py31compat.py to pkg_resources\py31compat.pyc
    byte-compiling C:\Python27\lib\site-packages\reprlib\__init__.py to reprlib\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\reprlib
    byte-compiling C:\Python27\lib\site-packages\serial\__init__.py to serial\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\serial
    byte-compiling C:\Python27\lib\site-packages\serial\serialcli.py to serial\serialcli.pyc
    byte-compiling C:\Python27\lib\site-packages\serial\serialjava.py to serial\serialjava.pyc
    byte-compiling C:\Python27\lib\site-packages\serial\serialposix.py to serial\serialposix.pyc
    byte-compiling C:\Python27\lib\site-packages\serial\serialutil.py to serial\serialutil.pyc
    byte-compiling C:\Python27\lib\site-packages\serial\serialwin32.py to serial\serialwin32.pyc
    byte-compiling C:\Python27\lib\site-packages\serial\win32.py to serial\win32.pyc
    byte-compiling C:\Python27\lib\site-packages\winreg\__init__.py to winreg\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\winreg
    byte-compiling C:\Python27\lib\site-packages\zipextimporter.py to zipextimporter.pyc
    byte-compiling C:\Python27\lib\socket.py to socket.pyc
    byte-compiling C:\Python27\lib\sre.py to sre.pyc
    byte-compiling C:\Python27\lib\sre_compile.py to sre_compile.pyc
    byte-compiling C:\Python27\lib\sre_constants.py to sre_constants.pyc
    byte-compiling C:\Python27\lib\sre_parse.py to sre_parse.pyc
    byte-compiling C:\Python27\lib\ssl.py to ssl.pyc
    byte-compiling C:\Python27\lib\stat.py to stat.pyc
    byte-compiling C:\Python27\lib\string.py to string.pyc
    byte-compiling C:\Python27\lib\stringprep.py to stringprep.pyc
    byte-compiling C:\Python27\lib\struct.py to struct.pyc
    byte-compiling C:\Python27\lib\subprocess.py to subprocess.pyc
    byte-compiling C:\Python27\lib\sysconfig.py to sysconfig.pyc
    byte-compiling C:\Python27\lib\tarfile.py to tarfile.pyc
    byte-compiling C:\Python27\lib\tempfile.py to tempfile.pyc
    byte-compiling C:\Python27\lib\test\__init__.py to test\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\test
    byte-compiling C:\Python27\lib\test\test_support.py to test\test_support.pyc
    byte-compiling C:\Python27\lib\textwrap.py to textwrap.pyc
    byte-compiling C:\Python27\lib\threading.py to threading.pyc
    byte-compiling C:\Python27\lib\token.py to token.pyc
    byte-compiling C:\Python27\lib\tokenize.py to tokenize.pyc
    byte-compiling C:\Python27\lib\traceback.py to traceback.pyc
    byte-compiling C:\Python27\lib\tty.py to tty.pyc
    byte-compiling C:\Python27\lib\types.py to types.pyc
    byte-compiling C:\Python27\lib\urllib.py to urllib.pyc
    byte-compiling C:\Python27\lib\urllib2.py to urllib2.pyc
    byte-compiling C:\Python27\lib\urlparse.py to urlparse.pyc
    byte-compiling C:\Python27\lib\uu.py to uu.pyc
    byte-compiling C:\Python27\lib\uuid.py to uuid.pyc
    byte-compiling C:\Python27\lib\warnings.py to warnings.pyc
    byte-compiling C:\Python27\lib\weakref.py to weakref.pyc
    byte-compiling C:\Python27\lib\webbrowser.py to webbrowser.pyc
    byte-compiling C:\Python27\lib\whichdb.py to whichdb.pyc
    byte-compiling C:\Python27\lib\xml\__init__.py to xml\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\xml
    byte-compiling C:\Python27\lib\xml\parsers\__init__.py to xml\parsers\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\xml\parsers
    byte-compiling C:\Python27\lib\xml\parsers\expat.py to xml\parsers\expat.pyc
    byte-compiling C:\Python27\lib\zipfile.py to zipfile.pyc
    byte-compiling build\lib\nordicsemi\__init__.py to nordicsemi\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\nordicsemi
    byte-compiling build\lib\nordicsemi\dfu\__init__.py to nordicsemi\dfu\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\nordicsemi\dfu
    byte-compiling build\lib\nordicsemi\dfu\crc16.py to nordicsemi\dfu\crc16.pyc
    byte-compiling build\lib\nordicsemi\dfu\dfu.py to nordicsemi\dfu\dfu.pyc
    byte-compiling build\lib\nordicsemi\dfu\dfu_transport.py to nordicsemi\dfu\dfu_transport.pyc
    byte-compiling build\lib\nordicsemi\dfu\dfu_transport_serial.py to nordicsemi\dfu\dfu_transport_serial.pyc
    byte-compiling build\lib\nordicsemi\dfu\init_packet.py to nordicsemi\dfu\init_packet.pyc
    byte-compiling build\lib\nordicsemi\dfu\intelhex\__init__.py to nordicsemi\dfu\intelhex\__init__.pyc
    creating C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7\nordicsemi\dfu\intelhex
    byte-compiling build\lib\nordicsemi\dfu\intelhex\compat.py to nordicsemi\dfu\intelhex\compat.pyc
    byte-compiling build\lib\nordicsemi\dfu\manifest.py to nordicsemi\dfu\manifest.pyc
    byte-compiling build\lib\nordicsemi\dfu\model.py to nordicsemi\dfu\model.pyc
    byte-compiling build\lib\nordicsemi\dfu\nrfhex.py to nordicsemi\dfu\nrfhex.pyc
    byte-compiling build\lib\nordicsemi\dfu\package.py to nordicsemi\dfu\package.pyc
    byte-compiling build\lib\nordicsemi\dfu\signing.py to nordicsemi\dfu\signing.pyc
    byte-compiling build\lib\nordicsemi\dfu\util.py to nordicsemi\dfu\util.pyc
    byte-compiling build\lib\nordicsemi\exceptions.py to nordicsemi\exceptions.pyc
    byte-compiling build\lib\nordicsemi\version.py to nordicsemi\version.pyc
    *** copy extensions ***
    copying C:\Python27\DLLs\_ctypes.pyd -> C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7
    copying C:\Python27\DLLs\_hashlib.pyd -> C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7
    copying C:\Python27\DLLs\_socket.pyd -> C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7
    copying C:\Python27\DLLs\_ssl.pyd -> C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7
    copying C:\Python27\DLLs\_testcapi.pyd -> C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7
    copying C:\Python27\DLLs\bz2.pyd -> C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7
    copying C:\Python27\DLLs\pyexpat.pyd -> C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7
    copying C:\Python27\DLLs\select.pyd -> C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7
    copying C:\Python27\DLLs\unicodedata.pyd -> C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7
    *** copy dlls ***
    copying C:\WINDOWS\system32\CRYPT32.dll -> C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\collect-2.7
    copying C:\WINDOWS\system32\python27.dll -> C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\bundle-2.7
    setting sys.winver for 'C:\Python27\pc-nrfutil-0.3.0\build\bdist.win32\winexe\bundle-2.7\python27.dll' to 'nrfutil'
    copying C:\Python27\lib\site-packages\py2exe\run.exe -> C:\Python27\pc-nrfutil-0.3.0\0.3.0\nrfutil.exe
    Adding python27.dll as resource to C:\Python27\pc-nrfutil-0.3.0\0.3.0\nrfutil.exe
    The following modules appear to be missing
    ['Carbon', 'Carbon.Files', 'System', 'System.IO.Ports', '_datetime', '_imp', '_scproxy', '_sysconfigdata', 'colorama', 'dbm.dumb', 'dbm.gnu', 'dbm.ndbm', 'extern.six', 'gdbm', 'importlib.machinery', 'netbios', 'pkg_resources.extern.appdirs', 'pkg_resources.extern.packaging', 'pkg_resources.extern.six', 'pkg_resources.extern.six.moves', 'reprlib.recursive_repr', 'six.moves', 'test.support', 'win32pipe', 'win32wnet', '_thread.get_ident', 'winreg.CloseKey', 'winreg.HKEY_LOCAL_MACHINE', 'winreg.OpenKeyEx', 'winreg.QueryValueEx']
  • Hi.
    There could be problems in your PATH that might cause the issue, since you have multiple instances of different variables, and a odd number of  " also.
    I've tried to clean a bit up in your PATH. Could you first change you PATH to this:
    C:\WINDOWS;C:\WINDOWS\system32;C:\WINDOWS\System32\OpenSSH\;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\Program Files\CMake\bin;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\nodejs\;C:\Program Files\PuTTY\;C:\ProgramData\Oracle\Java\javapath;C:\Python27\;C:\Python27\Scripts;%PYTHON_HOME%";C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\Program Files (x86)\GnuWin32\bin\make;C:\Program Files (x86)\Nordic Semiconductor\nrf5x\bin\;C:\Program Files (x86)\Skype\Phone\;C:\Users\Shohidur\AppData\Local\Microsoft\WindowsApps;C:\Users\Shohidur\AppData\Roaming\npm;
    Then see if you get the -m and --mesh option from the command:
    nrfutilmesh dfu serial --help
    If you still dont get the -m and --mesh options I please follow these steps in this order:
    1. Delete all nrfutil files you have in :C\Python27
    2. Download this zip file called pc-nrfutil-mesh_dfu.zip.
    3. Unzip the zip file.
    4. Run the command: pip install --upgrade pip
    5. Run the command: pip install --upgrade setuptools
    6. Run the command: pip install -r requirements.txt
    7. Run the command: pip install http://sourceforge.net/projects/py2exe/files/latest/download?source=files
    8. Download and install VC compiler for Python.
    9. Run the command python setup.py install while you are inside the pc-nrfutil-mesh_dfu folder.
    10. Run the command python setup.py py2exe while you are inside the pc-nrfutil-mesh_dfu folder.
    - Andreas
    Now i am having this error:
    command : nrfutil dfu serial -pkg dfu_test.zip -p COM6 -b 115200 -fc --mesh
    Upgrading target on COM6 with DFU package C:\nordic_semi\nrf5_SDK_for_Mesh_v2.1.1\dfu_test\dfu_test.zip. Flow control is enabled.
    [------------------------------------] 0%
    Failed to upgrade target. Error is: ord() expected string of length 1, but int found
    Possible causes:
    - bootloader, SoftDevice or application on target does not match the requirements in the DFU package.
    - baud rate or flow control is not the same as in the target bootloader.
    - target is not in DFU mode. If using the SDK examples, press Button 4 and RESET and release both to enter DFU mode.
  • Thanks, finally it worked. The problem was with my DFU package. Which i created with different nrfutil. Now everything is good. Thanks for your kind support.
