pc_ble_driver_py.exceptions.NordicSemiException: No ping response after opening COM port
I was trying to run dfu mesh example according to this. I attempted quite few times but every time having an error at step 11.
infocenter.nordicsemi.com/index.jsp
Here is my environment details:
OS: windows 10
nrfutil version: 3.5.1
mesh SDK: Mesh_v2.1.1_src
Board : nrf52832
SDK version: 15
SoftDeive s132_6.0.0
step 1: Creating my own private key
 nrfutil.exe keys generate private.pem
Step2: Generated respective public key in hex format
nrfutil.exe keys display --key pk format code .\private.pem --out_file dfu_public_key.c
step 3: Added this key in the end of  "bootloader_config_default.json" file.
Step 4: Creating own signed image  package for dfu
nrfutil.exe pkg generate --hw-version 52 --application-version 4 --sd-req 0x00A8 --application C:\nordic_semi\nrf5_SDK_for_Mesh_v2.
1.1\bin\blinky\blinky_nrf52832_xxAA_s132_6.0.0.hex --key-file .\private.pem secure_dfu_mesh.zip
Step 5:  Generating device page with provided script as follow
python .\device_page_generator.py  -d nrf52832_xxAA -sd "s132_6.0.0"
Step 6:  flashing soft device:
nrfjprog --program C:\nordic_semi\nrf5_SDK_for_Mesh_v2.1.1\bin\softdevice\s132_nrf52_6.0.0_softdevice.hex --chiperase
step 7: Flash the serial bootloader on all devices:
nrfjprog --program C:\nordic_semi\nrf5_SDK_for_Mesh_v2.1.1\bin\bootloader\gccarmemb\mesh_bootloader_serial_gccarmemb_nrf52832_xxAA.hex
step 8: flashing application:
nrfjprog --program C:\nordic_semi\nrf5_SDK_for_Mesh_v2.1.1\examples\dfu\build\dfu_nrf52832_xxAA_s132_6.0.0_Debug\dfu_nrf52832_xxAA_s13
2_6.0.0.hex
Step 9: Flashing device page:
nrfjprog --program C:\nordic_semi\nrf5_SDK_for_Mesh_v2.1.1\tools\dfu\bin\device_page_nrf52832_xxAA_s132_6.0.0.hex
Step 10: Resetting
nrfjprog --reset
Step 11: Problematic one(Transfer the DFU archive over serial with nrfutil)
 nrfutil.exe dfu serial -pkg .\secure_dfu_mesh.zip -p COM15 -b 1200
 I have problem only on step 11
  • Hi.
    Could you post the error you get when you run the following commands:
    nrfjprog --program bin\softdevice\s132_nrf52_6.0.0_softdevice.hex --verify
    nrfjprog --program bin\bootloader\armcc\mesh_bootloader_serial_armcc_nrf52832_xxAA.hex --verify
    nrfjprog --program examples\dfu\build\dfu_nrf52832_xxAA_s132_6.0.0_Debug\dfu_nrf52832_xxAA_s132_6.0.0.hex --verify
    nrfjprog --program tools\dfu\bin\device_page_nrf52832_xxAA_s132_6.0.0.hex --verify
    nrfjprog --reset
    nrfutilmesh dfu serial -pkg dfu_test.zip -p COM6 -b 115200 -fc --mesh
    Make sure you are in the nrf5_SDK_for_Mesh_v2.1.1 folder when you do this.
    - Andreas
  • 1) I got identical error messages for all verification commands and that is:
    Parsing hex file.
    Reading flash area to program to guarantee it is erased.
    ERROR: The area to write is not erased.
    2) No error for  nrfjprog --reset
    3) the most problematic steps for me:
    Error: no such option: --mesh
    if i remove --mesh switch then i get following errors:
    Upgrading target on COM6 with DFU package C:\nordic_semi\nrf5_SDK_for_Mesh_v2.1.1\dfu_test\dfu_test.zip. Flow control is enabled.
    [------------------------------------] 0%
    Failed to upgrade target. Error is: Serial port could not be opened on COM6. Reason: could not open port u'COM6': WindowsError(2, 'The system cannot find the file specified.')
    Possible causes:
    - bootloader, SoftDevice or application on target does not match the requirements in the DFU package.
    - baud rate or flow control is not the same as in the target bootloader.
    - target is not in DFU mode. If using the SDK examples, press Button 4 and RESET and release both to enter DFU mode.
  • with correct port number i get following errors:
    Upgrading target on COM3 with DFU package C:\nordic_semi\nrf5_SDK_for_Mesh_v2.1.1\dfu_test\dfu_test.zip. Flow control is enabled.
    [------------------------------------] 0%Timed out waiting for acknowledgement from device.
    Failed to upgrade target. Error is: No data received on serial port. Not able to proceed.
    Possible causes:
  • i was reading this and found following lines:
    • Versions 1.5.0 and later generate modern firmware packages compatible with nRF SDK 12.0 and newer
    So i was wondering why you recommended me 0.3.0 ? As i am using sdk 15 should not i use  later version than your recommendation ?
    Could you write these two commands, and print the output:
    nrfutilmesh version
    nrfutilmesh dfu serial --help
    - Andreas
