pc_ble_driver_py.exceptions.NordicSemiException: No ping response after opening COM port
I was trying to run dfu mesh example according to this. I attempted quite few times but every time having an error at step 11.
infocenter.nordicsemi.com/index.jsp
Here is my environment details:
OS: windows 10
nrfutil version: 3.5.1
mesh SDK: Mesh_v2.1.1_src
Board : nrf52832
SDK version: 15
SoftDeive s132_6.0.0
step 1: Creating my own private key
 nrfutil.exe keys generate private.pem
Step2: Generated respective public key in hex format
nrfutil.exe keys display --key pk format code .\private.pem --out_file dfu_public_key.c
step 3: Added this key in the end of  "bootloader_config_default.json" file.
Step 4: Creating own signed image  package for dfu
nrfutil.exe pkg generate --hw-version 52 --application-version 4 --sd-req 0x00A8 --application C:\nordic_semi\nrf5_SDK_for_Mesh_v2.
1.1\bin\blinky\blinky_nrf52832_xxAA_s132_6.0.0.hex --key-file .\private.pem secure_dfu_mesh.zip
Step 5:  Generating device page with provided script as follow
python .\device_page_generator.py  -d nrf52832_xxAA -sd "s132_6.0.0"
Step 6:  flashing soft device:
nrfjprog --program C:\nordic_semi\nrf5_SDK_for_Mesh_v2.1.1\bin\softdevice\s132_nrf52_6.0.0_softdevice.hex --chiperase
step 7: Flash the serial bootloader on all devices:
nrfjprog --program C:\nordic_semi\nrf5_SDK_for_Mesh_v2.1.1\bin\bootloader\gccarmemb\mesh_bootloader_serial_gccarmemb_nrf52832_xxAA.hex
step 8: flashing application:
nrfjprog --program C:\nordic_semi\nrf5_SDK_for_Mesh_v2.1.1\examples\dfu\build\dfu_nrf52832_xxAA_s132_6.0.0_Debug\dfu_nrf52832_xxAA_s13
2_6.0.0.hex
Step 9: Flashing device page:
nrfjprog --program C:\nordic_semi\nrf5_SDK_for_Mesh_v2.1.1\tools\dfu\bin\device_page_nrf52832_xxAA_s132_6.0.0.hex
Step 10: Resetting
nrfjprog --reset
Step 11: Problematic one(Transfer the DFU archive over serial with nrfutil)
 nrfutil.exe dfu serial -pkg .\secure_dfu_mesh.zip -p COM15 -b 1200
 I have problem only on step 11
  • 1) nrfutilmesh version:
    nrfutil version 0.3.0
    2) nrfutilmesh dfu serial --help:
    Usage: nrfutilmesh dfu serial [OPTIONS]
    Program a device with bootloader that support serial DFU
    Options:
    -pkg, --package PATH DFU package filename [required]
    -p, --port TEXT Serial port COM Port to which the device is
    connected [required]
    -b, --baudrate INTEGER Desired baud rate 38400/96000/115200/230400/250000/4
    60800/921600/1000000 (default: 38400). Note:
    Physical serial ports (e.g. COM1) typically do not
    support baud rates > 115200
    -fc, --flowcontrol Enable flow control, default: disabled
    --help Show this message and exit.
  • Hi.
    It seems to be something missing from nrfutilmesh, you should also have the options -i, --interval, m, and --mesh.
    Could you download the nrfutilmesh zip folder again, use this link
    Unzip the zip folder, and run the command pip.exe install -r requirements.txt inside the folder.
    Does it state that all requirements are already satisfied?
    - Andreas
  • Thank you for your support. While installing nrfutilmesh following step was not sucessfull:
    To generate a self-contained Windows exe version of the utility (Windows only):
    python setup.py py2exe
    It was giving following error:
    running py2exe
    error: bundle-files 1 not yet supported on win64
    However it was creating nrfutil.exe file.
    And yes, pip.exe install -r requirements.txt states that all requirements already satisfied.
    Seems we are getting close to resolve the issue, i would really appreciate your effort until we solve it. Please help me to solve the issue.
    Thanks
  • Hi, are you using Windows or Ubuntu now?
    You need Windows to use py2exe.
    Download the win32 version here from SourceForge as listed in the prerequisites for Windows on GitHub.
    Also download the VC Python compiler from Microsoft.com.
    Install both these and try the installation steps again.
    - Andreas
  • I installed nrfutil version 0.3.0 but still can not see other options as you were pointing out. Below is my installation procedure:
    Step 1: I installed latest version (nrfutil version 3.5.1) :
    pip install nrfutil
    Step2: update pip by following command:
    python -m pip install --upgrade pip
    Step3: moving nrfutil and nrfutil-script from installed folder to desktop
    Step4: Manually Downloading zip file(pc-nrfutil-0.3.0.zip) for version and unzipping it under "C:\Python27\pc-nrfutil-0.3.0"
    Step5: Executing all pre-requisites commands from directory "C:\Python27\pc-nrfutil-0.3.0"
    Step6: navigating to "C:\Python27\pc-nrfutil-0.3.0"
    Step7:
    python setup.py install
    Step8: Renaming nrfutil to nrfutilmesh and nrfutil-script to nrfutilmesh-script
    Step9: Finally moving nrfutil and nrfutilmesh-script back to installed directory
