pc_ble_driver_py.exceptions.NordicSemiException: No ping response after opening COM port
I was trying to run dfu mesh example according to this. I attempted quite few times but every time having an error at step 11.
infocenter.nordicsemi.com/index.jsp
Here is my environment details:
OS: windows 10
nrfutil version: 3.5.1
mesh SDK: Mesh_v2.1.1_src
Board : nrf52832
SDK version: 15
SoftDeive s132_6.0.0
step 1: Creating my own private key
 nrfutil.exe keys generate private.pem
Step2: Generated respective public key in hex format
nrfutil.exe keys display --key pk format code .\private.pem --out_file dfu_public_key.c
step 3: Added this key in the end of  "bootloader_config_default.json" file.
Step 4: Creating own signed image  package for dfu
nrfutil.exe pkg generate --hw-version 52 --application-version 4 --sd-req 0x00A8 --application C:\nordic_semi\nrf5_SDK_for_Mesh_v2.
1.1\bin\blinky\blinky_nrf52832_xxAA_s132_6.0.0.hex --key-file .\private.pem secure_dfu_mesh.zip
Step 5:  Generating device page with provided script as follow
python .\device_page_generator.py  -d nrf52832_xxAA -sd "s132_6.0.0"
Step 6:  flashing soft device:
nrfjprog --program C:\nordic_semi\nrf5_SDK_for_Mesh_v2.1.1\bin\softdevice\s132_nrf52_6.0.0_softdevice.hex --chiperase
step 7: Flash the serial bootloader on all devices:
nrfjprog --program C:\nordic_semi\nrf5_SDK_for_Mesh_v2.1.1\bin\bootloader\gccarmemb\mesh_bootloader_serial_gccarmemb_nrf52832_xxAA.hex
step 8: flashing application:
nrfjprog --program C:\nordic_semi\nrf5_SDK_for_Mesh_v2.1.1\examples\dfu\build\dfu_nrf52832_xxAA_s132_6.0.0_Debug\dfu_nrf52832_xxAA_s13
2_6.0.0.hex
Step 9: Flashing device page:
nrfjprog --program C:\nordic_semi\nrf5_SDK_for_Mesh_v2.1.1\tools\dfu\bin\device_page_nrf52832_xxAA_s132_6.0.0.hex
Step 10: Resetting
nrfjprog --reset
Step 11: Problematic one(Transfer the DFU archive over serial with nrfutil)
 nrfutil.exe dfu serial -pkg .\secure_dfu_mesh.zip -p COM15 -b 1200
 I have problem only on step 11
  • Hi.
    Do you still get the error Error: no such option: --mesh when you use the command:
    nrfutilmesh dfu serial -pkg dfu_test.zip -p <YOUR COM PORT> -b 115200 -fc --mesh
    Could you also post your output for the command:
    nrfutilmesh dfu serial --help:
    You should have the right options now. And are you using Windows or Ubuntu now?
    - Andreas
  • yes still i have Error: no such option: --mesh.
    Usage: nrfutilmesh dfu serial [OPTIONS]
    Program a device with bootloader that support serial DFU
    Options:
    -pkg, --package PATH DFU package filename [required]
    -p, --port TEXT Serial port COM Port to which the device is
    connected [required]
    -b, --baudrate INTEGER Desired baud rate 38400/96000/115200/230400/250000/
    460800/921600/1000000 (default: 38400). Note:
    Physical serial ports (e.g. COM1) typically do not
    support baud rates > 115200
    -fc, --flowcontrol Enable flow control, default: disabled
    --help Show this message and exit.
    I am using windows 10
  • Hi.
    I've been trying to reproduce your error, but I need a bit more time.
    In the mean time, could you perhaps try the command:
    Using the nrfutilmesh I've installed in my Python2.7 folder? I've added two files to a zip libary, copy both files into your \Python27\Scripts folder.
    If you now get the options --mesh and -m, try the command:
    nrfutilmesh.zip
    - Andreas
    I copied your provided files under mentioned directory and replaced existing file. But still i am not getting other options as you mentioned. If you need further details for reproducing the problem, i can send you the screen shot of my details installation.
  • Hi.
    Can you do all the installation steps one more time, that is, steps 1 to 6.
    After you have finished, could you compare the files you now have installed, that is nrfutilmesh-script.py and nrfutilmesh.exe to the two files I've sent you, by running the command in cmd:
    FC [pathname1] [pathname2]
    Where [pathname1] is the path to the file you installed, and [pathname2] is the path to the file i sent you. And please post the result.
    -- Andreas
