pc_ble_driver_py.exceptions.NordicSemiException: No ping response after opening COM port
I was trying to run dfu mesh example according to this. I attempted quite few times but every time having an error at step 11.
infocenter.nordicsemi.com/index.jsp
Here is my environment details:
OS: windows 10
nrfutil version: 3.5.1
mesh SDK: Mesh_v2.1.1_src
Board : nrf52832
SDK version: 15
SoftDeive s132_6.0.0
step 1: Creating my own private key
 nrfutil.exe keys generate private.pem
Step2: Generated respective public key in hex format
nrfutil.exe keys display --key pk format code .\private.pem --out_file dfu_public_key.c
step 3: Added this key in the end of  "bootloader_config_default.json" file.
Step 4: Creating own signed image  package for dfu
nrfutil.exe pkg generate --hw-version 52 --application-version 4 --sd-req 0x00A8 --application C:\nordic_semi\nrf5_SDK_for_Mesh_v2.
1.1\bin\blinky\blinky_nrf52832_xxAA_s132_6.0.0.hex --key-file .\private.pem secure_dfu_mesh.zip
Step 5:  Generating device page with provided script as follow
python .\device_page_generator.py  -d nrf52832_xxAA -sd "s132_6.0.0"
Step 6:  flashing soft device:
nrfjprog --program C:\nordic_semi\nrf5_SDK_for_Mesh_v2.1.1\bin\softdevice\s132_nrf52_6.0.0_softdevice.hex --chiperase
step 7: Flash the serial bootloader on all devices:
nrfjprog --program C:\nordic_semi\nrf5_SDK_for_Mesh_v2.1.1\bin\bootloader\gccarmemb\mesh_bootloader_serial_gccarmemb_nrf52832_xxAA.hex
step 8: flashing application:
nrfjprog --program C:\nordic_semi\nrf5_SDK_for_Mesh_v2.1.1\examples\dfu\build\dfu_nrf52832_xxAA_s132_6.0.0_Debug\dfu_nrf52832_xxAA_s13
2_6.0.0.hex
Step 9: Flashing device page:
nrfjprog --program C:\nordic_semi\nrf5_SDK_for_Mesh_v2.1.1\tools\dfu\bin\device_page_nrf52832_xxAA_s132_6.0.0.hex
Step 10: Resetting
nrfjprog --reset
Step 11: Problematic one(Transfer the DFU archive over serial with nrfutil)
 nrfutil.exe dfu serial -pkg .\secure_dfu_mesh.zip -p COM15 -b 1200
 I have problem only on step 11
  • Hi.
    There could be problems in your PATH that might cause the issue, since you have multiple instances of different variables, and a odd number of  " also.
    I've tried to clean a bit up in your PATH. Could you first change you PATH to this:
    C:\WINDOWS;C:\WINDOWS\system32;C:\WINDOWS\System32\OpenSSH\;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\Program Files\CMake\bin;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\nodejs\;C:\Program Files\PuTTY\;C:\ProgramData\Oracle\Java\javapath;C:\Python27\;C:\Python27\Scripts;%PYTHON_HOME%";C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\Program Files (x86)\GnuWin32\bin\make;C:\Program Files (x86)\Nordic Semiconductor\nrf5x\bin\;C:\Program Files (x86)\Skype\Phone\;C:\Users\Shohidur\AppData\Local\Microsoft\WindowsApps;C:\Users\Shohidur\AppData\Roaming\npm;
    Then see if you get the -m and --mesh option from the command:
    nrfutilmesh dfu serial --help
    If you still dont get the -m and --mesh options I please follow these steps in this order:
    1. Delete all nrfutil files you have in :C\Python27
    2. Download this zip file called pc-nrfutil-mesh_dfu.zip.
    3. Unzip the zip file.
    4. Run the command: pip install --upgrade pip
    5. Run the command: pip install --upgrade setuptools
    6. Run the command: pip install -r requirements.txt
    7. Run the command: pip install http://sourceforge.net/projects/py2exe/files/latest/download?source=files
    8. Download and install VC compiler for Python.
    9. Run the command python setup.py install while you are inside the pc-nrfutil-mesh_dfu folder.
    10. Run the command python setup.py py2exe while you are inside the pc-nrfutil-mesh_dfu folder.
    - Andreas
    Now i am having this error:
    command : nrfutil dfu serial -pkg dfu_test.zip -p COM6 -b 115200 -fc --mesh
    Upgrading target on COM6 with DFU package C:\nordic_semi\nrf5_SDK_for_Mesh_v2.1.1\dfu_test\dfu_test.zip. Flow control is enabled.
    [------------------------------------] 0%
    Failed to upgrade target. Error is: ord() expected string of length 1, but int found
    Possible causes:
    - bootloader, SoftDevice or application on target does not match the requirements in the DFU package.
    - baud rate or flow control is not the same as in the target bootloader.
    - target is not in DFU mode. If using the SDK examples, press Button 4 and RESET and release both to enter DFU mode.
  • Thanks, finally it worked. The problem was with my DFU package. Which i created with different nrfutil. Now everything is good. Thanks for your kind support.
