How to use bsp_event_to_button_action_assign function to assign long push action to an event?
Hi Everyone
I have been trying to do some simple led blinking by generating events , however i need to do that if a button_0 is pressed for some duration.
Here is a code that i have been trying to use without any success.
Thanks
Rajat!
 * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup bsp_example_main main.c
 * @ingroup bsp_example
 * @brief BSP Example Application main file.
#include <stdbool.h>
#include <stdint.h>
#include "boards.h"
#include "bsp.h"
#include "app_timer.h"
#include "nordic_common.h"
#include "nrf_error.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define BUTTON_PREV_ID           0                           /**< Button used to switch the state. */
#define BUTTON_NEXT_ID           1                           /**< Button used to switch the state. */
static bsp_indication_t actual_state =  BSP_INDICATE_FIRST;         /**< Currently indicated state. */
#define BUTTON2     NRF_GPIO_PIN_MAP(0,12)
static const char * indications_list[] = BSP_INDICATIONS_LIST;
#define BTN_ACTION_LONG     BSP_BUTTON_ACTION_LONG_PUSH
void bsp_evt_handler(bsp_event_t evt)
    uint32_t err_code;
    switch (evt)
        case BSP_EVENT_KEY_0:
              nrf_gpio_pin_toggle(13);
        case BSP_EVENT_KEY_1:
              nrf_gpio_pin_toggle(14);
         case BSP_EVENT_KEY_2:
              nrf_gpio_pin_toggle(15);
        case BSP_EVENT_KEY_3:
              nrf_gpio_pin_toggle(16);
            return; // no implementation needed
/**@brief Function for initializing low frequency clock.
void clock_initialization()
    NRF_CLOCK->LFCLKSRC            = (CLOCK_LFCLKSRC_SRC_Xtal << CLOCK_LFCLKSRC_SRC_Pos);
    NRF_CLOCK->TASKS_LFCLKSTART    = 1;
    while (NRF_CLOCK->EVENTS_LFCLKSTARTED == 0)
        // Do nothing.
/**@brief Function for initializing bsp module.
void bsp_configuration()
    uint32_t err_code;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_evt_handler);
 * @brief Function for application main entry.
    bool pressed;
    clock_initialization();
    uint32_t err_code = app_timer_init();
    bsp_event_to_button_action_assign(BUTTON_1,BTN_ACTION_LONG,  BSP_EVENT_KEY_0);
    bsp_configuration();
    while (true)
        NRF_LOG_FLUSH();
        __SEV();
        __WFE();
        __WFE();
  • Here's an update ,
    I am able to detect the LONG PUSH EVENT , but there's an issue.
    Whenever i am pressing the button the BSP_EVENT_KEY_0 events gets generated first and then when the LONG PUSH EVENT timeout reaches then the L0NG_PUSH_EVENT is generated.
    It goes like this:
    I press and hold the button , the expected print statement should be
    LONG PRESSED .
    But instead it comes out like this
    SHORT PRESSED
    LONG PRESSED(prints after timeout is reached)
    How can i tackle this issue?
    Thanks
    Rajat!
  • This is what i am expecting to do:
    if i press a button and release it , it should print "SHORT PRESSED"
    If i press and hold a button for sometime , then it should print "LONG PRESSED"
  • Hi!
    Did you make any progress on your issue?
    You could simply add a new event to the bsp_event_t enum in the bsp.h file.
    ie. BSP_EVENT_LONG_TEST
    and change your code to;
        uint32_t err_code;
        switch (evt)
            case BSP_EVENT_LONG_TEST:
    and;
        bool pressed;
        bsp_event_to_button_action_assign(BUTTON_1,BTN_ACTION_LONG,  BSP_EVENT_LONG_TEST);
    This should make your defined button output only the "LONG PRESSED".
    Let me know if you have further questions.
    Joakim.
