I am trying to build a system with a single PRX and up to 5 PTX devices. Initial development work was done with a single PTX with it's address on Pipe0 in the PRX. I have communications working as expected.
I now have two PTX devices. Device 1 is on the PRX Pipe0 address. Device 2 is on the PRX Pipe1 address.
I have setup my application with #defines that allow me to easily rebuild the PRX with Pipe0 ONLY enabled, Pipe0 and Pipe1 enabled, or all pipes enabled.
If I enable only Pipe0 on the PRX, I can communicate with device that matches the Pipe0 address.
If I enable Pipe0 and Pipe1 on the PRX, I can communiate ONLY with the device that matches the Pipe1 address. If I only have the device that matches the Pipe0 address running, the PRX always reports no data in any pipe, and the Rx FIFO is always empty.
I am running Enhanced Shockburst, Auto Ack with payload, and Dynamic payload length.
Can anyone offer some insight into what is going on here?
Please see below for the register setups:
3000 79 !!!!!! Start Radio Initialization !!!!!!
3000 135 PIPE0 Only
3000 161 Rx Addr0: JDXY1
3000 193
3000 208 CONFIG: 0x0B EN_AA: 0x01 EN_RXADDR: 0x01
3000 268 SETUP_AW: 0x03 SETUP_RETR: 0x13 RF_CH: 0x02
3050 58 Status: 0x0E OBSERVE_TX: 0x00 RPD: 0x00
3100 55 Rx Addr0: JDXY1 Rx Addr1: JDTB2 Rx Addr2: 3
3150 56 Rx Addr3: 4 Rx Addr4: 5 Rx Addr5: 6
3200 46 Tx Addr: JDTB1
3250 25 FIFO Status: 0x11 DYNPD: 0x01 FEATURE: 0x06
3250 88 !!!!!! Radio Initialization Complete !!!!!!
Receives packets from JDXY1
3000 135 PIPE0 PIPE1
3000 162 Rx Addr0: JDXY1 Rx Addr1: JDTB2
3000 210
3000 225 CONFIG: 0x0B EN_AA: 0x03 EN_RXADDR: 0x03
3000 286 SETUP_AW: 0x03 SETUP_RETR: 0x13 RF_CH: 0x02
3100 55 Rx Addr0: JDXY1 tRx Addr1: JDTB2 Rx Addr2: 3
3250 25 FIFO Status: 0x11 DYNPD: 0x03 FEATURE: 0x06
Does NOT receive packets from JDXY1 DOES receive packetsfrom JDTB2
