Not able to read the register values from external sensor using the nrf_drv_twi_tx and nrf_drv_twi_rx functions in the twisensor example.
I have been trying to read the register values, from BNO_080, using the functions nrf_drv_twi_tx to write and nrf_drv_twi_rx to read. But for some reason, i have been getting a constant value as the output, when i try to see them on the serial monitor. I have attached my code below. I have put a flag after every function, but for some reason, it does not go into the flag , the one after the read_sensor_data() in the int main().
Any information why?
#define SHTP_REPORT_COMMAND_RESPONSE 0xF1
#define SHTP_REPORT_COMMAND_REQUEST 0xF2
#define SHTP_REPORT_FRS_READ_RESPONSE 0xF3
#define SHTP_REPORT_FRS_READ_REQUEST 0xF4
#define SHTP_REPORT_PRODUCT_ID_RESPONSE 0xF8
#define SHTP_REPORT_PRODUCT_ID_REQUEST 0xF9
#define SHTP_REPORT_BASE_TIMESTAMP 0xFB
#define SHTP_REPORT_SET_FEATURE_COMMAND 0xFD
/* TWI instance ID. */
#define TWI_INSTANCE_ID     0
#define TRANSACTION_QUEUE_SIZE 5
#define BNO_080  0x4B         							//the BNO_080 address, which gets toggled when we call the tx or rx functions to either 1 or a 0//
#define SENSOR_REPORTID_GAME_ROTATION_VECTOR 0x08       //this is the register data, which we are trying to send out//
#define SENSOR_REPORTID_ACCELEROMETER 0x01
#define SENSOR_REPORTID_GYROSCOPE 0x02
#define SENSOR_REPORTID_MAGNETIC_FIELD 0x03
#define SENSOR_REPORTID_LINEAR_ACCELERATION 0x04
#define SENSOR_REPORTID_ROTATION_VECTOR 0x05
#define SENSOR_REPORTID_GRAVITY 0x06
#define SENSOR_REPORTID_GEOMAGNETIC_ROTATION_VECTOR 0x09
#define SENSOR_REPORTID_TAP_DETECTOR 0x10
#define SENSOR_REPORTID_STEP_COUNTER 0x11
#define SENSOR_REPORTID_STABILITY_CLASSIFIER 0x13
#define SENSOR_REPORTID_PERSONAL_ACTIVITY_CLASSIFIER 0x1E
/* Indicates if operation on TWI has ended. */
static volatile bool m_xfer_done = false;
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
uint8_t address = SENSOR_REPORTID_STEP_COUNTER;
void BNO_080_set_mode(void)
    ret_code_t err_code;
    uint8_t reg[2] = {SHTP_REPORT_PRODUCT_ID_REQUEST, 0b00000000};
    err_code = nrf_drv_twi_tx(&m_twi, BNO_080, reg, sizeof(reg), false);
    while (m_xfer_done == false);
    reg[0] = SHTP_REPORT_PRODUCT_ID_RESPONSE;
    err_code = nrf_drv_twi_tx(&m_twi, BNO_080, reg, 1, false);
__STATIC_INLINE void data_handler(uint8_t address)
    NRF_LOG_INFO("Data: %d.\r\n", address);
    NRF_LOG_FLUSH();
 * @brief TWI events handler.
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
    switch (p_event->type)
        case NRF_DRV_TWI_EVT_DONE:
            if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
                data_handler(address);
            m_xfer_done = true;
 * @brief UART initialization.
void twi_init (void)
    const nrf_drv_twi_config_t twi_bno080_config = {
            .scl                = 27,
            .sda                = 26,
            .frequency          = NRF_DRV_TWI_FREQ_400K,
            .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
            .clear_bus_init     = false
    err_code = nrf_drv_twi_init(&m_twi, &twi_bno080_config, twi_handler, NULL);
    nrf_drv_twi_enable(&m_twi);
 * @brief Function for reading data.
static void read_sensor_data(void)
    ret_code_t err_code = nrf_drv_twi_rx(&m_twi, BNO_080, &address, sizeof(address));
//    ret_code_t err_code;
//    err_code = nrf_drv_twi_tx(&m_twi, BNO_080, &address, 1, true);
//    if (NRF_SUCCESS == err_code)
//        err_code = nrf_drv_twi_rx(&m_twi, BNO_080, dataValue, 12, false);
//    APP_ERROR_CHECK(err_code);
    NRF_LOG_INFO("FLAG 1:\r\n");
    NRF_LOG_FLUSH();
    twi_init();
    NRF_LOG_INFO("Flag 2:\r\n");
    NRF_LOG_FLUSH();
    BNO_080_set_mode();
    NRF_LOG_INFO("Flag 3: \r\n");
    NRF_LOG_FLUSH();
    while (true)
        nrf_delay_ms(500);
        do
            __WFE();
        read_sensor_data();
        NRF_LOG_INFO("Flag4:\r\n")
        NRF_LOG_FLUSH();
  • What do you mean by this: "But for some reason, i have been getting temperature values as the output"?
    The BNO_080 seems to be a IMU sensor, it should not give you temperature values?
  • What i mean by this was, i am getting a constant value, when i try to write to the BNO_080_DEFAULT_ADDRESS and then read the output and store it in the buffer. I came to know, i need to run a shtp protocol, on top of the twi interface. Because, every time i try to read some register, i get either the same value which i am sending (writing) through the nrf_drv_twi_tx command, at the receiver end (serial monitor) or i get some value which is not exactly readable. Do you have any knowledge, how should i tackle this problem?
  • I do not know what protocol or commands your sensor expects, this you will have to read from the datasheet of the device. However, it looks like your read_sensor_data function only calls nrf_drv_twi_rx, and not nrf_drv_twi_tx. Normally I2C/TWI devices expect some register to be written, to know what will be output, and then you can read the output. I see you have some commented commands as well, but you do not seem to have any sync between the calls to make sure the previous transfer is completed. The TWI driver will work in non-blocking mode if you pass a callback handler to the init function. You then need to wait for a transfer to finish using 'while (m_xfer_done == false);' before starting next transfer.
  • #include <stdio.h>
    #include "boards.h"
    #include "app_error.h"
    #include "nrf_drv_twi.h"
    #include "nrf_delay.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    /* TWI instance. */
    uint8_t address = SENSOR_REPORTID_GAME_ROTATION_VECTOR;
    uint8_t buffer[10];
        uint8_t reg[2] = {SENSOR_REPORTID_GAME_ROTATION_VECTOR, 0x00};
    //    uint8_t reg1[2] = {SENSOR_REPORTID_ACCELEROMETER, 0x00};
    //    uint8_t reg2[2] = {SENSOR_REPORTID_LINEAR_ACCELERATION, 0x00};
    //    err_code = nrf_drv_twi_tx(&m_twi, BNO_080, reg1, sizeof(reg1), false);
    //    while (m_xfer_done == false);
    //    err_code = nrf_drv_twi_tx(&m_twi, BNO_080, reg2, sizeof(reg2), false);
    __STATIC_INLINE void data_handler(uint8_t buffer)
        NRF_LOG_INFO("Data: %x.\r\n", &buffer);
        NRF_LOG_FLUSH();
                    data_handler(buffer);
                m_xfer_done = true;
                .scl                = 27,
                .sda                = 26,
                .frequency          = NRF_DRV_TWI_FREQ_100K,
        err_code = nrf_drv_twi_rx(&m_twi, BNO_080, &buffer, sizeof(buffer));
        twi_init();
        BNO_080_set_mode();
        while (true)
            nrf_delay_ms(200);
            do
                __WFE();
            read_sensor_data();
            NRF_LOG_INFO("Flag4: %x \r\n", buffer);
            NRF_LOG_FLUSH();
    Here is my code right now, and i still am getting one constant value, i.e.
    <info> app: Data: 2003FE57.
    <error> app: Fatal error
    <warning> app: System reset
    <info> app: Flag4⸮J⸮⸮⸮⸮
    ⸮⸮⸮2⸮⸮⸮⸮⸮⸮⸮⸮⸮’⸮j
  • You are printing the address of the data variable on line 70, not the actual data. Change the line from:
    to:
    NRF_LOG_INFO("Data: %x.\r\n", buffer);
    You also seems to have a global variable called buffer. You should change one of the variable names to avoid confusion with regards to which variable is referenced.
