I am using ADC without external reference and no analog input in order to measure the battery level with a timer (code at the end).
I am also reading several ports state using the buttons library.
Everything works fine, except ports 26, 27 and 28 when I am actually turning the ADC on, even tough I am configuring the NRF->CONFIG to not use any analog input. (And the case about port 28 is even more rare, since it is just a regular IO)
What am I doing wrong?
Thanks!
init code:
static void bams_adc_init(void)
/* Enable interrupt on ADC sample ready event*/
NRF_ADC->INTENSET = ADC_INTENSET_END_Msk;
sd_nvic_SetPriority(ADC_IRQn, NRF_APP_PRIORITY_LOW);
sd_nvic_EnableIRQ(ADC_IRQn);
NRF_ADC->CONFIG = (ADC_CONFIG_EXTREFSEL_None << ADC_CONFIG_EXTREFSEL_Pos) /* Bits 17..16 : ADC external reference pin selection. */
| (ADC_CONFIG_PSEL_Disabled << ADC_CONFIG_PSEL_Pos) /*!< No analog input as analog input. */
| (ADC_CONFIG_REFSEL_VBG << ADC_CONFIG_REFSEL_Pos) /*!< Use internal 1.2V bandgap voltage as reference for conversion. */
| (ADC_CONFIG_INPSEL_SupplyOneThirdPrescaling << ADC_CONFIG_INPSEL_Pos) /*!< VDD specified by PSEL with 1/3 prescaling used as input for the conversion. */
| (ADC_CONFIG_RES_8bit << ADC_CONFIG_RES_Pos); /*!< 8bit ADC resolution. */
/* Enable ADC*/
NRF_ADC->ENABLE = ADC_ENABLE_ENABLE_Enabled;
