UART pin should not use AIN pin
I init the UART pin with the AIN pin such as P0.05, but the program will run into __WEAK void app_error_fault_handler(uint32_t id, uint32_t pc, uint32_t info) every time. Is there anyone experience this problem, any suggestion or response is appreciated.
following is the uart init funciton.
static void uart_init(void)
uint32_t err_code;
.rx_pin_no = RX_PIN_NUMBER,
.tx_pin_no = TX_PIN_NUMBER,
.rts_pin_no = RTS_PIN_NUMBER,
.cts_pin_no = CTS_PIN_NUMBER,
.use_parity = false,
#if defined (UART_PRESENT)
.baud_rate = NRF_UART_BAUDRATE_115200
#else
.baud_rate = NRF_UARTE_BAUDRATE_115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
  • Hi Martin,
    Thank you very much for your answer, I follow the debug steps and trace the error code, it seems that the error code number is NRF_ERROR_DATA_SIZE(Invalid Data size), see the below shot, can you point out what's wrong with the data size in my code?  and I attached the zip files which is used for uart1 application.
    app_uart1.zip
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    static void uart1_init(void)
    uint32_t err_code;
    app_uart1_comm_params_t const comm_params =
    .rx_pin_no = 5,//14,
    .tx_pin_no = 6,//16,
    .rts_pin_no = 255,
    .cts_pin_no = 255,
    .flow_control = APP_UART1_FLOW_CONTROL_DISABLED,
    #else
    APP_UART1_FIFO_INIT(&comm_params,
    UART_RX_BUF_SIZE,
    UART_TX_BUF_SIZE,
    uart1_event_handle,
    err_code);
    uint32_t err_code;
    #else
    UART_RX_BUF_SIZE,
    UART_TX_BUF_SIZE,
    uart_event_handle,
    err_code);
    bool erase_bonds;
    // Initialize.
    uart_init();
    uart1_init();
    log_init();
    timers_init();
