i'm using the sdk only for ble serial data transfer, which i'm not using for this pwm test
all code talks directly to the hw registers
those are some code snippets to show the setup
init funct :
PSEL_OUT [0] = 11 // port bit 11
PSEL_OUT [1] = 0
PSEL_OUT [2] = 0
PSEL_OUT [3] = 0
ENABLE = 1
COUNTER_TOP = 0x03ff // not needed for wafeform
MODE = PWM_MODE_UPDOWN_Up
PRESCALER = div // div = 5, divide by 32
LOOP = PWM_LOOP_CNT_Disabled
DECODER = PWM_DECODER_LOAD_WaveForm |
PWM_DECODER_MODE_RefreshCount << PWM_DECODER_MODE_Pos
pwm data struct and values :
typedef struct { /* easy-dma cfg */
ushort Dat0 ; /* pwm 0 */
ushort Dat1 ; /* pwm 1 */
ushort Dat2 ; /* pwm 2 */
ushort Dat3 ; /* pwm 3, freq */
} PACKED Data_t ;
union { /* some previous data member causes mis-alignment */
ushort Align ;
Data_t Data ;
Dat0 = 15000 >> div // prescale div = 5
Dat1 = 0
Dat1 = 0
Dat3 = 50000 >> div
pwm run funct :
void TPwm::Run (eSeq_t seq) const
PWM_SEQ_Type *ps = &pDev->SEQ [seq] ;
ps->PTR = (uint32_t) &Data ;
ps->CNT = sizeof (Data) / sizeof (ushort) ;
ps->REFRESH = 0 ;
ps->ENDDELAY = 0 ;
pDev->TASKS_SEQSTART [seq] = 1 ;
what am i missing ???
i want the ability to update pwm waveform by updating the Data_t values and calling Pwm.Run (seq) at any time i need to
for the test i call it once and it displays the proper waveform for about 1 - 2 seconds and stops until i call it again and again via input monitor cmds
thanks and cheers efiLabs
