I am a newbie to BLE and starting with nordic ble chip. I downloaded SDK 15.0.1, is there any proper document explaining SDK directory structure.
Thanks
Thanks
There is no description for directories.
Earlier, i've worked with ATmel BitCloud SDK for ATmega128RFA1 and ATSAMR21G18A.
They have provided proper explanation. Here it's quite confusing.
I think what you are looking for is an explanation of the different folders in the SDK and what their contents are. As far as I'm aware this does not exist (I've also tried looking for it when I started out). Below is a short explanation of the main folders. Note I'm also a beginner and this reflects what (I think) I've understood so far
Components: Code for the different peripherals on-board the Nordic IC's
Config: Configuration files for IC's
Documentation: Some license files, images, change history of the SDK & links to the infocenter documentation (as linked by Andreas)
Examples: All the examples in the SDK
External: Some software compatible with nRF chips made by external sources (e.g. RTOS, file system)
External_tools: Tools to ease development (only cmsis in 15.0.0, used by some IDE's to modify sdk_config.h easily)
Integration: Mostly legacy drivers
Modules: Driver files for on-board peripherals
The examples incorporate the solution and hex-file for each example. The solutions link to the other folders to get the used modules/components/etc. Any documentation on how to use the drivers and develop is in the infocenter.
I hope this can help you further a bit.
Thanks for the reply.
One more question, I know you are also a beginner and i'm asking the question without even trying - If I want to create my custom project how can I do that using the Nordic SDK.
If I want to use UART to communicate to a sensor, BLE to send data to Gateway. How to create this project ?
I hope I was able to convey my message.
