IAR Error[Pe020]: identifier "NRFX_TIMER1_INST_IDX" is undefined
I am using the NRF52-DK softdevice 6.0.0 and NRF SDK 15.0.The app is based on on the saadc PCA10040 S112. I want to add static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(1); in my main.c
in sdk_config.h I then setup :
#define NRFX_TIMER_ENABLED 1
#define NRFX_TIMER1_ENABLED 1
If I compile, I have the following issue :
Could you please explain me what is my mistake?Thanks
  • Try to set TIMER_ENABLED and TIMER1_ENABLED to 1 instead:
    #ifndef TIMER_ENABLED
    #define TIMER_ENABLED 1
    #ifndef TIMER1_ENABLED
    #define TIMER1_ENABLED 1
    Best regards, Simon
  • Why do you recommend this "work around"?
    Is the NRFX_TIMER API not ready to use?
    In the file nrfx_timer.h the NRFX_TIMER1 _INST_IDX is concated with NRFX_CONCAT_3(NRFX_TIMER, id, _INST_IDX), but the enum is defined in the following enum!
    Please advise
     * @brief Macro for creating a timer driver instance.
    #define NRFX_TIMER_INSTANCE(id)                                   \
        .p_reg            = NRFX_CONCAT_2(NRF_TIMER, id),             \
        .instance_id      = NRFX_CONCAT_3(NRFX_TIMER, id, _INST_IDX), \
        .cc_channel_count = NRF_TIMER_CC_CHANNEL_COUNT(id),           \
    enum {
    #if NRFX_CHECK(NRFX_TIMER0_ENABLED)
        NRFX_TIMER0_INST_IDX,
    #if NRFX_CHECK(NRFX_TIMER1_ENABLED)
        NRFX_TIMER1_INST_IDX,
    #if NRFX_CHECK(NRFX_TIMER2_ENABLED)
        NRFX_TIMER2_INST_IDX,
    #if NRFX_CHECK(NRFX_TIMER3_ENABLED)
        NRFX_TIMER3_INST_IDX,
    #if NRFX_CHECK(NRFX_TIMER4_ENABLED)
        NRFX_TIMER4_INST_IDX,
        NRFX_TIMER_ENABLED_COUNT
  • The definitions TIMER_ENABLED and TIMER1_ENABLED originates from older SDK's, but the Timer driver in SDK 15 uses NRFX definitions.
    The reason it fails, is due to the file apply_old_config.h (located in integration/nrfx/legacy) and the following lines:
    #if defined(TIMER_ENABLED)
    #undef NRFX_TIMER_ENABLED
    #define NRFX_TIMER_ENABLED  TIMER_ENABLED
    #if defined(TIMER1_ENABLED)
    #undef NRFX_TIMER1_ENABLED
    #define NRFX_TIMER1_ENABLED  TIMER1_ENABLED
    This will make your project to use the old definitions (not NRFX) in the sdk_config.h file.
    Two ways of solving this:
    • My initial suggestion
    • Use the new definitions (NRFX_TIMER_ENABLED and NRFX_TIMER1_ENABLED) in the sdk config file, and delete/comment out the old definitions (TIMER_ENABLED and TIMER1_ENABLED) to prevent it from being overwritten
    Does this make sense?
    Best regards, Simon
    I just had the same issue and for the record I just wanted to say this worked perfectly!
    Jack
  • Hello Simon,
    Your first input worked for me. But I am trying to understand the basic issue. Though TIMER_ENABLED is nowhere enabled how macros in apply_old_config.h are executed.
    To cross check, I kept dummy variable as shown below. Irrespective of macro enabled, I am getting compile error.
    X;           // Dummy variable
    Is this due to #if define() same as #ifdef and irrespective of 0 or 1 TIMER_ENABLED is enabled. I mean below all are same.
    #define TIMER_ENABLED 0
    To avoid compile error I commented.
    //#define TIMER_ENABLED 0
    Is my understanding correct. I feel coding style is wrong. Please let me know your inputs.
    Thanks & Regards
    Vishnu Beema
