when I add uart to ble central multilink,there are all of "
Hi all:
when i add uart code in ble_multilink ,and it gived me errors like this:
"<error> app: Fatal error
<warning> app: System reset
<error> app: Fatal error"
my work steps is:
First:I change NRF_SDH_BLE_CENTRAL_LINK_COUNT from 8 to 20,and it works fine ,i can link peripheral.
Second:I add ble_central_uart_c code in multilink project,and it compling ok,but when i download to my NRF52832 board,it can't connect to perpheral,and it throw me those errors.
can anyone help me?please,thank you
    If you compile your project with DEBUG defined you will get the file name, line number, and error code of where the error occurred (error module). Please try re-compile your project with this flag set and check what the error code is and which function call it was returned from.
  • Thank you for your reply! when I run in debug mode,it can just goto app_error_weak,i also didn't know where my code is wrong,i'm a newbee,and i check my code,i also can't konw where is wrong,Could you send me a debug blog for NRF52 project,and This is my main code:
    * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
    * All rights reserved.
    * list of conditions and the following disclaimer.
    * Semiconductor ASA integrated circuit in a product or a software update for
    * such product, must reproduce the above copyright notice, this list of
    * conditions and the following disclaimer in the documentation and/or other
    * materials provided with the distribution.
    * contributors may be used to endorse or promote products derived from this
    * software without specific prior written permission.
    * Nordic Semiconductor ASA integrated circuit.
    * engineered, decompiled, modified and/or disassembled.
    * @brief BLE LED Button Service central and client application main file.
    * This example can be a central for up to 8 peripherals.
    * The peripheral is called ble_app_blinky and can be found in the ble_peripheral
    * folder.
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "app_timer.h"
    //new added
    #include "app_uart.h"
    #include "app_util.h"
    //end my added
    #include "bsp_btn_ble.h"
    #include "ble.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "ble_db_discovery.h"
    #include "ble_lbs_c.h"
    #include "ble_conn_state.h"
    //my added
    #include "ble_nus_c.h"
    //end added
    #include "nrf_ble_gatt.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG 1 /**< A tag that refers to the BLE stack configuration we set with @ref sd_ble_cfg_set. Default tag is @ref APP_BLE_CONN_CFG_TAG. */
    #define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    //my added
    #define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
    #define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
    //end added
    #define CENTRAL_SCANNING_LED BSP_BOARD_LED_0
    #define CENTRAL_CONNECTED_LED BSP_BOARD_LED_1
    #define LEDBUTTON_LED BSP_BOARD_LED_2 /**< LED to indicate a change of state of the the Button characteristic on the peer. */
    #define LEDBUTTON_BUTTON BSP_BUTTON_0 /**< Button that will write to the LED characteristic of the peer. */
    #define BUTTON_DETECTION_DELAY APP_TIMER_TICKS(50) /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
    #define SCAN_INTERVAL 0x00A0 /**< Determines scan interval in units of 0.625 millisecond. */
    #define SCAN_WINDOW 0x0050 /**< Determines scan window in units of 0.625 millisecond. */
    #define SCAN_DURATION 0x0000 /**< Duration of the scanning in units of 10 milliseconds. If set to 0x0000, scanning will continue until it is explicitly disabled. */
    #define MIN_CONNECTION_INTERVAL MSEC_TO_UNITS(7.5, UNIT_1_25_MS) /**< Determines minimum connection interval in milliseconds. */
    #define MAX_CONNECTION_INTERVAL MSEC_TO_UNITS(30, UNIT_1_25_MS) /**< Determines maximum connection interval in milliseconds. */
    #define SLAVE_LATENCY 0 /**< Determines slave latency in terms of connection events. */
    #define SUPERVISION_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Determines supervision time-out in units of 10 milliseconds. */
    //my added
    #define ECHOBACK_BLE_UART_DATA 1 /**< Echo the UART data that is received over the Nordic UART Service back to the sender. */
    BLE_NUS_C_DEF(m_ble_nus_c); /**< BLE NUS service client instance. */
    //end added
    NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
    BLE_LBS_C_ARRAY_DEF(m_lbs_c, NRF_SDH_BLE_CENTRAL_LINK_COUNT); /**< LED Button client instances. */
    BLE_DB_DISCOVERY_ARRAY_DEF(m_db_disc, NRF_SDH_BLE_CENTRAL_LINK_COUNT); /**< Database discovery module instances. */
    static char const m_target_periph_name[] = "Pig_T"; /**< Name of the device we try to connect to. This name is searched for in the scan report data*/
    static uint8_t m_scan_buffer_data[BLE_GAP_SCAN_BUFFER_MIN]; /**< buffer where advertising reports will be stored by the SoftDevice. */
    //my added
    static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    //end added
    /**@brief Pointer to the buffer where advertising reports will be stored by the SoftDevice. */
    static ble_data_t m_scan_buffer =
    m_scan_buffer_data,
    /**@brief Scan parameters requested for scanning and connection. */
    static ble_gap_scan_params_t const m_scan_params =
    .active = 0,
    .interval = SCAN_INTERVAL,
    .window = SCAN_WINDOW,
    .timeout = SCAN_DURATION,
    .scan_phys = BLE_GAP_PHY_1MBPS,
    .filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL,
    /**@brief Connection parameters requested for connection. */
    static ble_gap_conn_params_t const m_connection_param =
    (uint16_t)MIN_CONNECTION_INTERVAL,
    (uint16_t)MAX_CONNECTION_INTERVAL,
    (uint16_t)SLAVE_LATENCY,
    (uint16_t)SUPERVISION_TIMEOUT
    /**@brief Function to handle asserts in the SoftDevice.
    * how your product is supposed to react in case of Assert.
    * @param[in] line_num Line number of the failing ASSERT call.
    * @param[in] p_file_name File name of the failing ASSERT call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
    /**@brief Function for the LEDs initialization.
    * @details Initializes all LEDs used by the application.
    static void leds_init(void)
    /**@brief Function to start scanning. */
    static void scan_start(void)
    ret_code_t ret;
    (void) sd_ble_gap_scan_stop();
    NRF_LOG_INFO("Start scanning for device name %s.", (uint32_t)m_target_periph_name);
    ret = sd_ble_gap_scan_start(&m_scan_params, &m_scan_buffer);
    APP_ERROR_CHECK(ret);
    // Turn on the LED to signal scanning.
    bsp_board_led_on(CENTRAL_SCANNING_LED);
    /**@brief Handles events coming from the LED Button central module.
    * @param[in] p_lbs_c The instance of LBS_C that triggered the event.
    * @param[in] p_lbs_c_evt The LBS_C event.
    static void lbs_c_evt_handler(ble_lbs_c_t * p_lbs_c, ble_lbs_c_evt_t * p_lbs_c_evt)
    switch (p_lbs_c_evt->evt_type)
    case BLE_LBS_C_EVT_DISCOVERY_COMPLETE:
    ret_code_t err_code;
    NRF_LOG_INFO("LED Button service discovered on conn_handle 0x%x",
    p_lbs_c_evt->conn_handle);
    err_code = app_button_enable();
    // LED Button service discovered. Enable notification of Button.
    err_code = ble_lbs_c_button_notif_enable(p_lbs_c);
    } break; // BLE_LBS_C_EVT_DISCOVERY_COMPLETE
    case BLE_LBS_C_EVT_BUTTON_NOTIFICATION:
    NRF_LOG_INFO("Link 0x%x, Button state changed on peer to 0x%x",
    p_lbs_c_evt->conn_handle,
    p_lbs_c_evt->params.button.button_state);
    if (p_lbs_c_evt->params.button.button_state)
    bsp_board_led_on(LEDBUTTON_LED);
    bsp_board_led_off(LEDBUTTON_LED);
    } break; // BLE_LBS_C_EVT_BUTTON_NOTIFICATION
    // No implementation needed.
    /**@brief Function for handling the advertising report BLE event.
    * @param[in] p_adv_report Advertising report from the SoftDevice.
    static void on_adv_report(ble_gap_evt_adv_report_t const * p_adv_report)
    if (ble_advdata_name_find(p_adv_report->data.p_data,
    p_adv_report->data.len,
    m_target_periph_name))
    // Name is a match, initiate connection.
    err_code = sd_ble_gap_connect(&p_adv_report->peer_addr,
    &m_scan_params,
    &m_connection_param,
    APP_BLE_CONN_CFG_TAG);
    NRF_LOG_INFO("Connection Start");
    for(int i=0;i<33;i++){
    NRF_LOG_INFO("Connection data i %d",p_adv_report->data.p_data[i]);
    //NRF_LOG_INFO("Connection char i %s",p_adv_report->data.p_data[i]);
    //NRF_LOG_INFO("Connection hex i %x",p_adv_report->data.p_data[i]);
    NRF_LOG_INFO("Connection end");
    NRF_LOG_INFO("Connection data %d,%d",p_adv_report->data.p_data,p_adv_report->data.len);
    if (err_code != NRF_SUCCESS)
    NRF_LOG_ERROR("Connection Request Failed, reason %d", err_code);
    err_code = sd_ble_gap_scan_start(NULL, &m_scan_buffer);
    * @param[in] p_ble_evt Bluetooth stack event.
    * @param[in] p_context Unused.
    // For readability.
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
    // Upon connection, check which peripheral has connected, initiate DB
    // discovery, update LEDs status and resume scanning if necessary.
    case BLE_GAP_EVT_CONNECTED:
    NRF_LOG_INFO("Connection 0x%x established, starting DB discovery.",
    p_gap_evt->conn_handle);
    APP_ERROR_CHECK_BOOL(p_gap_evt->conn_handle < NRF_SDH_BLE_CENTRAL_LINK_COUNT);
    err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);
    err_code = ble_lbs_c_handles_assign(&m_lbs_c[p_gap_evt->conn_handle],
    p_gap_evt->conn_handle,
    NULL);
    err_code = ble_db_discovery_start(&m_db_disc[p_gap_evt->conn_handle],
    if (err_code != NRF_ERROR_BUSY)
    // Update LEDs status, and check if we should be looking for more
    // peripherals to connect to.
    bsp_board_led_on(CENTRAL_CONNECTED_LED);
    if (ble_conn_state_central_conn_count() == NRF_SDH_BLE_CENTRAL_LINK_COUNT)
    bsp_board_led_off(CENTRAL_SCANNING_LED);
    // Resume scanning.
    scan_start();
    } break; // BLE_GAP_EVT_CONNECTED
    // Upon disconnection, reset the connection handle of the peer which disconnected, update
    // the LEDs status and start scanning again.
    NRF_LOG_INFO("LBS central link 0x%x disconnected (reason: 0x%x)",
    p_gap_evt->params.disconnected.reason);
    if (ble_conn_state_central_conn_count() == 0)
    err_code = app_button_disable();
    // Turn off connection indication LED
    bsp_board_led_off(CENTRAL_CONNECTED_LED);
    // Start scanning
    scan_start();
    // Turn on LED for indicating scanning
    } break;
    case BLE_GAP_EVT_ADV_REPORT:
    on_adv_report(&p_gap_evt->params.adv_report);
    case BLE_GAP_EVT_TIMEOUT:
    // We have not specified a timeout for scanning, so only connection attemps can timeout.
    if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
    NRF_LOG_DEBUG("Connection request timed out.");
    } break;
    case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
    NRF_LOG_DEBUG("BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST.");
    // Accept parameters requested by peer.
    err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
    &p_gap_evt->params.conn_param_update_request.conn_params);
    } break;
    ble_gap_phys_t const phys =
    .rx_phys = BLE_GAP_PHY_AUTO,
    .tx_phys = BLE_GAP_PHY_AUTO,
    } break;
    case BLE_GATTC_EVT_TIMEOUT:
    } break;
    case BLE_GATTS_EVT_TIMEOUT:
    } break;
    /**@brief LED Button collector initialization. */
    static void lbs_c_init(void)
    ble_lbs_c_init_t lbs_c_init_obj;
    lbs_c_init_obj.evt_handler = lbs_c_evt_handler;
    for (uint32_t i = 0; i < NRF_SDH_BLE_CENTRAL_LINK_COUNT; i++)
    err_code = ble_lbs_c_init(&m_lbs_c[i], &lbs_c_init_obj);
    * @details Initializes the SoftDevice and the BLE event interrupts.
    uint32_t ram_start = 0;
    // Enable BLE stack.
    /**@brief Function for writing to the LED characteristic of all connected clients.
    * @details Based on if the button is pressed or released, this function writes a high or low
    * LED status to the server.
    * @param[in] button_action The button action (press/release).
    * Determines if the LEDs of the servers will be ON or OFF.
    * @return If successful NRF_SUCCESS is returned. Otherwise, the error code from @ref ble_lbs_led_status_send.
    static ret_code_t led_status_send_to_all(uint8_t button_action)
    for (uint32_t i = 0; i< NRF_SDH_BLE_CENTRAL_LINK_COUNT; i++)
    err_code = ble_lbs_led_status_send(&m_lbs_c[i], button_action);
    if (err_code != NRF_SUCCESS &&
    err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
    err_code != NRF_ERROR_INVALID_STATE)
    return err_code;
    return NRF_SUCCESS;
    /**@brief Function for handling events from the button handler module.
    * @param[in] pin_no The pin that the event applies to.
    static void button_event_handler(uint8_t pin_no, uint8_t button_action)
    switch (pin_no)
    case LEDBUTTON_BUTTON:
    err_code = led_status_send_to_all(button_action);
    if (err_code == NRF_SUCCESS)
    NRF_LOG_INFO("LBS write LED state %d", button_action);
    APP_ERROR_HANDLER(pin_no);
    /**@brief Function for initializing the button handler module.
    static void buttons_init(void)
    // The array must be static because a pointer to it will be saved in the button handler module.
    static app_button_cfg_t buttons[] =
    {LEDBUTTON_BUTTON, false, BUTTON_PULL, button_event_handler}
    err_code = app_button_init(buttons, ARRAY_SIZE(buttons), BUTTON_DETECTION_DELAY);
    /**@brief Function for handling database discovery events.
    * @details This function is callback function to handle events from the database discovery module.
    * Depending on the UUIDs that are discovered, this function should forward the events
    * to their respective services.
    * @param[in] p_event Pointer to the database discovery event.
    static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    NRF_LOG_DEBUG("call to ble_lbs_on_db_disc_evt for instance %d and link 0x%x!",
    p_evt->conn_handle,
    ble_lbs_on_db_disc_evt(&m_lbs_c[p_evt->conn_handle], p_evt);
    //my added
    /**@brief Function for handling characters received by the Nordic UART Service.
    * @details This function takes a list of characters of length data_len and prints the characters out on UART.
    * If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
    static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
    ret_code_t ret_val;
    NRF_LOG_DEBUG("Receiving data.");
    NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
    for (uint32_t i = 0; i < data_len; i++)
    do
    ret_val = app_uart_put(p_data[i]);
    if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
    NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
    APP_ERROR_CHECK(ret_val);
    } while (ret_val == NRF_ERROR_BUSY);
    if (p_data[data_len-1] == '\r')
    while (app_uart_put('\n') == NRF_ERROR_BUSY);
    if (ECHOBACK_BLE_UART_DATA)
    // Send data back to peripheral.
    do
    ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
    NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
    /**@brief Function for handling app_uart events.
    * a string. The string will be be sent over BLE when the last character received was a
    * 'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    static uint16_t index = 0;
    uint32_t ret_val;
    switch (p_event->evt_type)
    /**@snippet [Handling data from UART] */
    case APP_UART_DATA_READY:
    index++;
    if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
    do
    ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_array, index);
    if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_BUSY) )
    index = 0;
    NRF_LOG_ERROR("Communication error occurred while handling UART.");
    case APP_UART_FIFO_ERROR:
    NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
    /**@brief Callback handling NUS Client events.
    * @details This function is called to notify the application of NUS client events.
    * @param[in] p_ble_nus_c NUS Client Handle. This identifies the NUS client
    * @param[in] p_ble_nus_evt Pointer to the NUS Client event.
    /**@snippet [Handling events from the ble_nus_c module] */
    static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
    switch (p_ble_nus_evt->evt_type)
    case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
    NRF_LOG_INFO("Discovery complete.");
    err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
    err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
    NRF_LOG_INFO("Connected to device with Nordic UART Service.");
    case BLE_NUS_C_EVT_NUS_TX_EVT:
    ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
    case BLE_NUS_C_EVT_DISCONNECTED:
    NRF_LOG_INFO("Disconnected.");
    scan_start();
    * @brief Function for shutdown events.
    * @param[in] event Shutdown type.
    static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
    switch (event)
    case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
    // Prepare wakeup buttons.
    return true;
    NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
    //end added
    /** @brief Database discovery initialization.
    static void db_discovery_init(void)
    ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
    //my added
    /**@brief Function for initializing the UART. */
    static void uart_init(void)
    .rx_pin_no = RX_PIN_NUMBER,
    .tx_pin_no = TX_PIN_NUMBER,
    .rts_pin_no = RTS_PIN_NUMBER,
    .cts_pin_no = CTS_PIN_NUMBER,
    .use_parity = false,
    .baud_rate = UART_BAUDRATE_BAUDRATE_Baud115200
    UART_RX_BUF_SIZE,
    UART_TX_BUF_SIZE,
    uart_event_handle,
    APP_IRQ_PRIORITY_LOWEST,
    err_code);
    printf("err_uart_code%s",err_code);
    /**@brief Function for initializing the NUS Client. */
    static void nus_c_init(void)
    ble_nus_c_init_t init;
    init.evt_handler = ble_nus_c_evt_handler;
    err_code = ble_nus_c_init(&m_ble_nus_c, &init);
    //end added
    * @details Handle any pending log operation(s), then sleep until the next event occurs.
    nrf_pwr_mgmt_run();
    /** @brief Function for initializing the log module.
    static void log_init(void)
    /** @brief Function for initializing the timer.
    static void timer_init(void)
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    // Initialize.
    log_init();
    timer_init();
    //my added
    uart_init();
    //end added
    leds_init();
    buttons_init();
    power_management_init();
    ble_stack_init();
    gatt_init();
    //my added
    nus_c_init();
    //end added
    db_discovery_init();
    lbs_c_init();
    ble_conn_state_init();
    // Start execution.
    NRF_LOG_INFO("Multilink example started.");
    scan_start();
    for (;;)
    idle_state_handle();
    Which toolchain are you using, pure GCC, Segger embedded studio, Keil or IAR? Here is a relevant but a bit dated thread regarding debugging: https://devzone.nordicsemi.com/f/nordic-q-a/10729/my-device-is-freezing-and-restarting
