SDK 15.1 nrfx_qspi.h wont compile under C++
The gnu C++ compiler wont do non trivial assignments designated initialisers, but by simply reordering this will work, Its a bit annoying,
nrfx_qspi.h line 73 replace with the following...
 * @brief QSPI instance default configuration.
#define NRFX_QSPI_DEFAULT_CONFIG                                        \
    .xip_offset  = NRFX_QSPI_CONFIG_XIP_OFFSET,                         \
    .pins = {                                                           \
       .sck_pin     = NRFX_QSPI_PIN_SCK,                                \
       .csn_pin     = NRFX_QSPI_PIN_CSN,                                \
       .io0_pin     = NRFX_QSPI_PIN_IO0,                                \
       .io1_pin     = NRFX_QSPI_PIN_IO1,                                \
       .io2_pin     = NRFX_QSPI_PIN_IO2,                                \
       .io3_pin     = NRFX_QSPI_PIN_IO3,                                \
    .prot_if = {                                                        \
        .readoc     = (nrf_qspi_readoc_t)NRFX_QSPI_CONFIG_READOC,       \
        .writeoc    = (nrf_qspi_writeoc_t)NRFX_QSPI_CONFIG_WRITEOC,     \
        .addrmode   = (nrf_qspi_addrmode_t)NRFX_QSPI_CONFIG_ADDRMODE,   \
        .dpmconfig  = false,                                            \
    .phy_if = {                                                         \
        .sck_delay  = (uint8_t)NRFX_QSPI_CONFIG_SCK_DELAY,              \
        .dpmen      = false,                                            \
        .spi_mode   = (nrf_qspi_spi_mode_t)NRFX_QSPI_CONFIG_MODE,       \
        .sck_freq   = (nrf_qspi_frequency_t)NRFX_QSPI_CONFIG_FREQUENCY, \
    .irq_priority   = (uint8_t)NRFX_QSPI_CONFIG_IRQ_PRIORITY,           \
