Hello, I am currently working on a nr52840 s140 Sdk 15.0 card and I want to recover data from a component running on the i²c bus. (I have not yet installed the component on the card).
The problem is that I get a fatal errror from uart_config(void).
Here is my code:
#include <stdio.h>
#include "boards.h"
#include "app_uart.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/*UART buffer size. */
#define UART_TX_BUF_SIZE 256
#define UART_RX_BUF_SIZE 1
#warning "!**** ARE YOU ABSOLUTELY SURE YOU HAVE CHOSEN THE CORRECT SCL AND SDA PINS? ****!"
#define DEVICE_SCL_PIN 3
#define DEVICE_SDA_PIN 4
nrf_drv_twi_t twi_instance = NRF_DRV_TWI_INSTANCE(0);
uint8_t device_address = 0; // Address used to temporarily store the current address being checked
bool device_found = false;
* @brief UART events handler.
static void uart_events_handler(app_uart_evt_t * p_event)
switch (p_event->evt_type)
case APP_UART_FIFO_ERROR:
* @brief UART initialization.
static void uart_config(void)
uint32_t err_code;
const app_uart_comm_params_t comm_params =
RX_PIN_NUMBER,
TX_PIN_NUMBER,
RTS_PIN_NUMBER,
CTS_PIN_NUMBER,
APP_UART_FLOW_CONTROL_DISABLED,
false,
UART_BAUDRATE_BAUDRATE_Baud115200
APP_UART_FIFO_INIT(&comm_params,UART_RX_BUF_SIZE,UART_TX_BUF_SIZE,uart_events_handler,APP_IRQ_PRIORITY_LOW,err_code);
* @brief TWI events handler.
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
switch(p_event->type)
case NRF_DRV_TWI_EVT_DONE:
// If EVT_DONE (event done) is received a device is found and responding on that particular address
printf("\r\n!****************************!\r\nDevice found at 7-bit address: %#x!\r\n!****************************!\r\n\r\n", device_address);
device_found = true;
case NRF_DRV_TWI_EVT_ADDRESS_NACK:
printf("No address ACK on address: %#x!\r\n", device_address);
case NRF_DRV_TWI_EVT_DATA_NACK:
printf("No data ACK on address: %#x!\r\n", device_address);
void twi_init (void)
ret_code_t err_code;
const nrf_drv_twi_config_t twi_config = {
.scl = DEVICE_SCL_PIN,
.sda = DEVICE_SDA_PIN,
.frequency = NRF_TWI_FREQ_100K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH
err_code = nrf_drv_twi_init(&twi_instance, &twi_config, twi_handler, NULL);
nrf_drv_twi_enable(&twi_instance);
static void log_init(void)
log_init();
NRF_LOG_INFO(" 1");
nrf_gpio_cfg_output(LED_1);
NRF_LOG_INFO(" 2");
nrf_gpio_pin_set(LED_1);
NRF_LOG_INFO("3");
twi_init();
NRF_LOG_INFO("4");
uart_config();
NRF_LOG_INFO("\033[2J\033[;H\r\n* Example to find TWI devices connected to \r\n* the TWI bus and their addresses\r\n\r\n");
uint8_t dummy_data = 0x55;
// Itterate through all possible 7-bit TWI addresses
for(uint8_t i = 0; i <= 0x7F; i++)
device_address = i;
// Send dummy data. If a device is present on this particular address a TWI EVT_DONE event is
// received in the twi event handler and a message is printed to UART
nrf_drv_twi_tx(&twi_instance, i, &dummy_data, 1, false);
// Delay 10 ms to allow TWI transfer to complete and UART to print messages before starting new transfer
nrf_delay_ms(10);
if(device_found)
// Blinke LED_1 rapidly if device is found
while(true)
nrf_gpio_pin_toggle(LED_1);
nrf_delay_ms(100);
// Disable LED_1 if device is NOT found
nrf_gpio_cfg_default(LED_1);
printf("*****************\n\rNO DEVICES FOUND!\r\n*****************\n\r");
while(true)
thank's
