Hello!
(SDK15, nrf52832, SES)
I started to implement DFU in my code following this tutorial. So far with the tutorial i have the following issue.
1. In the section D1. Flash bootloader and softdevice says to flash the softdevice then the bootloader. I have figured out so far that the softdevice is s132_nrf52_6.0.0_softdevice.hex. As for the bootloader, is it the secure_bootloader_ble_s132_pca10040.hex ??
2. In the infocenter, testing section, it says the BUTTON 4 is the one that activates the DFU mode. I have checked the code in examples\dfu\secure_bootloader\pca10040_ble and i haven´t found where that is implemented. Does that code is always in DFU mode?
3. Following the 2. question, I want to activate the DFU mode when getting an instruction from the App. I found the following code in this forum:
// Disable the SoftDevice and restart properly in bootloader mode
void bootloader_start() {
// A "simple" reset is not enough, the SD and IRQs must be disabled first
ble_dfu_evt_t evt;
memset(&evt, 0, sizeof(evt));
evt.ble_dfu_evt_type = BLE_DFU_START;
dfu_app_on_dfu_evt(&m_dfus, &evt);
I wanted to know if it's the right way to enter DFU mode because i couldn´t find the BUTTON 4 action which activates the DFU mode, and if there is another way to enter DFU.
4. This is a silly question, but i just wanted to be sure before starting. The code in the DFU example that is written in the main should be implemented right when i start the DFU mode and not when my App start right?
Sorry about all the questions, i'm just getting started with DFU.
