I need to change, on a time basis, the advertising packet :
Let's say for X seconds it has to work as a "iBeacon"
- BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED
- Advertising interval 100ms
, while for other X seconds as a scannable and connecteble advertising (standard) packet:
- Advertising interval 190 ms
i'm developing starting from the template example with BLE_ADVERTISING_DEF(m_advertising) structure and I'm trying to "integrate"
with the "nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_beacon" example but I'm getting an :
"..<error> app: Fatal error
<warning> app: System reset"
when trying with this piece of code:
static void timer_timeout_handler(void * p_context)
UNUSED_PARAMETER(p_context);
ret_code_t err_code;
static int flag=1;
timerCounter++;
if( timerCounter % 3 == 0 )
if (flag ){
//stop "standard" adv
NRF_LOG_INFO(" stopping standard ADV");
err_code = sd_ble_gap_adv_stop(m_advertising.adv_handle);
// change advertising message
NRF_LOG_INFO(" init iBeacon ");
iBeacon_init();
NRF_LOG_INFO(" starting ibeacon");
iBeacon_start();
flag = 0;
NRF_LOG_INFO(" restart standard ADV");
err_code = sd_ble_gap_adv_stop(m_adv_handle);
flag =1;
static void iBeacon_init(void)
uint32_t err_code;
ble_advdata_t advdata;
uint8_t flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
ble_advdata_manuf_data_t manuf_specific_data;
manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
#if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
// If USE_UICR_FOR_MAJ_MIN_VALUES is defined, the major and minor values will be read from the
// UICR instead of using the default values. The major and minor values obtained from the UICR
// are encoded into advertising data in big endian order (MSB First).
// To set the UICR used by this example to a desired value, write to the address 0x10001080
// using the nrfjprog tool. The command to be used is as follows.
// nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val <your major/minor value>
// For example, for a major value and minor value of 0xabcd and 0x0102 respectively, the
// the following command should be used.
// nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val 0xabcd0102
uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
m_beacon_info[index++] = MSB_16(major_value);
m_beacon_info[index++] = LSB_16(major_value);
m_beacon_info[index++] = MSB_16(minor_value);
m_beacon_info[index++] = LSB_16(minor_value);
manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
manuf_specific_data.data.size = APP_BEACON_INFO_LENGTH;
// Build and set advertising data.
memset(&advdata, 0, sizeof(advdata));
advdata.name_type = BLE_ADVDATA_NO_NAME;
advdata.flags = flags;
advdata.p_manuf_specific_data = &manuf_specific_data;
// Initialize advertising parameters (used when starting advertising).
memset(&m_adv_params, 0, sizeof(m_adv_params));
m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
m_adv_params.p_peer_addr = NULL; // Undirected advertisement.
m_adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
m_adv_params.interval = NON_CONNECTABLE_ADV_INTERVAL;
m_adv_params.duration = APP_IBCN_DURATION; // Never time out.
err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
static void iBeacon_start(void)
err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
the application resets on iBeacon_init() in the timer handler.
is it a problem of configuring the right parametrs to the SD API , or something else?
Thx
bye
