Hi
I am integrating your Android DFU library with our mobile app to do FOTA to our Nordic device nRF52832. We are using SDK 14.2 and doing the firmware update using zip file.
In 1 out of 7 times, firmware update gets stuck just after sending `Sending Enter Bootloader (Op Code = 1)`, because the device is not responding with `Response received (Op Code = 1, Status = 1)`. On other occasions the DFU succeeds without issue.
Log during failed DFU:
09-06 15:33:22.837 I/DfuBaseService(26281): DFU service created. Version: 1.7.009-06 15:33:22.939 D/BluetoothGatt(26281): onConnectionUpdated() - Device=CA:03:09:F7:A7:F5 interval=6 latency=0 timeout=500 status=009-06 15:33:22.999 I/DfuBaseService(26281): Connecting to the device...09-06 15:33:23.000 D/BluetoothGatt(26281): connect() - device: CA:03:09:F7:A7:F5, auto: false09-06 15:33:23.000 D/BluetoothGatt(26281): registerApp()09-06 15:33:23.001 D/BluetoothGatt(26281): registerApp() - UUID=fc8345b1-8afd-4152-a5cd-3a685a29e74d09-06 15:33:23.003 D/BluetoothGatt(26281): onClientRegistered() - status=0 clientIf=1109-06 15:33:23.006 D/BluetoothGatt(26281): onClientConnectionState() - status=0 clientIf=11 device=CA:03:09:F7:A7:F509-06 15:33:23.006 I/DfuBaseService(26281): Connected to GATT server09-06 15:33:23.007 D/BluetoothGatt(26281): discoverServices() - device: CA:03:09:F7:A7:F509-06 15:33:23.009 I/DfuBaseService(26281): Attempting to start service discovery... succeed09-06 15:33:23.714 D/BluetoothGatt(26281): onSearchComplete() = Device=CA:03:09:F7:A7:F5 Status=009-06 15:33:23.715 I/DfuBaseService(26281): Services discovered09-06 15:33:23.722 I/DfuImpl (26281): Buttonless service without bond sharing found -> SDK 13 or newer09-06 15:33:23.737 I/DfuImpl (26281): Enabling indications...09-06 15:33:23.739 D/BluetoothGatt(26281): setCharacteristicNotification() - uuid: 8ec90003-f315-4f60-9fb8-838830daea50 enable: true09-06 15:33:23.755 D/BluetoothGatt(26281): onConnectionUpdated() - Device=CA:03:09:F7:A7:F5 interval=36 latency=0 timeout=500 status=009-06 15:33:23.755 D/BluetoothGatt(26281): onConnectionUpdated() - Device=CA:03:09:F7:A7:F5 interval=36 latency=0 timeout=500 status=009-06 15:33:23.802 I/DfuImpl (26281): Sending Enter Bootloader (Op Code = 1)DFU\DfuProgressListenerAdapter.cs;OnDeviceConnected;44;20180906T223323Z;INFO;OnDeviceConnected: CA:03:09:F7:A7:F5DFU\DfuProgressListenerAdapter.cs;OnDfuProcessStarting;26;20180906T223323Z;INFO;OnDfuProcessStarting: CA:03:09:F7:A7:F5DFU\DfuProgressListenerAdapter.cs;OnEnablingDfuMode;68;20180906T223323Z;INFO;OnEnablingDfuMode: CA:03:09:F7:A7:F5
Log during successful DFU:
09-06 15:15:05.382 I/DfuBaseService(21681): DFU service created. Version: 1.7.009-06 15:15:05.495 I/DfuBaseService(21681): Connecting to the device...09-06 15:15:05.497 D/BluetoothGatt(21681): connect() - device: CA:03:09:F7:A7:F5, auto: false09-06 15:15:05.497 D/BluetoothGatt(21681): registerApp()09-06 15:15:05.498 D/BluetoothGatt(21681): registerApp() - UUID=c904ece0-c2ba-4378-8e77-064b3205111109-06 15:15:05.500 D/BluetoothGatt(21681): onClientRegistered() - status=0 clientIf=1109-06 15:15:05.503 D/BluetoothGatt(21681): onClientConnectionState() - status=0 clientIf=11 device=CA:03:09:F7:A7:F509-06 15:15:05.504 I/DfuBaseService(21681): Connected to GATT server09-06 15:15:05.505 D/BluetoothGatt(21681): discoverServices() - device: CA:03:09:F7:A7:F509-06 15:15:05.507 I/DfuBaseService(21681): Attempting to start service discovery... succeed09-06 15:15:05.606 D/BluetoothGatt(21681): onConnectionUpdated() - Device=CA:03:09:F7:A7:F5 interval=6 latency=0 timeout=500 status=009-06 15:15:05.606 D/BluetoothGatt(21681): onConnectionUpdated() - Device=CA:03:09:F7:A7:F5 interval=6 latency=0 timeout=500 status=009-06 15:15:06.283 D/BluetoothGatt(21681): onSearchComplete() = Device=CA:03:09:F7:A7:F5 Status=009-06 15:15:06.283 I/DfuBaseService(21681): Services discovered09-06 15:15:06.289 I/DfuImpl (21681): Buttonless service without bond sharing found -> SDK 13 or newer09-06 15:15:06.301 I/DfuImpl (21681): Enabling indications...09-06 15:15:06.303 D/BluetoothGatt(21681): setCharacteristicNotification() - uuid: 8ec90003-f315-4f60-9fb8-838830daea50 enable: true09-06 15:15:06.333 D/BluetoothGatt(21681): onConnectionUpdated() - Device=CA:03:09:F7:A7:F5 interval=36 latency=0 timeout=500 status=009-06 15:15:06.356 D/BluetoothGatt(21681): onConnectionUpdated() - Device=CA:03:09:F7:A7:F5 interval=36 latency=0 timeout=500 status=0DFU\DfuProgressListenerAdapter.cs;OnDeviceConnected;44;20180906T221506Z;INFO;OnDeviceConnected: CA:03:09:F7:A7:F509-06 15:15:06.364 I/DfuImpl (21681): Sending Enter Bootloader (Op Code = 1)DFU\DfuProgressListenerAdapter.cs;OnDfuProcessStarting;26;20180906T221506Z;INFO;OnDfuProcessStarting: CA:03:09:F7:A7:F5DFU\DfuProgressListenerAdapter.cs;OnEnablingDfuMode;68;20180906T221506Z;INFO;OnEnablingDfuMode: CA:03:09:F7:A7:F509-06 15:15:06.463 I/DfuImpl (21681): Response received (Op Code = 1, Status = 1)09-06 15:15:11.478 D/BluetoothGatt(21681): onClientConnectionState() - status=8 clientIf=10 device=CA:03:09:F7:A7:F509-06 15:15:11.480 D/BluetoothGatt(21681): onClientConnectionState() - status=8 clientIf=11 device=CA:03:09:F7:A7:F509-06 15:15:11.480 W/DfuBaseService(21681): Target device disconnected with status: 809-06 15:15:11.482 D/BluetoothGatt(21681): refresh() - device: CA:03:09:F7:A7:F509-06 15:15:11.485 I/DfuBaseService(21681): Refreshing result: true09-06 15:15:11.485 I/DfuBaseService(21681): Cleaning up...09-06 15:15:11.485 D/BluetoothGatt(21681): close()09-06 15:15:11.486 D/BluetoothGatt(21681): unregisterApp() - mClientIf=1109-06 15:15:11.494 I/DfuImpl (21681): Restarting to bootloader mode09-06 15:15:11.507 D/BluetoothAdapter(21681): isLeEnabled(): ON09-06 15:15:11.511 I/DfuBaseService(21681): Action received: android.bluetooth.device.action.ACL_DISCONNECTED09-06 15:15:11.516 D/BluetoothLeScanner(21681): onScannerRegistered() - status=0 scannerId=11 mScannerId=009-06 15:15:11.612 D/BluetoothAdapter(21681): isLeEnabled(): ON09-06 15:15:11.614 I/DfuImpl (21681): Scanning for new address finished with: CA:03:09:F7:A7:F6... (proceeds to success)
Here is the code I am using:
_dfuProgressListener = new DfuProgressListenerAdapter(_progressListener, _loggingService); DfuServiceListenerHelper.RegisterProgressListener(_context, _dfuProgressListener); DfuServiceInitiator starter = new DfuServiceInitiator(device.DeviceId) .SetDeviceName(device.Name) //.SetKeepBond(true) .SetDisableNotification(true) .SetPacketsReceiptNotificationsEnabled(true) .SetPacketsReceiptNotificationsValue(18) .SetUnsafeExperimentalButtonlessServiceInSecureDfuEnabled(true); starter.SetZip(zipFilePath); _controller = starter.Start(_context, Class.FromType(typeof(DfuAndroidService)));
What could I be missing? This random failure is not happening when using your nRF Connect Android app to do the DFU.
I am using One+3 mobile with Android 8.0, but it is happening using other Android mobile devices too.
Thanks
Jagan
