Disabling the GPIOTE interrupt using INTENCLR
Hi, I am using nrf52832 board. I was trying to disable the GPIOTE interrupt for a particular event (Event4) using INTENCLR register.  My code was NRF_GPIOTE->INTENCLR = 1 < < 4; But still the interrupt is not getting disabled. How to do the disabling actually?
  • NRF_GPIOTE->INTENCLR = NRF_GPIOTE_INT_IN4_MASK;
    That should disable the interrupt for IN[4] event.
    Not sure what your code does, there seems to be  white space between the "<". Should yield a compiler error IMHO.
  • Hi Turbo J,
    There is no white space between "<" and I don't get any compiler error.
    Can we have a telephonic discussion regarding this issue?
    Thanks
  • Hi
    Could you describe the issue in a bit more detail?
    Could there be any other GPIOTE events that trigger the interrupt, or are you sure it is the IN[4] event that is the cause?
    Are you able to share your code so I can have a look at it?
    Best regards
    Torbjørn
    Here is the section of code in which I am trying to disable the GPIOTE interrupts. This product communicates to Mobile device using BLE. Can you please go through this and suggest a solution?
    #define LOGIC_HIGH                                    1
    #define LOGIC_LOW                                     0
    enum interrupt_events_t {
        EVENT0 = 0,
        EVENT1,
        EVENT2,
        EVENT3,
        EVENT4,
        EVENT5,
        EVENT6,
        EVENT7
    void enableTrashBinInterrupt() {
        NRF_GPIOTE->INTENSET = LOGIC_HIGH << EVENT5;
    void enableTrayLidInterrupt() {
        NRF_GPIOTE->INTENSET = LOGIC_HIGH << EVENT4;
    void disableTrashBinInterrupt() {
        NRF_GPIOTE->INTENCLR = LOGIC_HIGH << EVENT5;
    void disableTrayLidInterrupt() {
        NRF_GPIOTE->INTENCLR = LOGIC_HIGH << EVENT4;
    int main(void) {
        /* Switches, LEDs, ADC initialisations*/
        if (deviceStatus == TEST_PASSED) {
            lockTrayLidAndTrashBin();
            goToHomePosition();
            enableTrashBinInterrupt();
            enableTrayLidInterrupt();
            if (deviceCalibrationStatus == DEVICE_CALIBRATED)
                disposeTip();
            if (currentState != ERROR_STATE)
                goToLoadingPosition();
        unlockTrayLidAndTrashBin();
        runConfirmationBuzzer();
        nrf_delay_ms(100);
        disableTrashBinInterrupt();
        disableTrayLidInterrupt();
        err_code = advertisementInit(false);                                  // Initialize the bluetooth communication
        bootupErrorHandler(err_code);
        if (err_code == NRF_SUCCESS) {
            err_code = startAdvertisement();
        while(1) {
        // waiting for start command from apk
    Thanks
