SDK 15.0, PCA 10056 (1.0.0)
Is it possible to let the relay-example from the SDK 15.0 run in a way, so that the long-range feature of Bt 5 is supported between the Peripheral and the Central?
If yes, what would be necessary to change the example successfully? The Collector is a Smartphone, so between Collector and Central only short range should be used under Bt 4.x.
Thanks for any help.
