Dear Sir,
I am trying to use a whitelist on peripheral side so as to connect the peripheral to a given phone/App.
At first I enabled the "p_advertising->adv_params.scan_req_notification = 1;" in ble_advertising.c file to get the rssi and peer adress of the device who responds to advertising packets.
Then I used the peer address which correponds to highest rssi.
Then create a whitelist with this peer address .
I am attaching the main file here.
Please let me know if I am missing something on this.
I have modified the code for ble_hrs_app(on peripheral side). I have tried a number of ways( which I commented for now). Please forgive as it may look a little mess.
* Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @example examples/ble_peripheral/ble_app_hrs/main.c
* @brief Heart Rate Service Sample Application main file.
* This file contains the source code for a sample application using the Heart Rate service
* (and also Battery and Device Information services). This application uses the
* @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "nrf_sdm.h"
#include "app_error.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_bas.h"
#include "ble_hrs.h"
#include "ble_dis.h"
#include "ble_conn_params.h"
#include "sensorsim.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "peer_manager.h"
#include "fds.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "ble_conn_state.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define DEVICE_NAME "Nordic_HRM" /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME "NordicSemiconductor" /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL 300 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION 6000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define WAKE_UP_INTERVAL APP_TIMER_TICKS(120000)
#define BATTERY_LEVEL_MEAS_INTERVAL APP_TIMER_TICKS(2000) /**< Battery level measurement interval (ticks). */
#define MIN_BATTERY_LEVEL 81 /**< Minimum simulated battery level. */
#define MAX_BATTERY_LEVEL 100 /**< Maximum simulated 7battery level. */
#define BATTERY_LEVEL_INCREMENT 1 /**< Increment between each simulated battery level measurement. */
#define HEART_RATE_MEAS_INTERVAL APP_TIMER_TICKS(1000) /**< Heart rate measurement interval (ticks). */
#define MIN_HEART_RATE 140 /**< Minimum heart rate as returned by the simulated measurement function. */
#define MAX_HEART_RATE 300 /**< Maximum heart rate as returned by the simulated measurement function. */
#define HEART_RATE_INCREMENT 10 /**< Value by which the heart rate is incremented/decremented for each call to the simulated measurement function. */
#define RR_INTERVAL_INTERVAL APP_TIMER_TICKS(300) /**< RR interval interval (ticks). */
#define MIN_RR_INTERVAL 100 /**< Minimum RR interval as returned by the simulated measurement function. */
#define MAX_RR_INTERVAL 500 /**< Maximum RR interval as returned by the simulated measurement function. */
#define RR_INTERVAL_INCREMENT 1 /**< Value by which the RR interval is incremented/decremented for each call to the simulated measurement function. */
#define SENSOR_CONTACT_DETECTED_INTERVAL APP_TIMER_TICKS(5000) /**< Sensor Contact Detected toggle interval (ticks). */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(400, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.4 seconds). */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(650, UNIT_1_25_MS) /**< Maximum acceptable connection interval (0.65 second). */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
BLE_HRS_DEF(m_hrs); /**< Heart rate service instance. */
BLE_BAS_DEF(m_bas); /**< Structure used to identify the battery service. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
APP_TIMER_DEF(m_battery_timer_id); /**< Battery timer. */
APP_TIMER_DEF(m_heart_rate_timer_id); /**< Heart rate measurement timer. */
APP_TIMER_DEF(m_rr_interval_timer_id); /**< RR interval timer. */
APP_TIMER_DEF(m_sensor_contact_timer_id); /**< Sensor contact detected timer. */
APP_TIMER_DEF(wakeup_timer_id);
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static bool m_rr_interval_enabled = true; /**< Flag for enabling and disabling the registration of new RR interval measurements (the purpose of disabling this is just to test sending HRM without RR interval data. */
static sensorsim_cfg_t m_battery_sim_cfg; /**< Battery Level sensor simulator configuration. */
static sensorsim_state_t m_battery_sim_state; /**< Battery Level sensor simulator state. */
static sensorsim_cfg_t m_heart_rate_sim_cfg; /**< Heart Rate sensor simulator configuration. */
static sensorsim_state_t m_heart_rate_sim_state; /**< Heart Rate sensor simulator state. */
static sensorsim_cfg_t m_rr_interval_sim_cfg; /**< RR Interval sensor simulator configuration. */
static sensorsim_state_t m_rr_interval_sim_state; /**< RR Interval sensor simulator state. */
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifiers. */
{BLE_UUID_HEART_RATE_SERVICE, BLE_UUID_TYPE_BLE},
{BLE_UUID_BATTERY_SERVICE, BLE_UUID_TYPE_BLE},
{BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
typedef struct
int8_t rssi; /**< Received Signal Strength Indication in dBm. */
ble_gap_addr_t peer_addr; /**< Bluetooth address of the peer device. If the peer_addr resolved: @ref ble_gap_addr_t::addr_id_peer is set to 1
and the address is the device's identity address. */
} list_peer;
static list_peer peak_rssi;
/**@brief Callback function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] file_name File name of the failing ASSERT call.
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
ret_code_t err_code;
NRF_LOG_INFO("Erase bonds!");
err_code = pm_peers_delete();
void advertising_start(bool erase_bonds)
if (erase_bonds == true)
delete_bonds();
// Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Function for handling File Data Storage events.
* @param[in] p_evt Peer Manager event.
* @param[in] cmd
static void fds_evt_handler(fds_evt_t const * const p_evt)
if (p_evt->id == FDS_EVT_GC)
NRF_LOG_DEBUG("GC completed\n");
/**@brief Function for handling Peer Manager events.
static void pm_evt_handler(pm_evt_t const * p_evt)
switch (p_evt->evt_id)
case PM_EVT_BONDED_PEER_CONNECTED:
NRF_LOG_INFO("Connected to a previously bonded device.");
} break;
case PM_EVT_CONN_SEC_SUCCEEDED:
NRF_LOG_INFO("Connection secured: role: %d, conn_handle: 0x%x, procedure: %d.",
ble_conn_state_role(p_evt->conn_handle),
p_evt->conn_handle,
p_evt->params.conn_sec_succeeded.procedure);
} break;
case PM_EVT_CONN_SEC_FAILED:
/* Often, when securing fails, it shouldn't be restarted, for security reasons.
* Other times, it can be restarted directly.
* Sometimes it can be restarted, but only after changing some Security Parameters.
* Sometimes, it cannot be restarted until the link is disconnected and reconnected.
* Sometimes it is impossible, to secure the link, or the peer device does not support it.
* How to handle this error is highly application dependent. */
} break;
case PM_EVT_CONN_SEC_CONFIG_REQ:
// Reject pairing request from an already bonded peer.
pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
} break;
case PM_EVT_STORAGE_FULL:
// Run garbage collection on the flash.
err_code = fds_gc();
if (err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
// Retry.
} break;
NRF_LOG_DEBUG("PM_EVT_PEERS_DELETE_SUCCEEDED");
advertising_start(false);
} break;
case PM_EVT_PEER_DATA_UPDATE_FAILED:
// Assert.
APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error);
} break;
case PM_EVT_PEER_DELETE_FAILED:
// Assert.
APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error);
} break;
case PM_EVT_PEERS_DELETE_FAILED:
// Assert.
APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error);
} break;
case PM_EVT_ERROR_UNEXPECTED:
// Assert.
APP_ERROR_CHECK(p_evt->params.error_unexpected.error);
} break;
case PM_EVT_CONN_SEC_START:
case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
case PM_EVT_PEER_DELETE_SUCCEEDED:
case PM_EVT_LOCAL_DB_CACHE_APPLIED:
case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
// This can happen when the local DB has changed.
case PM_EVT_SERVICE_CHANGED_IND_SENT:
case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
/**@brief Function for performing battery measurement and updating the Battery Level characteristic
* in Battery Service.
static void battery_level_update(void)
uint8_t battery_level;
battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
err_code = ble_bas_battery_level_update(&m_bas, battery_level, BLE_CONN_HANDLE_ALL);
if ((err_code != NRF_SUCCESS) &&
(err_code != NRF_ERROR_INVALID_STATE) &&
(err_code != NRF_ERROR_BUSY) &&
(err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
APP_ERROR_HANDLER(err_code);
static void wakeup_timeout_handler(void * p_context)
bool erase_bonds;
UNUSED_PARAMETER(p_context);
NRF_LOG_INFO("\n WakeUp");
/* if (erase_bonds == true)
delete_bonds();
err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_DIRECTED);
advertising_start(erase_bonds);
/**@brief Function for handling the Battery measurement timer timeout.
* @details This function will be called each time the battery level measurement timer expires.
* @param[in] p_context Pointer used for passing some arbitrary information (context) from the
* app_start_timer() call to the timeout handler.
static void battery_level_meas_timeout_handler(void * p_context)
battery_level_update();
/**@brief Function for handling the Heart rate measurement timer timeout.
* @details This function will be called each time the heart rate measurement timer expires.
* It will exclude RR Interval data from every third measurement.
static void heart_rate_meas_timeout_handler(void * p_context)
static uint32_t cnt = 0;
uint16_t heart_rate;
heart_rate = (uint16_t)sensorsim_measure(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
cnt++;
err_code = ble_hrs_heart_rate_measurement_send(&m_hrs, heart_rate);
// Disable RR Interval recording every third heart rate measurement.
// NOTE: An application will normally not do this. It is done here just for testing generation
// of messages without RR Interval measurements.
m_rr_interval_enabled = ((cnt % 3) != 0);
/**@brief Function for handling the RR interval timer timeout.
* @details This function will be called each time the RR interval timer expires.
static void rr_interval_timeout_handler(void * p_context)
if (m_rr_interval_enabled)
uint16_t rr_interval;
rr_interval = (uint16_t)sensorsim_measure(&m_rr_interval_sim_state,
&m_rr_interval_sim_cfg);
ble_hrs_rr_interval_add(&m_hrs, rr_interval);
/**@brief Function for handling the Sensor Contact Detected timer timeout.
* @details This function will be called each time the Sensor Contact Detected timer expires.
static void sensor_contact_detected_timeout_handler(void * p_context)
static bool sensor_contact_detected = false;
sensor_contact_detected = !sensor_contact_detected;
ble_hrs_sensor_contact_detected_update(&m_hrs, sensor_contact_detected);
/**@brief Function for the Timer initialization.
* @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
// Initialize timer module.
err_code = app_timer_init();
// Create timers.
err_code = app_timer_create(&wakeup_timer_id,
APP_TIMER_MODE_REPEATED,
wakeup_timeout_handler);
// Create timers.
err_code = app_timer_create(&m_battery_timer_id,
battery_level_meas_timeout_handler);
err_code = app_timer_create(&m_heart_rate_timer_id,
heart_rate_meas_timeout_handler);
err_code = app_timer_create(&m_rr_interval_timer_id,
rr_interval_timeout_handler);
err_code = app_timer_create(&m_sensor_contact_timer_id,
sensor_contact_detected_timeout_handler);
* @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
* device including the device name, appearance, and the preferred connection parameters.
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_HEART_RATE_SENSOR_HEART_RATE_BELT);
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
/**@brief GATT module event handler.
static void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
NRF_LOG_INFO("GATT ATT MTU on connection 0x%x changed to %d.",
p_evt->conn_handle,
p_evt->params.att_mtu_effective);
ble_hrs_on_gatt_evt(&m_hrs, p_evt);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
* @details Initialize the Heart Rate, Battery and Device Information services.
ble_hrs_init_t hrs_init;
ble_bas_init_t bas_init;
ble_dis_init_t dis_init;
uint8_t body_sensor_location;
// Initialize Heart Rate Service.
body_sensor_location = BLE_HRS_BODY_SENSOR_LOCATION_FINGER;
memset(&hrs_init, 0, sizeof(hrs_init));
hrs_init.evt_handler = NULL;
hrs_init.is_sensor_contact_supported = true;
hrs_init.p_body_sensor_location = &body_sensor_location;
// Here the sec level for the Heart Rate Service can be changed/increased.
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&hrs_init.hrs_hrm_attr_md.cccd_write_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_hrm_attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_hrm_attr_md.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&hrs_init.hrs_bsl_attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_bsl_attr_md.write_perm);
err_code = ble_hrs_init(&m_hrs, &hrs_init);
// Initialize Battery Service.
memset(&bas_init, 0, sizeof(bas_init));
// Here the sec level for the Battery Service can be changed/increased.
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_char_attr_md.cccd_write_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_char_attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&bas_init.battery_level_char_attr_md.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_report_read_perm);
bas_init.evt_handler = NULL;
bas_init.support_notification = true;
bas_init.p_report_ref = NULL;
bas_init.initial_batt_level = 100;
err_code = ble_bas_init(&m_bas, &bas_init);
// Initialize Device Information Service.
memset(&dis_init, 0, sizeof(dis_init));
ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, (char *)MANUFACTURER_NAME);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&dis_init.dis_attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&dis_init.dis_attr_md.write_perm);
err_code = ble_dis_init(&dis_init);
/**@brief Function for initializing the sensor simulators.
static void sensor_simulator_init(void)
m_battery_sim_cfg.min = MIN_BATTERY_LEVEL;
m_battery_sim_cfg.max = MAX_BATTERY_LEVEL;
m_battery_sim_cfg.incr = BATTERY_LEVEL_INCREMENT;
m_battery_sim_cfg.start_at_max = true;
sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
m_heart_rate_sim_cfg.min = MIN_HEART_RATE;
m_heart_rate_sim_cfg.max = MAX_HEART_RATE;
m_heart_rate_sim_cfg.incr = HEART_RATE_INCREMENT;
m_heart_rate_sim_cfg.start_at_max = false;
sensorsim_init(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
m_rr_interval_sim_cfg.min = MIN_RR_INTERVAL;
m_rr_interval_sim_cfg.max = MAX_RR_INTERVAL;
m_rr_interval_sim_cfg.incr = RR_INTERVAL_INCREMENT;
m_rr_interval_sim_cfg.start_at_max = false;
sensorsim_init(&m_rr_interval_sim_state, &m_rr_interval_sim_cfg);
/**@brief Function for starting application timers.
static void application_timers_start(void)
// Start application timers.
err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
err_code = app_timer_start(m_heart_rate_timer_id, HEART_RATE_MEAS_INTERVAL, NULL);
err_code = app_timer_start(m_rr_interval_timer_id, RR_INTERVAL_INTERVAL, NULL);
err_code = app_timer_start(m_sensor_contact_timer_id, SENSOR_CONTACT_DETECTED_INTERVAL, NULL);
err_code = app_timer_start(wakeup_timer_id, WAKE_UP_INTERVAL, NULL);
/**@brief Function for handling the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module which
* are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply
* setting the disconnect_on_fail config parameter, but instead we use the event
* handler mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
/**@brief Function for handling a Connection Parameters error.
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = m_hrs.hrm_handles.cccd_handle;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
// Prepare wakeup buttons.
// err_code = sd_power_system_off();
* @param[in] ble_adv_evt Advertising event.
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
NRF_LOG_INFO("Fast advertising.");
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
case BLE_ADV_EVT_WHITELIST_REQUEST:
NRF_LOG_INFO("Here in BLE_ADV_EVT_WHITELIST_REQUEST ");
/*ble_gap_addr_t whitelist_addr = {1, BLE_GAP_ADDR_TYPE_PUBLIC, {0x2B, 0xE1, 0xD6, 0x60, 0xC7, 0x44}};
const ble_gap_addr_t *p_whitelist_addr[1] = {&whitelist_addr};
err_code = sd_ble_gap_whitelist_set(p_whitelist_addr, 1);
err_code = ble_advertising_whitelist_reply(&m_advertising,&whitelist_addr, 1, NULL, 0);
APP_ERROR_CHECK(err_code);*/
/* peak_rssi.peer_addr.addr[0] =0x15;
peak_rssi.peer_addr.addr[1] =0x00;
peak_rssi.peer_addr.addr[2] =0x20;
peak_rssi.peer_addr.addr[3] =0x84;
peak_rssi.peer_addr.addr[4] =0x40;
peak_rssi.peer_addr.addr[5] =0x00;*/
ble_gap_addr_t whitelist_addr = peak_rssi.peer_addr;
NRF_LOG_INFO_ARRAY(whitelist_addr.addr,BLE_GAP_ADDR_LEN);
NRF_LOG_INFO("\n WL = %d \n",0);
case BLE_ADV_EVT_PEER_ADDR_REQUEST:
NRF_LOG_INFO("Requesting peer address \n ");
NRF_LOG_INFO("peer address = %d \n ",peak_rssi.rssi);
NRF_LOG_INFO_ARRAY(peak_rssi.peer_addr.addr,BLE_GAP_ADDR_LEN);
// err_code = ble_advertising_peer_addr_reply(&m_advertising,&peak_rssi.peer_addr);
NRF_LOG_INFO("Requesting peer address END \n ");
void NRF_LOG_INFO_ARRAY(uint8_t * array, uint8_t array_size)
for(int i = 0; i < array_size; i++)
NRF_LOG_RAW_INFO("0x%x ",array[i]);
NRF_LOG_RAW_INFO("\r\n");
void populate_report( ble_gap_evt_scan_req_report_t * scanreport )
NRF_LOG_INFO("received = %d",scanreport->rssi);
NRF_LOG_INFO("before peak = %d ",peak_rssi.rssi);
NRF_LOG_INFO_ARRAY(scanreport->peer_addr.addr,BLE_GAP_ADDR_LEN);
if(peak_rssi.rssi < scanreport->rssi )
NRF_LOG_INFO(" Inside Peak");
strncpy(peak_rssi.peer_addr.addr,scanreport->peer_addr.addr,BLE_GAP_ADDR_LEN);
peak_rssi.rssi = scanreport->rssi;
NRF_LOG_INFO("after peak = %d ",peak_rssi.rssi);
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
ble_gap_addr_t peer_address_cent;
int8_t rssi_cent;
ble_gap_evt_scan_req_report_t * report;
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected hrs.");
NRF_LOG_INFO_ARRAY(p_ble_evt->evt.gap_evt.params.connected.peer_addr.addr,BLE_GAP_ADDR_LEN);
NRF_LOG_INFO("TYPE = %d",p_ble_evt->evt.gap_evt.params.connected.peer_addr.addr_type);
NRF_LOG_INFO("Disconnected, reason %d.",
p_ble_evt->evt.gap_evt.params.disconnected.reason);
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
case BLE_GAP_EVT_SCAN_REQ_REPORT:
NRF_LOG_INFO("In scan req report ");
// no = 6;
// sprintf(&strDeviceName[0], "%s%05d\0", &DEVICE_NAME[0], no);
report = &(p_ble_evt->evt.gap_evt.params.scan_req_report);
//memcpy(&report, &p_ble_evt->evt.gap_evt.params.scan_req_report, sizeof(p_ble_evt->evt.gap_evt.params.scan_req_report));
rssi_cent = p_ble_evt->evt.gap_evt.params.scan_req_report.rssi;
peer_address_cent = p_ble_evt->evt.gap_evt.params.scan_req_report.peer_addr;
NRF_LOG_INFO("rssi = %d",rssi_cent );
NRF_LOG_INFO_ARRAY(peer_address_cent.addr,BLE_GAP_ADDR_LEN);
// NRF_LOG_INFO_ARRAY(report->peer_addr.addr,BLE_GAP_ADDR_LEN);
populate_report(report);
/* NRF_LOG_INFO("addr = %x",peer_address_cent.addr[0] );
NRF_LOG_INFO("addr = %x",peer_address_cent.addr[1] );
NRF_LOG_INFO("addr = %x",peer_address_cent.addr[2] );
NRF_LOG_INFO("addr = %x",peer_address_cent.addr[3] );
NRF_LOG_INFO("addr = %x",peer_address_cent.addr[4] );
NRF_LOG_INFO("addr = %x",peer_address_cent.addr[5] );*/
NRF_LOG_INFO("End");
// No implementation needed.
uint32_t ram_start = 0;
// Enable BLE stack.
* @param[in] event Event generated by button press.
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
case BSP_EVENT_DISCONNECT:
case BSP_EVENT_WHITELIST_OFF:
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
err_code = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
err_code = fds_register(fds_evt_handler);
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.include_appearance = true;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
init.advdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
init.config.ble_adv_directed_interval = APP_ADV_INTERVAL;
init.config.ble_adv_directed_timeout = APP_ADV_DURATION;
init.config.ble_adv_whitelist_enabled =true; //gk for whitelist
init.config.ble_adv_directed_enabled =true; //gk for directed
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
bsp_event_t startup_event;
err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
nrf_pwr_mgmt_run();
/**@brief Function for application main entry.
bool erase_bonds;
peak_rssi.rssi = -90;
// Initialize.
log_init();
timers_init();
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
advertising_init();
services_init();
sensor_simulator_init();
conn_params_init();
peer_manager_init();
// Start execution.
NRF_LOG_INFO("Heart Rate Sensor example started.");
application_timers_start();
// Enter main loop.
for (;;)
idle_state_handle();
Please correct me if I am missing something or done something wrong?
