I am using the ble_app_uart code from SDK 6.0 on my custom PCB with a nrf51822. I am comparing it's functionality with a PCA10004. Both are running the exact same code. I'm also using both the Master Control Panel and an iphone 5S (running nrf UART) to interact with them.
I am getting different results between my PCB and the PCA10004 and I am trying to track down the issue.
Here's what is happening... using the custom PCB and the iphone nrf UART app, I can connect to the device, but during that process a BLE_GAP_EVT_SEC_INFO_REQUEST event (seen using the debugger) which errors out with "No keys found for this device" . After that, any attempts to send data from the iphone to the app fail to generate the nus_data_handler call.
If I do the same test with the PCA10004 and the iphone, I never see the BLE_GAP_EVT_SEC_INFO_REQUEST event and data is transferred back and forth just fine.
If I try my custom PCB and use the Master Control Panel software to connect, do a service discovery, and then send some data, I never get the BLE_GAP_EVT_SEC_INFO_REQUEST and the data is transferred successfully.
So, there is something going on between my custom board and the iphone that is triggering this security request. I have tried turning bonding off. I've verified that in the gap init function, we are using BLE_GAP_CONN_SEC_MODE_SET_OPEN, which I'm assuming to mean that there is no security/encryption.
Any thoughts/suggestions would be helpful.
Thanks.
