i am using nrf52840 sdk 14.2 s140
i want to advertise in a single channel and which app is used to trace on which channel is advertising
Hi.
Bluetooth Low Energy advertises by hopping between three different channels, that is channel 37, 38, and 39.
If you want to advertise on a single channel, you simply have to turn off two of the three channels.
You can find this in the infocenter here.
Example:
ble_gap_adv_params_t adv_params;
adv_params.channel_mask.ch_37_off = 1;
adv_params.channel_mask.ch_38_off = 1;
- Andreas
i tried and how to check whether ble is transmitting on the particular channel
Hi.
Well as i said, BLE is always advertising on 3 channels, and skips between the 3 channels.
This means that BLE does not advertise on a particular channel.
If you want to advertise on a particular channel, you have to turn off two channels, like I showed in my previous reply.
- Andreas
ok is there any application which shows the ble is advertising on particular chaNNEL
Hi.
No, there is not any example applications where advertising happens on a particular channel.
But you can add the code in my previous reply to any example found in the \ble_peripheral folder.
Let me show you here:
Open the ble_app_blinky project in the folder \nRF5_SDK_14.2.0_17b948a\examples\ble_peripheral\ble_app_blinky\pca10056\s140 in your prefered IDE.
Find the static void advertising_start(void) function in main.c
If you want to turn of channel 37, add the code:
adv_params.channel_mask.ch_39_off = 1;
ret_code_t err_code;
// Start advertising
memset(&adv_params, 0, sizeof(adv_params));
adv_params.type = BLE_GAP_ADV_TYPE_ADV_IND;
adv_params.p_peer_addr = NULL;
adv_params.fp = BLE_GAP_ADV_FP_ANY;
adv_params.interval = APP_ADV_INTERVAL;
adv_params.timeout = APP_ADV_TIMEOUT_IN_SECONDS;
err_code = sd_ble_gap_adv_start(&adv_params, APP_BLE_CONN_CFG_TAG);
bsp_board_led_on(ADVERTISING_LED);
}- Andreas
