Can a Peripheral device know the RSSI for a connected Central
Hello fellow Nordic community,
Assume that a given Peripheral (P) is advertising a BLE GAP signal which allows for multiple connections to be made.
In the vicinity to P we have two central devices (C1, C2) that hear the advertisement signal and connect to P.
(P) - - - - - - < 5 m > - - - - - - (C1)
  - - - - - - - - - - <  10m > - - - - - - - - - - - - - - - - - - - - - - - - - - - - (C2)
Is it possible to determine on the Peripheral side which connected Central (C1 or C2) that's signal-wise closest to the Peripheral. Hence in the above example determine that C1 is closer than C2?
Thanks for any help!
Cheers,
Kristian
  • Hi.
    You can use the two functions sd_ble_gap_rssi_get() and sd_ble_gap_rssi_start() to get the RSSI value between a given peripheral and a central.
    You can find more information about these functions in the infocenter under:
    nRF52 Series -> SoftDevices -> Your SoftDevice -> Your SoftDevice API -> Your SoftDevice version API -> API Reference -> Generic Access Profile (GAP)
    Here is the link to the infocenter.
    With RSSI you can't really state which device is closest in distance, since RSSI is a measurement of signal strength, and lots of factors play a part in that value.
    I can give you an example: If there is a wall between P and C1, but P and C2 are in line of sight with no obstacles, you might get a higher RSSI value for C2 then C1 even though C2 is 5 meter further away from P.
    - Andreas
  • Thanks Andreas,
    I get that the actual distance is hard to estimate given a bunch of factors that affects the signal strength.
    I read from your answer that it is possible on the Peripheral side to know the RSSI to a given connected Central. Is that correct?
    Do you know of any examples that show how this could be done?
    Thank you so much for all the help!
  • Hi.
    I can show you how I did it.
    I used the examples\ble_peripheral\ble_app_uart example in SDK 15.0 for this. I did the following in main.c:
    To get a continuous RSSI value I created a timer, which I first defined in the header, like this:
    (Library and API for the timer)
    APP_TIMER_DEF(my_timer_id);
    I then created the timer in int main(void) with the following code (ADDED BY ME):
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        uint32_t err_code = app_timer_create(&my_timer_id, APP_TIMER_MODE_REPEATED , timeout_handler); //ADDED BY ME
        APP_ERROR_CHECK(err_code);// ADDED BY ME
        // Start execution.
        advertising_start();
        // Enter main loop.
        for (;;)
            idle_state_handle();
    The timer required a timeout handler, which I created above int main(void), which looked like this:
    static void timeout_handler(void *timeoutpointer)
                uint8_t rssi;
                uint8_t channel;
                uint32_t err_code = sd_ble_gap_rssi_get(m_conn_handle,&rssi,&channel);
                NRF_LOG_INFO("RSSI: %d", rssi);
    It was in the timeout_handler I collected and printed the RSSI values.
    I started the timer in the case BLE_GAP_EVT_CONNECTED found in static void ble_evt_handler(ble_evt_t const * p_ble_evt, void * p_context)
    I added the following code before the switch case in the ble_evt_handler:
        uint32_t err_code;
        ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt; // ADDED BY ME
    In the BLE_GAP_EVT_CONNECTED case i added the following code:
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                err_code = sd_ble_gap_rssi_start(p_ble_evt->evt.gap_evt.conn_handle,BLE_GAP_RSSI_THRESHOLD_INVALID,0); //ADDED BY ME
                APP_ERROR_CHECK(err_code); //ADDED BY ME
                err_code = app_timer_start(my_timer_id,APP_TIMER_TICKS(5000),0); //ADDED BY ME
    I then compiled programmed the example and got roughly the same RSSI in dBm as in nRF Connect between the two devices.
    Hope this helps.
    - Andreas
  • Awesome, thanks for the examples. I tried it myself and it seems to work fine.
    Thank you for this example. It definitely works fine.
    I had another doubt, is it possible to display the RSSI value on the Serial Interface ? I'm using PuTTY, and I wanted to display the RSSI values on it
