Mesh SDK 2.2.0 Bug in mesh_opt_core_adv_set
I have an application using mesh SDK 2.1.1 that is working.    I am migrating to V2.2.0.  In my current code I use nrf_mesh_opt_set()  to enable and disable a relay feature.   I read the migration guide :
https://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.meshsdk.v2.0.1%2Findex.html
and it indicates that mesh_opt_core_adv_set() is the new way to set options.    Using this new API I consistently get an assertion:
app_error_weak.c,   95, Mesh assert at 0x0002A384 (:0)
I looked at the code in config_server.c for an example.  I tried something very simple:
mesh_opt_core_adv_get(CORE_TX_ROLE_RELAY,&relay_state);
relay_state.enable = false;
mesh_opt_core_adv_set(CORE_TX_ROLE_RELAY,&relay_state);
This always results in the app_error_weak assertion.   The "get" operation returns data in the struct that looks OK.   The assertion happens in the set operation. The code that handles internal storage is quite complex so I am trying to get to the bottom of where this assertion is being thrown.
Also,   when I use the old API:
param_value.opt.val = 0;
nrf_mesh_opt_set(NRF_MESH_OPT_NET_RELAY_ENABLE, &param_value)
I get the same result.      The only solution now is to go back to V2.1.1
I tried performing a full chip erase to clear the persistent data but have not had any success.
  • Just an update:
    This project is based up the light switch proxy client.  Most of my application is run from the main loop which uses:
    bool done = nrf_mesh_process();
    if (done)
    sd_app_evt_wait();
    if I change the mesh stack init params to:
     .core.irq_priority       = NRF_MESH_IRQ_PRIORITY_THREAD,
    The options api works BUT the proxy subsystem not throws  an assertion when I try to provision the device from the NRFMesh android app:
    app_error_weak.c,   95, Mesh assert at 0x0002A3C6
    which appears to check
    bearer_event_in_correct_irq_priority()
    What is the correct settings for using the proxy and running mesh api from the main application loop?
    This has been reported internally, will update you when I get an answer from the team.
    UPDATE: The solution is to call any runtime mesh configuration functions (like mesh_opt_core_adv_set()) inside static void start(void) function only before mesh_stack_start() call, e.g.:
        rtt_input_enable(app_rtt_input_handler, RTT_INPUT_POLL_PERIOD_MS);
        // <- Call mesh_opt_core_adv_set() here
        ERROR_CHECK(mesh_stack_start());
    In addition to this it will be required to add some changes to mesh/stack/src/mesh_stack.c. I have attached the original, the fixed and the diff file below:
    /* Copyright (c) 2010 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
     * list of conditions and the following disclaimer.
    #include "mesh_stack.h"
    #include "nrf_mesh_events.h"
    #include "access_config.h"
    #include "flash_manager.h"
    #include "device_state_manager.h"
    #include "config_server.h"
    #include "health_server.h"
    #include "net_state.h"
    #include "hal.h"
    #include "mesh_config.h"
    #include "mesh_config_backend_glue.h"
    #if GATT_PROXY
    #include "proxy.h"
    static health_server_t m_health_server;
    static void device_reset(void)
        hal_device_reset(0);
    uint32_t mesh_stack_init(const mesh_stack_init_params_t * p_init_params,
                             bool * p_device_provisioned)
        uint32_t status;
        if (p_init_params == NULL)
            return NRF_ERROR_NULL;
        /* Initialize the mesh stack */
        status = nrf_mesh_init(&p_init_params->core);
        if (status != NRF_SUCCESS)
            return status;
        /* Initialize the access layer */
        dsm_init();
        access_init();
        /* Initialize the configuration server */
        status = config_server_init(p_init_params->models.config_server_cb);
            return status;
        /* Initialize the health server for the primary element */
        status = health_server_init(&m_health_server, 0, DEVICE_COMPANY_ID,
                                    p_init_params->models.health_server_attention_cb,
                                    p_init_params->models.p_health_server_selftest_array,
                                    p_init_params->models.health_server_num_selftests);
            return status;
        /* Give application opportunity to initialize application specific models */
        if (p_init_params->models.models_init_cb != NULL)
            p_init_params->models.models_init_cb();
        /* Load configuration, and check if the device has already been provisioned */
        mesh_config_load();
        (void) dsm_flash_config_load();
        (void) access_flash_config_load();
        bool is_provisioned = mesh_stack_is_device_provisioned();
    #if GATT_PROXY
        if (is_provisioned)
            proxy_init();
        if (p_device_provisioned != NULL)
            *p_device_provisioned = is_provisioned;
        return NRF_SUCCESS;
    uint32_t mesh_stack_start(void)
        /* If the device is provisioned, the proxy state is automatically recovered from flash when
         * mesh_config loads the configuration. */
        uint32_t status = nrf_mesh_enable();
    #if GATT_PROXY
        if (status == NRF_SUCCESS &&
            mesh_stack_is_device_provisioned() &&
            proxy_is_enabled())
            (void) proxy_start();
        return status;
    uint32_t mesh_stack_provisioning_data_store(const nrf_mesh_prov_provisioning_data_t * p_prov_data,
                                                const uint8_t * p_devkey)
        dsm_handle_t netkey_handle, devkey_handle;
        dsm_local_unicast_address_t local_address;
        local_address.address_start = p_prov_data->address;
        local_address.count = ACCESS_ELEMENT_COUNT;
        uint32_t status;
        /* Store received provisioning data in the DSM */
        status = dsm_local_unicast_addresses_set(&local_address);
            return status;
        status = dsm_subnet_add(p_prov_data->netkey_index, p_prov_data->netkey, &netkey_handle);
            return status;
        status = dsm_devkey_add(p_prov_data->address, netkey_handle, p_devkey, &devkey_handle);
            return status;
        NRF_MESH_ERROR_CHECK(net_state_iv_index_set(p_prov_data->iv_index, p_prov_data->flags.iv_update));
        /* Bind config server to the device key */
        status = config_server_bind(devkey_handle);
            return status;
        /* Store new config server binding. */
        access_flash_config_store();
        return status;
    void mesh_stack_config_clear(void)
        access_clear();
        dsm_clear();
        net_state_reset();
    bool mesh_stack_is_device_provisioned(void)
        dsm_local_unicast_address_t addr;
        dsm_local_unicast_addresses_get(&addr);
        return (addr.address_start != NRF_MESH_ADDR_UNASSIGNED);
    #if PERSISTENT_STORAGE
    static void mesh_evt_handler(const nrf_mesh_evt_t * p_evt)
        if (p_evt->type == NRF_MESH_EVT_FLASH_STABLE)
            device_reset();
    void mesh_stack_device_reset(void)
        /* We have to do this elaborate dance to avoid nested
         * calls to bearer event. It should be possible to call this
         * function from within a bearer_event_process context.
        if (flash_manager_is_stable())
            device_reset();
            static nrf_mesh_evt_handler_t s_evt_handler = {
                .evt_cb = mesh_evt_handler
            nrf_mesh_evt_handler_add(&s_evt_handler);
    #else
        device_reset();
    #endif  /* PERSISTENT_STORAGE */
    uint32_t mesh_stack_persistence_flash_usage(const uint32_t ** pp_start, uint32_t * p_length)
        if (pp_start == NULL || p_length == NULL)
        mesh_config_backend_flash_usage_t mesh_config_usage;
        mesh_config_backend_flash_usage_get(&mesh_config_usage);
        if (mesh_config_usage.p_start != NULL)
            *pp_start = mesh_config_usage.p_start;
            /* If there's no mesh config present in flash, access holds the lowest flash area. */
            *pp_start = access_flash_area_get();
        *p_length = (((const uint8_t *) flash_manager_recovery_page_get()) - ((const uint8_t *) *pp_start) + PAGE_SIZE);
    #else
        *pp_start = NULL;
        *p_length = 0;
        return NRF_SUCCESS;
    #include "hal.h"
    #if GATT_PROXY
    #include "proxy.h"
    #include "nrf_nvic.h"
    #include "mesh_app_utils.h"
        uint32_t status;
            return status;
        dsm_init();
        access_init();
            return status;
            return status;
        uint8_t is_nested;
        ERROR_CHECK(sd_nvic_critical_region_enter(&is_nested));
        mesh_config_load();
    #if GATT_PROXY
        if (is_provisioned)
            proxy_init();
        ERROR_CHECK(sd_nvic_critical_region_exit(is_nested));
        return NRF_SUCCESS;
    #if GATT_PROXY
            proxy_is_enabled())
        return status;
        uint32_t status;
            return status;
            return status;
            return status;
            return status;
        return status;
        access_clear();
        dsm_clear();
        net_state_reset();
            device_reset();
            device_reset();
    #else
        device_reset();
    #else
        *pp_start = NULL;
        *p_length = 0;
        return NRF_SUCCESS;
    --- mesh_stack_orig.c	2018-09-20 15:55:47.109248666 +0200
    +++ mesh_stack_fixed.c	2018-09-20 15:55:50.709248666 +0200
    @@ -51,6 +51,9 @@
     #include "proxy.h"
    +#include "nrf_nvic.h"
    +#include "mesh_app_utils.h"
    @@ -102,6 +105,9 @@
    +    uint8_t is_nested;
    +    ERROR_CHECK(sd_nvic_critical_region_enter(&is_nested));
         mesh_config_load();
    @@ -122,6 +128,8 @@
    +    ERROR_CHECK(sd_nvic_critical_region_exit(is_nested));
         return NRF_SUCCESS;
  • Thanks for the update.
    A question about this:
    >>UPDATE: The solution is to call any runtime mesh configuration functions (like mesh_opt_core_adv_set()) inside static >>void start(void) function only before mesh_stack_start() call, e.g.:
    In my application,   some of the options need to be performed at run-time.  i.e. change transmit power,  toggle relay functionality, etc.      Will this restriction remain moving forward?
    My system has another way of storing persistent data and I currently have my own hooks into the mesh stack to change options.  I am trying to get a feel for what API I should plan on using moving forward.   For now, I am going to stick with 2.1.1 but would like to make migration to future versions easier.
    One of our developers suggested the following:
    Call any runtime mesh configuration functions (like mesh_opt_core_adv_set()) between calls sd_nvic_critical_region_enter()/_exit(), e.g.:
    uint8_t is_nested;
    // Call mesh_opt_core_adv_set(...) here
