Custom board reboot at high cosumption
Hi, I have a problem with my custom PCB.
Im ussing Segger in Mac, the latest sdk (15.02) and the latest softdevice too.
I have a custom pcb with a buzzer and when i try to turn on, the pcb lost the connection and reboot itself.
But the strange its that, if i have the jlink wire connected the buzzer works like a charm and dosnt reboot.
Can you help me please¿? thanks !
  • I need some more info, can you post the schematic please?
  • Yes sure!!
    I have a custom with nrf58232 with a pair of leds in two pines separated respectively.
    In a another pin i have a buzzer.
    Here are the jlink wires, and the way of program it.
    The custom board works perfectly in my old sdk (13) and I can toogle the buzzer  without problems.
    Now Im making the project again in the new sdk (15.2) and the first thing that I'm doing its toogle the buzzer with the methods bsp_board_leds_on() and bsp_board_leds_off()( I also test the method for single pines bsp_boards_led_on(PIN_NUMBER) ) in the nus_data_handler() method.
    And the problem is that, when I connect the JLINK wires the PCB works perfectly, can toogle all components inside the nus_data_handler but without wires I can't work in the method, when I try to turn on the buzzer the pcb reboot, however before the main loop, I can toogle it.
    Can be because have a high compsuption with the buzzer and the BLE connection togheter ? but in the older SDK was working
  • I'm keep triying to work but I dont have result.
    With only the VCC and ground connected works like a charm !! But it not a hardware problem 100% certified because in the last SDK was working without problems.
    Also, reading the documentation i added before try to turn on the buzzer the method:
    nrf_pwr_mgmt_feed();
    but the same, the pcb reboots when the buzzer will turn on.
    another test, If It be with the jlink wires and I turn on the buzzer, and then
    remove the wires, the buzzer keep on, and I keep the connection alive and can turn off again.
    What can be it ?? thanks !!
  • Sounds SW related, the CPU hard faults when you turn on the buzzer. Can you post the code?
  • yes sure ! Here is the code :
    #include <stdint.h>
    #include <string.h>
    #include <ble/ble_services/ble_nus/ble_nus.h>
    #include "nrf_drv_twi.h"
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_delay.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME "NORDIC TEST" /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL 64 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS) /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS) /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY 0 /**< Slave latency. */
    #define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
    const uint8_t MEM_STEP = 8;
    char thisAction;
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT); /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
    NRF_BLE_QWR_DEF(
    m_qwr); /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
    static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
    static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT -
    3; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifier. */
    STC3115_ConfigData_TypeDef STC3115_ConfigData;
    STC3115_BatteryData_TypeDef STC3115_BatteryData;
    static const nrf_drv_twi_t m_twi_master = NRF_DRV_TWI_INSTANCE(0);
    /**@brief Function for assert macro callback.
    * @warning This handler is an example only and does not fit a final product. You need to analyse
    * how your product is supposed to react in case of Assert.
    * @param[in] line_num Line number of the failing ASSERT call.
    * @param[in] p_file_name File name of the failing ASSERT call.
    void assert_nrf_callback(uint16_t line_num, const uint8_t *p_file_name) {
    /**@brief Function for initializing the timer module.
    static void timers_init(void) {
    ret_code_t
    err_code = app_timer_init();
    * the device. It also sets the permissions and appearance.
    static void gap_params_init(void) {
    uint32_t
    err_code;
    ble_gap_conn_params_t gap_conn_params;
    strlen(DEVICE_NAME));
    gap_conn_params.slave_latency = SLAVE_LATENCY;
    gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
    * application about an error.
    * @param[in] nrf_error Error code containing information about what went wrong.
    static void nrf_qwr_error_handler(uint32_t nrf_error) {
    APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
    * @details This function will process the data received from the Nordic UART BLE Service and send
    * it to the UART module.
    * @param[in] p_evt Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
    static void nus_data_handler(ble_nus_evt_t *p_evt) {
    if (p_evt->type == BLE_NUS_EVT_RX_DATA) {
    uint32_t
    err_code;
    for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++) {
    do {
    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
    thisAction = p_evt->params.rx_data.p_data[0];
    NRF_LOG_ERROR("%c", thisAction);
    if (thisAction == 0x61) { //a ALERT
    // NRF_LOG_ERROR("%s", "OK_A");
    bsp_board_leds_off();
    if (thisAction == 0x62) {
    // NRF_LOG_ERROR("%s", "OK_B");
    bsp_board_leds_on();
    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY)) {
    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
    } while (err_code == NRF_ERROR_BUSY);
    if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r') {
    while (app_uart_put('\n') == NRF_ERROR_BUSY);
    static void services_init(void) {
    uint32_t
    err_code;
    ble_nus_init_t nus_init;
    // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
    * @details This function will be called for all events in the Connection Parameters Module
    * which are passed to the application.
    * @note All this function does is to disconnect. This could have been done by simply setting
    * the disconnect_on_fail config parameter, but instead we use the event handler
    * mechanism to demonstrate its use.
    * @param[in] p_evt Event received from the Connection Parameters Module.
    static void on_conn_params_evt(ble_conn_params_evt_t *p_evt) {
    uint32_t
    err_code;
    if (p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED) {
    /**@brief Function for handling errors from the Connection Parameters module.
    static void conn_params_error_handler(uint32_t nrf_error) {
    static void conn_params_init(void) {
    uint32_t
    err_code;
    cp_init.p_conn_params = NULL;
    cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
    cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
    cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
    cp_init.disconnect_on_fail = false;
    cp_init.evt_handler = on_conn_params_evt;
    cp_init.error_handler = conn_params_error_handler;
    static void sleep_mode_enter(void) {
    // uint32_t
    // err_code
    //// = bsp_indication_set(BSP_INDICATE_IDLE);
    //// APP_ERROR_CHECK(err_code);
    // // Prepare wakeup buttons.
    // err_code = bsp_btn_ble_sleep_mode_prepare();
    // // Go to system-off mode (this function will not return; wakeup will cause a reset).
    // err_code = sd_power_system_off();
    * @param[in] ble_adv_evt Advertising event.
    static void on_adv_evt(ble_adv_evt_t ble_adv_evt) {
    uint32_t
    err_code;
    switch (ble_adv_evt) {
    case BLE_ADV_EVT_FAST:
    // err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING);
    case BLE_ADV_EVT_IDLE:
    sleep_mode_enter();
    * @param[in] p_ble_evt Bluetooth stack event.
    * @param[in] p_context Unused.
    static void ble_evt_handler(ble_evt_t const *p_ble_evt, void *p_context) {
    uint32_t
    err_code;
    switch (p_ble_evt->header.evt_id) {
    case BLE_GAP_EVT_CONNECTED:
    NRF_LOG_INFO("Connected");
    // err_code = bsp_indication_set(BSP_INDICATE_CONNECTED);
    NRF_LOG_INFO("Disconnected");
    case BLE_GAP_EVT_PHY_UPDATE_REQUEST: {
    ble_gap_phys_t const phys =
    .rx_phys = BLE_GAP_PHY_AUTO,
    .tx_phys = BLE_GAP_PHY_AUTO,
    // Pairing not supported
    case BLE_GATTC_EVT_TIMEOUT:
    case BLE_GATTS_EVT_TIMEOUT:
    // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
    * @details This function initializes the SoftDevice and the BLE event interrupt.
    static void ble_stack_init(void) {
    ret_code_t
    err_code;
    uint32_t
    ram_start = 0;
    // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t *p_gatt, nrf_ble_gatt_evt_t const *p_evt) {
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)) {
    m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
    NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
    p_gatt->att_mtu_desired_central,
    p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void) {
    ret_code_t
    err_code;
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
    * @param[in] event Event generated by button press.
    void bsp_event_handler(bsp_event_t event) {
    uint32_t
    err_code;
    switch (event) {
    case BSP_EVENT_SLEEP:
    sleep_mode_enter();
    case BSP_EVENT_DISCONNECT:
    err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
    if (err_code != NRF_ERROR_INVALID_STATE) {
    case BSP_EVENT_WHITELIST_OFF:
    if (m_conn_handle == BLE_CONN_HANDLE_INVALID) {
    /**@brief Function for handling app_uart events.
    * a string. The string will be be sent over BLE when the last character received was a
    * 'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
    void uart_event_handle(app_uart_evt_t *p_event) {
    static uint8_t index = 0;
    uint32_t
    err_code;
    switch (p_event->evt_type) {
    case APP_UART_DATA_READY:
    index++;
    if ((data_array[index - 1] == '\n') ||
    (data_array[index - 1] == '\r') ||
    (index >= m_ble_nus_max_data_len)) {
    if (index > 1) {
    do {
    uint16_t
    length = (uint16_t) index;
    (err_code != NRF_ERROR_NOT_FOUND)) {
    } while (err_code == NRF_ERROR_RESOURCES);
    index = 0;
    // APP_ERROR_HANDLER(p_event->data.error_communication);
    case APP_UART_FIFO_ERROR:
    /**@brief Function for initializing the UART module.
    static void uart_init(void) {
    uint32_t
    err_code;
    .rx_pin_no = RX_PIN_NUMBER,
    .tx_pin_no = TX_PIN_NUMBER,
    .rts_pin_no = RTS_PIN_NUMBER,
    .cts_pin_no = CTS_PIN_NUMBER,
    .use_parity = false,
    .baud_rate = NRF_UART_BAUDRATE_115200
    #else
    .baud_rate = NRF_UARTE_BAUDRATE_115200
    UART_RX_BUF_SIZE,
    UART_TX_BUF_SIZE,
    uart_event_handle,
    APP_IRQ_PRIORITY_LOWEST,
    err_code);
    static void advertising_init(void) {
    uint32_t
    err_code;
    ble_advertising_init_t init;
    init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
    init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.srdata.uuids_complete.p_uuids = m_adv_uuids;
    init.config.ble_adv_fast_enabled = true;
    init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
    * @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
    static void buttons_leds_init(bool *p_erase_bonds) {
    bsp_event_t startup_event;
    uint32_t
    err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
    static void log_init(void) {
    ret_code_t
    err_code = NRF_LOG_INIT(NULL);
    static void power_management_init(void) {
    ret_code_t
    err_code;
    static void idle_state_handle(void) {
    UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
    nrf_pwr_mgmt_run();
    static void advertising_start(void) {
    uint32_t
    err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    //Functions to configure the TWI connection
    * @brief TWI initialization.
    static ret_code_t twi_init(nrf_drv_twi_t const *m_twi) {
    ret_code_t
    ret;
    const nrf_drv_twi_config_t config =
    .scl = 10,
    .sda = 8,
    .frequency = NRF_TWI_FREQ_400K,
    .interrupt_priority = APP_IRQ_PRIORITY_LOWEST,
    .clear_bus_init = false
    ret = nrf_drv_twi_init(m_twi, &config, NULL, NULL);
    while (ret != NRF_SUCCESS) {
    nrf_delay_ms(10);
    nrf_drv_twi_enable(m_twi);
    return ret;
    void conn_TWI(nrf_drv_twi_t const *p_nus) {
    twi_init(p_nus);
    /**@brief Application main function.
    int main(void) {
    bool erase_bonds;
    // Initialize.
    log_init();
    timers_init();
    bsp_board_led_on(BSP_BOARD_LED_0);
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    uart_init();
    advertising_init();
    conn_params_init();
    // Start execution.
    advertising_start();
    // Enter main loop.
    for (;;) {
    idle_state_handle();
