After the wdt is being ,the program cant be run immediately.
No using  bootloader.
the code cant run immediately is below when i enable the wtd.
After flashing the code by jlink,the code cant run till the wtd is timeout. i check the sd_power_reset_reason_get(&reg).
And the code reset,the code cant run till the wtd is timeout. i check the sd_power_reset_reason_get(&reg).
why?how can i do
