Inconsistent behavior when connecting from Custom BLE device to nrf52dk running different SDKs
We have a Сustom BLE device and observe inconsistent behavior when connecting from this device to to nrf52dk running different SDK versions.
- Custom Device connects OK with DK running SDK 13.1 / Soft Device ver: s132_nrf52_4.0.2_softdevice.hex
- Custom Device connects and immediately disconnects from DK running SDK 14.0 / Soft Device ver: s132_nrf52_5.0.0_softdevice.hex
- Custom Device doesn't have debug BlueZ output capability
- Alternative Reference Device (Raspi3, Raspbian Jessie) connects OK to all SDK-s from the list above
DK and application used:
- Hardware: Nordic nrf52dk pca10040
- Application: examples/ble_peripheral/ble_app_alert_notification
Custom Device info:
- Debian-based
- Linux kernel version: 3.14.79-xmm7272
- Bluez version 5.49
Based on DevZone posts, the suspicion was SDK 13 might have different clock settings vs. 14+. To validate this, we captured some registers' values in both 13 and 14 SDKs:
- NRF_CLOCK clock registers values right after enabling BLE stack
- Radio registers (NRF_RADIO->MODE and NRF_RADIO->MODECNF0) after successful connection to DK
Register values appeared to be exactly same in both cases.
Below are some logs examples when connecting Custom Device to DK.
1) SDK 13.1.0. Successful connection from Custom Device to DK
bluetoothctl output:
[bluetooth]# connect C7:81:0E:7B:BE:0B
Attempting to connect to C7:81:0E:7B:BE:0B
[CHG] Device C7:81:0E:7B:BE:0B Connected: yes
Connection successful
[NEW] Primary Service
/org/bluez/hci0/dev_C7_81_0E_7B_BE_0B/service000a
00001801-0000-1000-8000-00805f9b34fb
Generic Attribute Profile
[NEW] Characteristic
/org/bluez/hci0/dev_C7_81_0E_7B_BE_0B/service000a/char000b
00002a05-0000-1000-8000-00805f9b34fb
Service Changed
[NEW] Descriptor
/org/bluez/hci0/dev_C7_81_0E_7B_BE_0B/service000a/char000b/desc000d
00002902-0000-1000-8000-00805f9b34fb
Client Characteristic Configuration
[CHG] Device C7:81:0E:7B:BE:0B UUIDs: 00001800-0000-1000-8000-00805f9b34fb
[CHG] Device C7:81:0E:7B:BE:0B UUIDs: 00001801-0000-1000-8000-00805f9b34fb
[CHG] Device C7:81:0E:7B:BE:0B ServicesResolved: yes
[CHG] Device C7:81:0E:7B:BE:0B Paired: yes
[Nordic_Alert_Notif.]# disconnect
Attempting to disconnect from C7:81:0E:7B:BE:0B
[CHG] Device C7:81:0E:7B:BE:0B ServicesResolved: no
Successful disconnected
[CHG] Device C7:81:0E:7B:BE:0B Connected: no
nrf52dk output:
APP:INFO:Alert Notification client example started.
APP:INFO:Fast advertising
NRF_CLOCK->TASKS_HFCLKSTART 0x0
NRF_CLOCK->TASKS_HFCLKSTOP 0x0
NRF_CLOCK->TASKS_LFCLKSTART 0x0
NRF_CLOCK->TASKS_LFCLKSTOP 0x0
NRF_CLOCK->TASKS_CAL 0x0
NRF_CLOCK->TASKS_CTSTART 0x0
NRF_CLOCK->TASKS_CTSTOP 0x0
NRF_CLOCK->EVENTS_HFCLKSTARTED 0x0
NRF_CLOCK->EVENTS_LFCLKSTARTED 0x0
NRF_CLOCK->EVENTS_DONE 0x0
NRF_CLOCK->EVENTS_CTTO 0x0
NRF_CLOCK->INTENSET 0x0
NRF_CLOCK->INTENCLR 0x0
NRF_CLOCK->HFCLKRUN 0x0
NRF_CLOCK->HFCLKSTAT 0x10000
NRF_CLOCK->LFCLKRUN 0x1
NRF_CLOCK->LFCLKSTAT 0x10001
NRF_CLOCK->LFCLKSRCCOPY 0x1
NRF_CLOCK->LFCLKSRC 0x1
NRF_CLOCK->CTIV 0x0
NRF_CLOCK->TRACECONFIG 0x0
APP:INFO:Slow advertising
APP:INFO:Connected.
APP:INFO:NRF_RADIO->MODE 0x0
APP:INFO:NRF_RADIO->MODECNF0 0x200
APP:INFO:Start encryption.
APP:INFO:Connection secured: role: 1, conn_handle: 0x0, procedure: 1.
APP:INFO:Disconnected.
2) SDK 14.0.0. Connection and immediate disconnection from Custom Device to DK
nrf52dk output:
<info> app: NRF_CLOCK->TASKS_HFCLKSTART 0x0
<info> app: NRF_CLOCK->TASKS_HFCLKSTOP 0x0
<info> app: NRF_CLOCK->TASKS_LFCLKSTART 0x0
<info> app: NRF_CLOCK->TASKS_LFCLKSTOP 0x0
<info> app: NRF_CLOCK->TASKS_CAL 0x0
<info> app: NRF_CLOCK->TASKS_CTSTART 0x0
<info> app: NRF_CLOCK->TASKS_CTSTOP 0x0
<info> app: NRF_CLOCK->EVENTS_HFCLKSTARTED 0x0
<info> app: NRF_CLOCK->EVENTS_LFCLKSTARTED 0x0
<info> app: NRF_CLOCK->EVENTS_DONE 0x0
<info> app: NRF_CLOCK->EVENTS_CTTO 0x0
<info> app: NRF_CLOCK->INTENSET 0x0
<info> app: NRF_CLOCK->INTENCLR 0x0
<info> app: NRF_CLOCK->HFCLKRUN 0x0
<info> app: NRF_CLOCK->HFCLKSTAT 0x10000
<info> app: NRF_CLOCK->LFCLKRUN 0x1
<info> app: NRF_CLOCK->LFCLKSTAT 0x10001
<info> app: NRF_CLOCK->LFCLKSRCCOPY 0x1
<info> app: NRF_CLOCK->LFCLKSRC 0x1
<info> app: NRF_CLOCK->CTIV 0x0
<info> app: NRF_CLOCK->TRACECONFIG 0x0
<info> app: Alert Notification client example started.
<info> app: Fast advertising
<info> app: Connected.
<info> app: NRF_RADIO->MODE 0x0
<info> app: NRF_RADIO->MODECNF0 0x200
<info> app: Disconnected.
Our goal is to either somehow configure SDK 14+ to support connectivity to it from this device or at least be able to understand what is preventing from successful connection.
Any help will be much appreciated!
    Are you using the LF RC oscillator ?
    What is the value of NRF_SDH_CLOCK_LF_SRC and NRF_SDH_CLOCK_LF_XTAL_ACCURACY in sdk_config.h?
    Note that starting from s132_nrf52_5.0.0-2.alpha, the application need to set the accuracy/ppm of the RC oscillator itself. From the s132_nrf52_5.0.0-2.alpha release notes:
    The RC oscillator accuracy can now be set to any of the defined NRF_CLOCK_LF_ACCURACY values, and there is no default anymore. In other words, the nrf_clock_lf_cfg_t::accuracy parameter now has the same functionality when used with the RCOSC clock source as with the XTAL clock source
  • We use XTAL for the posted results, tried different NRF_SDH_CLOCK_LF_XTAL_ACCURACY values.
    In other attempts we also used RC as a clock source with different NRF_SDH_CLOCK_LF_RC_CTIV values - no luck either.
    Here's our current sdk_config.h configuration:
    // <h> Clock - SoftDevice clock configuration
    // <o> NRF_SDH_CLOCK_LF_SRC  - SoftDevice clock source.
    // <0=> NRF_CLOCK_LF_SRC_RC
    // <1=> NRF_CLOCK_LF_SRC_XTAL
    // <2=> NRF_CLOCK_LF_SRC_SYNTH
    #ifndef NRF_SDH_CLOCK_LF_SRC
    #define NRF_SDH_CLOCK_LF_SRC 1
    // <o> NRF_SDH_CLOCK_LF_RC_CTIV - SoftDevice calibration timer interval.
    #ifndef NRF_SDH_CLOCK_LF_RC_CTIV
    #define NRF_SDH_CLOCK_LF_RC_CTIV 0
    // <o> NRF_SDH_CLOCK_LF_RC_TEMP_CTIV - SoftDevice calibration timer interval under constant temperature.
    // <i> How often (in number of calibration intervals) the RC oscillator shall be calibrated
    // <i>  if the temperature has not changed.
    #ifndef NRF_SDH_CLOCK_LF_RC_TEMP_CTIV
    #define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 0
    // <o> NRF_SDH_CLOCK_LF_XTAL_ACCURACY  - External crystal clock accuracy used in the LL to compute timing windows.
    // <0=> NRF_CLOCK_LF_XTAL_ACCURACY_250_PPM
    // <1=> NRF_CLOCK_LF_XTAL_ACCURACY_500_PPM
    // <2=> NRF_CLOCK_LF_XTAL_ACCURACY_150_PPM
    // <3=> NRF_CLOCK_LF_XTAL_ACCURACY_100_PPM
    // <4=> NRF_CLOCK_LF_XTAL_ACCURACY_75_PPM
    // <5=> NRF_CLOCK_LF_XTAL_ACCURACY_50_PPM
    // <6=> NRF_CLOCK_LF_XTAL_ACCURACY_30_PPM
    // <7=> NRF_CLOCK_LF_XTAL_ACCURACY_20_PPM
    #ifndef NRF_SDH_CLOCK_LF_XTAL_ACCURACY
    #define NRF_SDH_CLOCK_LF_XTAL_ACCURACY 7
    Thanks for the reply!
  • Could you print the disconnect reason?
    In ble_evt_handler, you could do something like this:
                NRF_LOG_INFO("Disconnected reason: %d.",p_ble_evt->evt.gap_evt.params.disconnected.reason);
  • 62(0x3E is BLE_HCI_CONN_FAILED_TO_BE_ESTABLISHED. This is normally a sign that one of the peers have lost packets during the initial "CONNECT_REQ" process. You can get into a scenario where you receive the request, but the central does not get the ACK from the peripheral. This can happen if the RF link quality is bad (ie: connecting at a long range), or when there is an issue with the RF layout (soldering is bad or similar).
    How often do you see this issue? Are you able to reliable recreate it?
    To rule out any problems with the LF crystal, you could try to use the RC oscillator:
    Try these values in sdk_config.h
    // </h>
    #define NRF_SDH_CLOCK_LF_SRC 0
    #define NRF_SDH_CLOCK_LF_RC_CTIV 16
    #define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2
    #define NRF_SDH_CLOCK_LF_XTAL_ACCURACY 1
