How to detect binding information lost?
Hi all,
I'm using nrf51822 and ble_app_multirole_lesc example on SDK 12.3.
When I connect with "nrf connect" Android application for the first time, the bind is established and the communication is secure.
After that, I deleted the bond information from the mobile phone and I tried to reconnect again, nRF accepts the connection and calls "PM_EVT_PEER_DATA_UPDATE_SUCCEEDED" event.
1-How can this happen?
2-Is there an event called (nRF side) to detect that the mobile has lost the binding information?
Best regards.
    I assume that you connect with nRF Connect as a central (nRF in peripheral role), is that correct?
    Have you set:
    pm_conn_sec_config_t conn_sec_config = {.allow_repairing = true}; ?
    or is it false?
    Edvin
    Yes, I connected with nRF Connect as a central (nRF in peripheral role).
    I found that the pm_conn_sec_config_t conn_sec_config is called from PM_EVT_CONN_SEC_CONFIG_REQ event but this event is not called when I deleted the bond information from the mobile phone and I tried to reconnect again ( reconnect without entering in the bond process in the mobile side).
    This is the log I get when I reconnect:
    0> New stack status = CONNECTED
    0> CCW:DEBUG:PM_EVT_BONDED_PEER_CONNECTED Connected to previously bonded device
    0> CCW:INFO: PM_EVT_PEER_DATA_UPDATE_SUCCEEDED: peer_id=0 data_id=0x6 action=0x0
    0> CCW:INFO: PM_EVT_LOCAL_DB_CACHE_APPLIED
    1 - Is there an event called (nRF side) to detect that the mobile has lost the binding information?
    2- Can the nRF request to start the pairing/bonding process?
    Youssef
  • So do you have allow_repairing = true?
    1: no
    2: yes. The ble_app_gls example does this. It starts a timer in the connected event. In the timeout handler (sec_req_timeout_handler) it will ask to pair with the central. Check out this example.
    pm_conn_secure(conn_handle, force_repairing);
    force repairing is a bool value which will force re-pairing if true.
    Edvin
  • Thank you Edvin for your answer, that is what I am looking for
