flash questions
Question  1 :
I write 512 words to flash but only can get some value right .and some value was wrong.
I  used      fs_store( &one_min_data,
                                                        (uint32_t *)(FLASH_DATA_ADRR),
                                                        (uint32_t *)(&buffer),
                                                        512,
                                                        NULL);
The value should be 0 -511 .but the value in the flash is not like that .
By the way my sdk is 12.3.And with   ble app uart     demo.
What  I  have done and init   light   this
err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);//添加系统事件派发
void sys_evt_dispatch(uint32_t sys_evt)
//这函数在fstorage.c中实现
ble_advertising_on_sys_evt(sys_evt);
fs_sys_event_handler(sys_evt);
FS_REGISTER_CFG(fs_config_t one_min_data) =
.callback = one_min_data_flash_ok_event,// Function for event callbacks.
.num_pages = 6, // Number of physical flash pages required.
.priority = 0xFE // Priority for flash usage.
void one_min_data_flash_ok_event(fs_evt_t const * const evt, fs_ret_t result)
    if(evt->id==FS_EVT_STORE && result==FS_SUCCESS)
      MI_LOG_INFO("one_min_data_flash_ok_event\r\n");
512 flash write
Question  2 :
I  have tried another way I write three times Continuously. Also use  fs_store()
But the second time always get 00000000.
1st  value 0x55555555    address :122*4096                      ok
2nd value   whatever      address :121*4096                      wrong  get  0x00000000
3rd  value 0x5a5a5a5a    address:120*4096                        ok
And  I found that  no matter  which one is the second to write  it always wrong .
  • I found something ,if I write
                                                            512,
                                                            NULL);
                                                            512,
                                                            NULL);
  • I found something
    If I just  wait for event and do nothing after I call
                                                            512,
                                                            NULL);
    It will be OK.
    like this
    kk=fs_store( &one_min_data,
    buffer_text,
    512,
    NULL);
    while(1)
    if (NRF_LOG_PROCESS() == false)//将保存的LOG都吐出来之后进入休眠
    uint32_t err_code = sd_app_evt_wait();
    SO my question is that should I wait the complete event.and do nothing before that,just SD_app_evt_wait();
    until I resieve a flag whith be set by the complete event .like below
      recieve_flag=1;
    buffer_text,
    512,
    NULL);
    recieve_flag=0;
    while(recieve_flag!=1)
    IS the only way?
  • Yes, fstorage use asynchronous write and erase operations. You need to wait for the event before you can read back the written data, if not the operation might not be completed.
  • Thank you .I have tried for days to find the answer .thank you again .
