Hello!
I want to use easyDMA. The SDK version I use is SDK15.0.I want to know how to config easyDMA.For example , If I only need to config TWI0_USE_EASY_DMA==1 ?
Hello!
Yes, correct. Let me explain.
When using one of the provided examples in SDK 15 (for example twi_sensor), you have two choices when using I2C: TWIM (also TWIS) or TWI, where the first uses easyDMA and the second does not. When you enable easyDMA through either TWI0_USE_EASY_DMA or TWI1_USE_EASY_DMA, the example will use the functions in the TWIM driver (not the TWI driver).
Best regards, Simon
how to enable twim0...i changed in sdk_config.h still not working..
it was no problem in twi_sensor example...now i am integrating twi_sensor in ble_eddystone...and on built it give an error of "'NRF_DRV_TWI_INSTANCE_0' undeclared here (not in a function); did you mean 'NRF_DRV_TWI_INSTANCE_'?"
what is the reason and can you tell me how to enable twim0..
below is nrf_drv_twi.h file ...which shows that twim0 is not enabled..can you solve yhis problem..it would be great help..thank you.
If you look at the file nRF5_SDK_15.3.0\integration\nrfx\legacy\nrf_drv_twi.h, you will see that NRF_DRV_TWI_INSTANCE_0 depends on either NRFX_TWIM0_ENABLED or NRFX_TWI0_ENABLED.
#if NRFX_CHECK(NRFX_TWIM0_ENABLED)
#define NRF_DRV_TWI_INSTANCE_0 \
{ 0, { .twim = NRFX_TWIM_INSTANCE(0) }, true }
#elif NRFX_CHECK(NRFX_TWI0_ENABLED)
{ 0, { .twi = NRFX_TWI_INSTANCE(0) }, false }
#if NRFX_CHECK(NRFX_TWIM1_ENABLED)
#define NRF_DRV_TWI_INSTANCE_1 \
{ 1, { .twim = NRFX_TWIM_INSTANCE(1) }, true }
#elif NRFX_CHECK(NRFX_TWI1_ENABLED)
{ 1, { .twi = NRFX_TWI_INSTANCE(1) }, false }
Take a look at nRF5_SDK_15.3.0\integration\nrfx\legacy\apply_old_config.h to see how to enable these two configs. E.g. if you set TWI0_ENABLED and TWI0_USE_EASY_DMA to 1 in the sdk_config.h, then NRFX_TWIM0_ENABLED will be set to 1.
#if defined(TWI_PRESENT) && !defined(TWIM_PRESENT)
#undef NRFX_TWI0_ENABLED
#define NRFX_TWI0_ENABLED TWI0_ENABLED
#undef NRFX_TWIM0_ENABLED
#define NRFX_TWIM0_ENABLED 0
#undef NRFX_TWI1_ENABLED
#define NRFX_TWI1_ENABLED TWI1_ENABLED
#undef NRFX_TWIM1_ENABLED
#define NRFX_TWIM1_ENABLED 0
#elif !defined(TWI_PRESENT) && defined(TWIM_PRESENT)
#define NRFX_TWI0_ENABLED 0
#define NRFX_TWIM0_ENABLED TWI0_ENABLED
#define NRFX_TWI1_ENABLED 0
#define NRFX_TWIM1_ENABLED TWI1_ENABLED
#else // -> defined(TWI_PRESENT) && defined(TWIM_PRESENT)
#define NRFX_TWI0_ENABLED (TWI0_ENABLED && !TWI0_USE_EASY_DMA)
#define NRFX_TWIM0_ENABLED (TWI0_ENABLED && TWI0_USE_EASY_DMA)
Simon
