is multi touch HID possible with nrf51822 chip?
Hi All,
       Currently i am working on nrf51822 for multi touch HID.For that i have chosen mouse HID example as a reference, in which i have changed HID descriptor(single touch) and some other things.So, that single touch has been working.
And, if i changed the HID descriptor for multi touch, touch devices(touch laptop) were showing "Bluetooth driver error".
is it possible multi touch HID over nrf51822 as a reference of mouse HID example?
if possible, what all changes are to be required to work for multi touch.
so, please guide me how to implement multi touch HID over nrf51822.
regards
akash.
  • Hi Akash
    Multi touch should definitely be possible with the nRF51 series.
    Microsoft have some good articles on how to use multi touch with windows, such as this one. Have you had a look at that?
    If you still can't make it work, are you able to attach your HID descriptor so I can have a look at it?
    Best regards
    Torbjørn
  • Thanks for your precious reply.
    yes, i have gone through windows multi touch HID, but didn't work for me.
    so, i have taken one more multi touch HID, which has been working over USB.
    if i emulated same HID into Bluetooth stack, it was not working.
    here, i am attaching my HID
    0x05, 0x0D, // Usage Page (Digitizer)
    0x09, 0x04, // Usage (Touch Screen)
    0xA1, 0x01, // Collection (Application)
    0x09, 0x22, // Usage (Finger)
    0xA1, 0x02, // Collection (Logical)
    0x09, 0x42, // Usage (Tip Switch)
    0x15, 0x00, // Logical Minimum (0)
    0x25, 0x01, // Logical Maximum (1)
    0x75, 0x01, // Report Size (1)
    0x95, 0x01, // Report Count (1)
    0x81, 0x02, // Input (Data,Var,Abs,No Wrap,Linear,Preferred State,No Null Position)
    0x09, 0x30, // Usage (Tip Pressure)
    0x25, 0x7F, // Logical Maximum (127)
    0x75, 0x07, // Report Size (7)
    0x09, 0x51, // Usage (0x51)
    0x26, 0xFF, 0x00, // Logical Maximum (255)
    0x75, 0x08, // Report Size (8)
    0x05, 0x01, // Usage Page (Generic Desktop Ctrls)
    0x09, 0x30, // Usage (X)
    0x09, 0x31, // Usage (Y)
    0x26, 0xFF, 0x7F, // Logical Maximum (32767)
    0x65, 0x00, // Unit (None)
    0x75, 0x10, // Report Size (16)
    0x95, 0x02, // Report Count (2)
    0xC0, // End Collection
    0x27, 0xFF, 0xFF, 0x00, 0x00, // Logical Maximum (65534)
    0x09, 0x56, // Usage (0x56)
    0x09, 0x54, // Usage (0x54)
    0x25, 0x05, // Logical Maximum (12)
    0x09, 0x55, // Usage (0x55)
    0x25, 0x0A, // Logical Maximum (12)
    0xB1, 0x02, // Feature (Data,Var,Abs,No Wrap,Linear,Preferred State,No Null Position,Non-volatile)
    is there any changes are to be required in code(like feature report, input report,output report)?
    because, single touch has been working without adding any feature reports and output reports.
    regards,
    akash.
  • Hi Akash
    Have you had any progress with this lately?
    I am sorry for not getting back to you sooner. I have been quite busy with other tasks, and so far my attempts at setting up a similar HID report has been unsuccessful.
    I will do my best to get back to you next week with a working HID report.
    Best regards
    Torbjørn
  • Hi Ovrebekk
    I have also been working on HID to get it work, but couldn't get any break through.
    Regards
    akash
  • Hi Akash
    Still no luck?
    I am able to pair a kit to my phone using a descriptor very similar to yours, but I don't know what data I should send to test it out.
    Do you have some sample data sets I could use to test this?
    If for instance you want to activate two touch points at the same time, what is the recommended sequence of events?
    Do you know about any off the shelf BLE devices that implement multi touch over HID that could be used as a reference point?
    Best regards
    Torbjørn
