Hello, I have just started evaluating SoC nRF52832 and have built a custom board based on recommended diagram from the datasheet chapter 53.3. Actually, the board diagram and layout was published in the official Eagle 9.1.0 CAD examples release and follows the layout guidelines from Nordic well.
I've managed to get started with nRF52 SDK, Keil uVision and ST-Link and made my blinky examples running. Yaaay! However, I had no success in turning on the ble_uart example. I couldn't see the device advertising. I also tried to pick up any signal at the chip output with my 4GHz / 20GSps scope, but there was none.
Lastly, I decided to check if there is maybe some short circuit at the pin output and I measured 2.7 Ohm DC resistance between ANT pin and the ground. Is this value plausible DC resistance (as far as I understand there is a balun at the output pin) or am I dealing with potential short-circuit due to the soldering failure?
W.
