Is there somewhere an example of the scan module with a filter on a 128bits UUID address ?
Thanks in advance for your help
Best regards
Best regards
I suggest you to have a look the hrs central example, inside the on_adv_report you will find ble_advdata_uuid_find().
Hi Mttrinh,
Thanks for your answer.
With SDK15.2, it seems we don't use on_adv_report. I think it's the old way with older sdk.
I wanted to use the new scan module and I think I found the solution by myself.
I still have to see how to change the scan settings without using the defaults set in the sdk_config.h
I'm also looking to add 128bit uuid in my scan filter. i request you, please explain how you achieve this.
Thanks and regards
basava.
Have a look at the nrf_ble_scan_filter_set() function inside scan_init() in UART example.
Hey MPS,
I know it's late, but I saw this thread while I was searching for the same answer. Here's a declaration I found in ble.h:
/**@brief Add a Vendor Specific base UUID. * * @details This call enables the application to add a Vendor Specific base UUID to the BLE stack's table, for later * use with all other modules and APIs. This then allows the application to use the shorter, 24-bit @ref ble_uuid_t * format when dealing with both 16-bit and 128-bit UUIDs without having to check for lengths and having split code * paths. This is accomplished by extending the grouping mechanism that the Bluetooth SIG standard base UUID uses * for all other 128-bit UUIDs. The type field in the @ref ble_uuid_t structure is an index (relative to * @ref BLE_UUID_TYPE_VENDOR_BEGIN) to the table populated by multiple calls to this function, and the UUID field * in the same structure contains the 2 bytes at indexes 12 and 13. The number of possible 128-bit UUIDs available to * the application is therefore the number of Vendor Specific UUIDs added with the help of this function times 65536, * although restricted to modifying bytes 12 and 13 for each of the entries in the supplied array. * * @note Bytes 12 and 13 of the provided UUID will not be used internally, since those are always replaced by * the 16-bit uuid field in @ref ble_uuid_t. * * @note If a UUID is already present in the BLE stack's internal table, the corresponding index will be returned in * p_uuid_type along with an @ref NRF_SUCCESS error code. * * @param[in] p_vs_uuid Pointer to a 16-octet (128-bit) little endian Vendor Specific base UUID disregarding * bytes 12 and 13. * @param[out] p_uuid_type Pointer to a uint8_t where the type field in @ref ble_uuid_t corresponding to this UUID will be stored. * * @retval ::NRF_SUCCESS Successfully added the Vendor Specific base UUID. * @retval ::NRF_ERROR_INVALID_ADDR If p_vs_uuid or p_uuid_type is NULL or invalid. * @retval ::NRF_ERROR_NO_MEM If there are no more free slots for VS UUIDs. */ SVCALL(SD_BLE_UUID_VS_ADD, uint32_t, sd_ble_uuid_vs_add(ble_uuid128_t const *p_vs_uuid, uint8_t *p_uuid_type));
In the nordic UART service, the call looks like this:
err_code = sd_ble_uuid_vs_add(&nus_base_uuid, &p_ble_nus_c->uuid_type);
As Mttrinh suggests, the central UART example is where you can see it fully
