RESET PIN flag of RESETREAS sets after power cycle
I'm currently developing software on nrf52832. Unfortunately, I can't use the SDK for different reasons.
I'm currently looking at the RESETREAS register. If I correctly understand the datasheet, I should have the RESETREAS register with all bits to 0 if the module restarts after a power-cycle. However, in my case, I got the RESET PIN flag that is always set (RESETREAS=0x00000001) after such event.
In other situations, as for example after a reset from my code, I correctly have SREQ flag that is set (RESETREAS=0x00000100).
At boot, I read the RESETREAS register. Then I clear it to avoid having problems at next boot (NRF_POWER->RESETREAS = 0xFFFFFFFF;).
Do you have any idea why I always get the RESET PIN flag after a simple power off-power on ?
Thanks in advance for your answer,
Florent
    I have not been able to reproduce this on my side. I have a few questions:
    • Can you upload a code snippet that reproduces it on your side?
    • Do you see it occurring on multiple nRF52832 devices?
    • Is pin reset enabled for the device (PSELRESET in UICR)?
    • Do you see the same if it is not?
    Einar
  • Hi Einar,
    Thank you for your answer.
    • Can you upload a code snippet that reproduces it on your side? Here is what I'm doing:
    uint32_t reset_reason;
    // Read the RESETREAS register
    reset_reason = NRF_POWER->RESETREAS;
    // Clear the flag
    After a power cycle, reset_reason = 1. After a soft reset from my code for instance, reset_reason = 4.
    Yes I've tried on 3 devices and it happened on the 3.
    I think so but maybe I'm doing it in a wrong way. Here is how I do:
    if (((NRF_UICR->PSELRESET[0] & UICR_PSELRESET_CONNECT_Msk) != (UICR_PSELRESET_CONNECT_Connected << UICR_PSELRESET_CONNECT_Pos)) ||
      ((NRF_UICR->PSELRESET[1] & UICR_PSELRESET_CONNECT_Msk) != (UICR_PSELRESET_CONNECT_Connected << UICR_PSELRESET_CONNECT_Pos))){
    	/** Configure the NVMC for write mode */
    	NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen << NVMC_CONFIG_WEN_Pos;
    	while (NRF_NVMC->READY == NVMC_READY_READY_Busy){
    		// Do nothing.
    	/** Activate the reset pin */
    	NRF_UICR->PSELRESET[0] = 21;
    		// Do nothing.
    	NRF_UICR->PSELRESET[1] = 21;
    		// Do nothing.
    	/** Desactivate write mode for the NVMC (let it in read mode) */
    	NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren << NVMC_CONFIG_WEN_Pos;
    	/** Wait until config is done */
    		// Do nothing.
    I'm not sure to understand what you mean sorry.
    Florent
    Are you using custom HW? Could it be that for some reason the reset pin is asserted for some reason during power-up?
    My last question should not have been a separate point, so It became unclear. What I wander is if you see the same behaviour if you don't have pin reset enabled (to disable it you have to erase UICR and do a power cycle)?
  • Thank you for your answer Einar.
    Indeed, it's custom HW. Bu you are right. I will test on an DK board. I have no DK board with me today. I will therefore try tomorrow and see the behavior with this HW.
    Concerning the reset pin, as you say, I will also test with the reset pin not enabled.
    I will inform you about the results tomorrow (after the test on the DK board).
    Florent
